and does it work?
Versaboss | 02/12/2019 13:33:54 |
461 forum posts 51 photos | I have this small program on my computer (W.10) since umpteen years. It shows as version 1.8.0, seems this is the latest version. When I wanted to use it now, I had to discover that it stopped to work correctly. Some of the buttons display now a black background, and the 'captions' are invisible, and 'calculate' does nothing.
Kind regards, |
steamdave | 02/12/2019 14:47:03 |
462 forum posts 35 photos | I've just downloaded from your link and tried it out. Seems to work OK for me on Windoz 7 Pro. Dave |
Jim Nic | 02/12/2019 14:55:49 |
![]() 288 forum posts 164 photos | Hi Hans I have Alan Mundays Model Engineers Utilities installed on my workshop notebook computer running Windows XP. I loaded it umpteen years ago also (2011 or so) and mine is also version 1.8. It is still working fine as it always has. I have never tried it on a computer with a more modern operating system. No help to you, I'm sorry to say. Jim |
Martin Connelly | 02/12/2019 15:17:30 |
![]() 1615 forum posts 177 photos | Downloaded in Windows 10 Ran it and had an error Ran it as administrator and unpacked ok to C:\program files\model engineers utilities Ran the .exe file with no problems all looks ok. Martin C
peak4 | 02/12/2019 15:23:19 |
![]() 1327 forum posts 148 photos | Just downloaded a copy, as I'm not sure where mine was filed. Bill. |
Keith Wyles | 02/12/2019 15:49:02 |
35 forum posts | For me Win 10, error from program file folder, but OK when unzipped to desktop. |
SillyOldDuffer | 02/12/2019 15:58:26 |
Moderator 6689 forum posts 1503 photos | OK on Ubuntu 19.10, with wine-4.0.2 (Ubuntu 4.0.2-1) |
peak4 | 02/12/2019 17:16:18 |
![]() 1327 forum posts 148 photos | Posted by Keith Wyles on 02/12/2019 15:49:02:
For me Win 10, error from program file folder, but OK when unzipped to desktop. Yes, I to unzipped and ran from a documents folder, rather than program Files.
Neil Wyatt | 02/12/2019 17:26:25 |
![]() Moderator 18414 forum posts 718 photos 78 articles | Under W8 (and maybe W7 or Vista) you may need to look at the properties of the EXE file and tell it to run in a compatibility mode. W10 seems to be much more tolerant of running older programs - I run a 20 year old copy of Corel Suite on W10 with no difficulty, with Vista I had to use compatibility mode and with W7 there were some 'quirks' that have now disappeared under W10. Neil |
Emgee | 02/12/2019 17:31:52 |
1831 forum posts 240 photos | https://modelengineersutilities.software.informer.com/ From another topic thread, takes you to ME Utilities Edited By Emgee on 02/12/2019 17:36:38 Edited By Emgee on 02/12/2019 17:38:14 |
John Purdy | 02/12/2019 19:28:43 |
![]() 237 forum posts 131 photos | I have it on two computers a Win7 and a Win10 and so far have only used it for drill sizes for tapping and it seems to work OK for that. But I just tried some of the other functions and I get the same as Hans, a lot of black boxes where input data should be. I had it on an XT machine and all functions worked OK. I've just downloaded it from both sites listed in the above posts and it does the same thing. It does not matter which folder I unzip it to or if I unzip it as administrator, the initial screen comes up fine but when any of the functions are selected they come up with a number of black boxes. John |
Bandersnatch | 03/12/2019 01:51:53 |
![]() 1719 forum posts 60 photos | Later versions of Windows (8 and 10 at least) do not allow a program to put (and write to) its data files in the install directory \Program Files or \Program Files (x86) which are protected locations. It was quite common to do that in earlier times and if that's what this program is trying to do, Windows will barf when attempts are made to write to the data files unless you permanently invoke full administrator privileges (not a good idea). If the install program gives a choice, installing somewhere else ought to work. Also check whether it needs any other windows components (Visual Basic run-times etc) and that you have them. |
Thor | 03/12/2019 06:03:45 |
