Cracking a bolt
Danny M2Z02/12/2019 04:05:52
892 forum posts
283 photos
While playing with my new digital torque wrench I realised that trying to measure the undo torque of a previously installed bolt was a waste of time in many cases as the bolt suddenly lets go with an audible crack.
I am sure that I am not the first person to have noticed that bolts that have been installed (usually during manufacture) are reluctant to let go and when they do it is often with a 'crack'.
Inspection usually reveals no trace of thread sealant but I did notice that often the bolt is steel and the body is an aluminium alloy such as an engine cylinder head.
So why do we have to crack a bolt ?
* Danny M *
XD 35102/12/2019 04:41:50
1461 forum posts
Microscopic galling on the thread surfaces and between the bolt head and parent metal ?
James Winkler02/12/2019 05:03:13
6 forum posts
I have noted that it occurs if a black-oxide steel alloy screw has been installed for awhile. I seem to remember that tightening then quickly removing a steel alloy screw from aluminium alloy threads does not have nearly the break-free torque. Maybe the steel removes the aluminium oxide which reforms after awhile? There is a characteristic "smoke" and odour when the screw / bolt breaks free.
bill ellis02/12/2019 07:27:14
71 forum posts
Electrolytic (galvanic) corrosion caused by two dissimilar metals being in close contact. Basically one becomes the anode & one the cathode, the anode gets eaten causing the deposit which sticks the bolt in the hole.
John MC02/12/2019 08:18:40
305 forum posts
38 photos
Overcoming the static friction?
roy entwistle02/12/2019 09:07:06
1224 forum posts
Cylinder head bolts are usually in tension, they stretch which is why you don't use them again
Roy
roy entwistle02/12/2019 09:07:13
1224 forum posts
Roy
Michael Gilligan02/12/2019 09:30:05
16210 forum posts
707 photos
Zinc Chromate paste [Duralac for example] is very effective.
[ see post by bill ellis ]
Edited By Michael Gilligan on 02/12/2019 09:32:08
Nicholas Wheeler 102/12/2019 10:09:15
362 forum posts
20 photos
Posted by roy entwistle on 02/12/2019 09:07:13:
Roy
ALL bolts are in tension and stretch; that's how they work! Really critical bolts - con rod bolts for example - are tightened by measuring how much they have stretched
You're thinking of torque-to-yield bolts, that are deliberately tightened to near their failure point which means they shouldn't be reused.
ChrisB02/12/2019 12:14:34
537 forum posts
192 photos
If not referring to cylinder head bolts only, I wouldn't say all bolts are in tension.
Mick B102/12/2019 12:29:00
1666 forum posts
88 photos
Posted by ChrisB on 02/12/2019 12:14:34:
Why not? Seems to me that tightening a nut is trying to draw the bolt through the hole, and tightening a bolt into a static thread is trying to force the head in. The only thing that stops it unwinding from its own elastic tension is the frictional force between the thread flanks that is augmented by that tension to exceed the rotational vector derived from the helix angle.
So I'd think that any bolt that's in tight enough to resist vibration is in tension. Even if it's loose and the nut's just hanging on the thread, it's in slight tension - come to that its own weight can put it in tension.
Mick Dobson02/12/2019 12:31:58
21 forum posts
10 photos
Of course all bolts are in tension, once torque is being developed, whether special cylinder head bolts or otherwise.
The thread pitch derives a longitudinal force as a result of the torque applied. Lubrication and surface coating will also affect the friction, so the same torque on an oiled thread will give a larger tension than on a dry thread.
As mentioned by Nicholas, that is how fasteners work
ChrisB02/12/2019 12:47:46
537 forum posts
192 photos
Well I have seen cases where bolts are used in shear. The bolt is retained by a castle nut which is tightened just for the purpose of not falling off and secured by a cotterpin or tab washer. All the load the bolt carries is in shear not tension in these cases I mention.
Michael Gilligan02/12/2019 12:57:55
16210 forum posts
707 photos
Posted by ChrisB on 02/12/2019 12:47:46:
With the greatest respect, Chris ... That seems a very inefficient way to use a bolt
It is effectively just a shear-pin with something to stop it falling out.
Could you give us an example, please
Nicholas Wheeler 102/12/2019 13:07:43
362 forum posts
20 photos
That's common on cable linkages. But the cotter pin is doing the retaining, not the nut which is more of an adjustable spacer.
ChrisB02/12/2019 13:10:01
537 forum posts
192 photos
Posted by Michael Gilligan on 02/12/2019 12:57:55:
You may call it a shear pin Michael, I called it a bolt as most are threaded and have a hex or 12pt head. My experience of these types of "bolts" comes from aviation - as to the efficiency of use of these type of bolts, I'm not the designer, I just encountered them!
Oily Rag02/12/2019 13:13:11
123 forum posts
57 photos
To measure the torque of a retaining bolt (or stud and nut assembly) the usual method employed by engine development engineers is to mark the radial position of the bolt (or nut) relative to a surrounding fixed point, then to 'break off' the fastener and then to re-tighten to 'mark' - this will give the torque load of a fastener assembly. Where an engine cylinder head is concerned the torque loads will vary according to differences in gasket collapse, local casting collapse, either through thermal cycling or casting imperfections, and also due to thread 'pull'. There are now, however, systems which allow the torque induced in the bolt (or stud) to be read by recording the 'pitch'when the exposed end of the bolt (or stud) is struck, this without the need to disassemble. This uses the similarity between a bolt and a guitar string in tension to produce a 'pitch' when excited - a higher 'pitch' indicates a higher tension. This system requires a correlation exercise to remove all associated variables such as casting material, cavity differences, and other damping inducing effects which may be present. So, it will only work in a production environment for a specific application and / but with a corresponding error bandwidth due to casting production tolerances.
As mentioned previously by another respondent, the best way to tension conrod bolts is to measure the 'stretch' of the bolt by a non rotating point anvil micrometer. Carillo rods using APC fasteners have a 'stretch value' defining their fitting tension - a typical value may be something in the order of 0.0048".
John MC02/12/2019 13:35:03
305 forum posts
38 photos
Like a lifting shackle? Not a bolted joint is it. Stretching (no pun intended) the point a bit.
old mart02/12/2019 14:24:46
1921 forum posts
151 photos
Torque wrenches are for tightening bolts, not for undoing them. On a typical application such as a cylinder head, the bolts will be done up to a lower torque on the first time round, and then to the full tightness finally. The final tightening should be done in one continuous movement per bolt. If the tightening is interrupted just before the final torque is reached, the bolt will not be fully tightened when the torque wrench is taken to the set torque.. As soon as the tightening stops, the friction increases greatly before the bolt starts to move further. This is why it is common for taking some heads down to a lower torque, and then finishing by turning through a predetermined angle. On some older engines, the head was retightened after running to working temperature and then cooling. Then the way to retighten, was to slacken off each bolt, one at a time, before final tightening in the original sequence, to eliminate the "stiction". It is important to adhere to instructions regarding lubrication, or not.
One of the jobs at work was to bolt together the propeller hubs of C130J Hercules, before final machining. The 18 threequarter inch UNF bolts were tightened with a torque wrench in a predetermined sequence to stretch them from 0.012" to 0.015". Torquing alone was not considered accurate enough.
ChrisB02/12/2019 14:35:32
537 forum posts
192 photos
Posted by Nicholas Wheeler 1 on 02/12/2019 10:09:15:
My comment was in response to the above statement. In my opinion, bolts can be installed both in tension and shear, that's all. I was not referring to the type of joint being used - I'm referring to how forces can be transmitted to a bolt.
EngineDIY
