Martin 100 | 30/11/2019 19:50:00 |
274 forum posts 6 photos | I've both MEW and ME print and digital subscriptions, both obtained through the subscribe link above with expiry towards the end of 2020 Both subs numbers are entered in my settings After logging in to pocketmags and entering the appropriate subs numbers I can access current editions of both magazines Using the magazines link above it only lists my MEW subscription and after clicking the link I can access the MEW archive. I've tried tried on both firefox and chrome, on W7 and W10 and the magazines page is identical, always showing a link to just the MEW archive and not both mags. Emails to help@me.secureorder.co.uk have failed to elicit a response to my problem. The ME subscription was originally ordered as a print sub but has since been amended after discussion with help@me.secureorder.co.uk to a print and digital sub. The subscriptions page at https://me.secureorder.co.uk/index.php? shows what appears to be a current print and digital subscription to both mags
Neil Wyatt | 30/11/2019 20:08:00 |
![]() Moderator 19033 forum posts 734 photos 80 articles | Hi Martin, I've investigated, which will have logged you off. It seems that the ME subs number in your profile is correct and should allow access to the archive. As you state the system is only offering access to MEW. The subs company have no access to this system, so i will ask a colleague to investigate, but I'm afraid they won't be available until Monday. Thanks for your patience. Neil |
Neil Wyatt | 30/11/2019 20:19:48 |
![]() Moderator 19033 forum posts 734 photos 80 articles | Hi Martin, I think there may have been a 'hidden character' in the field where your subs number was entered into your profile. I deleted it and re-entered it and I was then able to view the ME archive by emulating your account. This may have happened if you tried to copy and paste the number or it might just be 'one of those things'. Please try viewing the archive (note you will need to log back in) and report back. Thanks Neil
JasonB | 30/11/2019 20:20:50 |
![]() Moderator 22751 forum posts 2653 photos 1 articles | Either Neil has worked some magic or I did something but looks like you should be able to access the archive now as I was just able to under your name. EDIT, Looks like we were both looking at it at the same time and Neil found the problem Edited By JasonB on 30/11/2019 20:21:42 |
Martin 100 | 30/11/2019 21:07:26 |
274 forum posts 6 photos | Many thanks Neil & Jason now all working. I did indeed just cut and paste direct from the subscription notification email and expected it to just 'work' |
Neil Wyatt | 01/12/2019 15:07:14 |
![]() Moderator 19033 forum posts 734 photos 80 articles | Posted by Martin 100 on 30/11/2019 21:07:26:
Many thanks Neil & Jason now all working. I did indeed just cut and paste direct from the subscription notification email and expected it to just 'work' I think you may have picked up a space as well as the number, but that's just a hunch! Neil |
Enough! | 01/12/2019 19:08:46 |
1719 forum posts 1 photos | Posted by Martin 100 on 30/11/2019 21:07:26:
That said, I've always found Windows (if that's what you're using) to be a bit of a pain when it comes to selecting text by dragging the mouse. It will frequently pick up leading or trailing spaces, to the extent that it seems more likely to do that than not. (Or even the preceding or following whole-lines). All very finicky. |