1324 forum posts 40 photos | Hi Hans, I have tried the ME Utilities program on my W.10 computer, I unpacked it as Administrator and tried to run it as Administrator and the main screen pops up without problems, but when trying for instance the "Speeds" part I too get the black backgound and buttons not doing anything. The screwcutting part seems to work OK, so mixed results on my new computer. When I find time I will try it on my old computer running XP. Thor |
Versaboss | 03/12/2019 14:14:56 |
461 forum posts 51 photos | After several tries with the hints given here (installing as administrator* and unpacking into an 'ordinary' data file) I have, on Windows 10, still the same results as described by Thor above. But, doing the same on my W. 8.1 laptop resulted in a correctly running program! All black on white background, fully usable! Still wondering what's going on here. As it was running correctly for many years, I suspect 'something' was updated some time back. (*) On W10 I had first to find out how to install myself as administrator, but the laptop has 'execute as administrator' in the context menu! Kind regards |
peak4 | 03/12/2019 15:17:56 |
![]() 1327 forum posts 148 photos | Versaboss, my understanding is that it is a stand alone program, so as such there is no need to "Install" it , as admin or otherwise. In my case, I downloaded the file from the link above. This was named as meu_v1_8.exe ; the icon associated with it is that of a folder with a clamp around it, rather than a folder with a zip running across it. That means, in this case, that it is a self extracting compressed folder, with the file type of "application". When you have downloaded the file, and virus checked if you wish, double click on it. Press the unzip icon. Use Explorer to navigate to your chosen folder, which should now contain 9 files (in my case). Bill
Edited By peak4 on 03/12/2019 15:19:31 |
John Purdy | 03/12/2019 18:58:18 |
![]() 237 forum posts 131 photos | Bill When you open the program and select one of the functions (say "cutting speeds" ), does it work normally, no black boxes? I have just downloaded it (again) to my W10 laptop and installed it exactly the way you describe above and it still does not work. When any of the functions are selected (say "cutting speed" as Thor selected) all I get is a couple of boxes listing inputs ( one is "materials" and the other is "calculate" ) but the rest are just black boxes. I would sure like to know how you get it to work properly on your machine. It also does the same thing on my W7 platform when installed as above. John Edited By John Purdy on 03/12/2019 18:59:07 |
peak4 | 03/12/2019 19:58:19 |
![]() 1327 forum posts 148 photos | John, right, now I see the problem. A bit tied up for the moment as I'm packing for a couple of days away, but I'll try in on an XP machine. A quick read around on the net, and this forum in particular, suggests the need for Visual Basic 6 runtime files, but not easy to install on W10. These files were dropped after XP https://www.model-engineer.co.uk/forums/postings.asp?th=48495 Sadly it looks like the author of the software is no longer with us, so don't expect any updates. I'm not about to play at the moment, as other things to do, but This is a possibility See also This from Microsoft Bill
Edited By peak4 on 03/12/2019 20:28:00 |
Versaboss | 03/12/2019 22:10:12 |
Just to show what's going wrong: here a picture of the limits and fits button. Oh the troubles, when the .jpg is too big, nothing happens. Kind regards, Edited By Versaboss on 03/12/2019 22:18:55 Edited By Versaboss on 03/12/2019 22:20:30 |
Thor | 04/12/2019 06:31:11 |
1324 forum posts 40 photos | Hi Hans, Your screenshot is exactly what I experience on my W.10 laptop. Here's a screenshot when running Win.XP: The program works well under Win.XP, and I have tried to tell W.10 to emulate Win.XP when running it, but it still looks like your screenshot. So I have not been able to find a way around the problem, may be others with more computer knowledge can help. Thor Edited By Thor on 04/12/2019 06:31:39 |
