centec 2a riser
geoff adams24/11/2019 14:18:59
133 forum posts
144 photos
img_0999.jpgimg_1003.jpgimg_0999.jpgimg_0991.jpgbought this machine 3 weeks ago little bit more sturdy than my chester champion made the riser block gives lot more room between table and cutter it has a power feed table but two gear wheels are missing to change the feed rate what i have got will do for now it also came with the horizontal attachment made in 1957 year i was born
i now have a boxford lathe ajax horizontal mill a meddings pillar drill all made around the 1950s all still going strong sorry pics wrong way round no idea how to fix
Geoff
old mart24/11/2019 14:33:41
992 forum posts
106 photos
That's a big chunk of aluminium, it looks like you could slide the top and bottom forward to give a couple of inches more throat if required, although the belt drive might not allow it without some redesign.
geoff adams24/11/2019 14:50:08
133 forum posts
144 photos
the alloy came from Allco Southampton only place near me that could do the size i needed most of the machining was done on my tormach cnc mill there is a member on the forum that gave me the idea he made a longer version so you can slide it forward with the vertical head still on and then use horizontal attachment as i have a horizontal mill and no room behind i stuck with the short version still very pleased
Geoff
peak424/11/2019 16:55:09
958 forum posts
89 photos
Do let us know if you decide to go into production. smiley
Bill
not done it yet24/11/2019 20:38:58
3797 forum posts
15 photos
I have a long riser with my 2B (made by Gary, I think), but there would be several who would like to extend the working head-space on their Centecs if previous threads are anything to go by.
The long version is definitely the favoured version if the space is available.
Mine has a VFD (220V output) running the power feed. I think the motor is still in star configuration, but it still seems to cope OK. I’ve yet to bother with the alternative gearing.
mid gard rail Jan 2020
