WM16B DRO - 2 or 3 axis?
Bluesbreaker23/11/2019 13:33:32
3 forum posts
Hi all - first post though I have been lurking round here for a while!
I'm fairly new to the ME hobby, and have recently acquired a Warco WM16B milling machine.
I'm considering fitting a DRO kit from M-DRO - given that the mill already has an inbuilt digital display provided for the quill feed, are there any advantages in fitting a Z-axis sensor and 3-axis DRO, or does experience suggest that the type of z-axis display fitted to chinese mills of this level will be adequate? Is it simply a question of deciding what level of accuracy I can live with?
Enough!23/11/2019 16:58:44
1719 forum posts
When I fitted DRO's to my WM16 lookalike I fitted one to the z-axis. It's so long ago that I don't remember the details but it seems to me that the existing readout didn't truly read the absolute position of the quill but rather linked to the quill adjustment gearing somewhere - at least part of which was a friction drive.
Others may have a better clue on this and later machines might be different in this respect.
It wasn't trivial fitting the DRO to the z-axis (although quite do-able).
David George 123/11/2019 19:06:26
1721 forum posts
500 photos
Hi welcome to the forum. I have fitted an M-DRO 3 axis to my V16 mill and wouldn't be without the 3rd axis.
David
Dave Smith 1423/11/2019 20:10:03
208 forum posts
40 photos
The fitted quill DRO only reads to two decimal places, which I found limiting, so I fitted optical DRO's to the x,y and replaced the Warco Quill. If you fit a 3 axis read out and you can always decide later to do either the quill or Z
Dave.
Enough!23/11/2019 23:01:22
1719 forum posts
Dave's post, differentiating between the quill and the z-axis made me realise I my post above is confused. To be clear, the DRO scale I fitted to mine was on the quill not the z-axis as I stated.
Bluesbreaker24/11/2019 21:13:21
3 forum posts
Thanks for all your replies and advice. I think I'll aim for a kit with a 3-axis display, and then I have the option to fit the Z-axis later on as Dave suggests.
rapid Direct
MIDLNDS GARDEN RAIL Jan 2022
JD Metals
