"Genuine" Myford 30/12 Fine Feed Tumbler Gear
Nick Hulme | 23/11/2019 01:26:34 |
750 forum posts 37 photos | I bought a 30/12 Fine Feed Tumbler Gear bought from the new Myford Ltd and fitted it to a genuine Nottingham Myford Super 7 with genuine Nottingham Myford change gears and genuine Nottingham Myford idler gears. |
Graham Stoppani | 23/11/2019 05:53:24 |
![]() 120 forum posts 26 photos | Had a similar experience with ML7 gears from RDG a few years back. |
Pete Rimmer | 23/11/2019 07:12:32 |
1219 forum posts 63 photos | A couple of the people I made 33/34 gears for commented on this also. |
Georgineer | 23/11/2019 11:36:14 |
564 forum posts 32 photos | Have you told Myford about the problem?
peak4 | 23/11/2019 14:52:49 |
![]() 1675 forum posts 179 photos | Posted by Nick Hulme on 23/11/2019 01:26:34:
My original Nottingham Myford fine feed cluster also has a plain bore, though the normal driver, where you can change the output gear, as you say has the needle roller and bronze bush. Bill |
Nick Hulme | 24/11/2019 13:20:25 |
750 forum posts 37 photos | Posted by Georgineer on 23/11/2019 11:36:14:
I considered it but what are they going to do, start checking products which they have not bothered to check so far and scrap the rejects or sell them anyway and expect a certain level of returns and for the other users to put up with shoddy products with a "Genuine Myford" sticker on them? |
Bazyle | 24/11/2019 13:32:13 |
![]() 6296 forum posts 222 photos | You should be telling Myford and demanding a guaranteed fit for purpose replacement within 5 working days. They do need to check every item they have in stock and have it reworked or remade by a local British company to ensure the quick turnaround. They will also need to be taking it up with their supplier and suing for all costs, including yours. This is what we do in equivalent circumstances although a different kind of industry. |
not done it yet | 24/11/2019 13:50:14 |
6734 forum posts 20 photos | We don’t actually know what their QC policy is. It may be quite stringent but this is a ‘one in a lot’ that has got past the inspection. In that case they would replace it immediately. On the other hand they may simply replace the faulty ones found by purchasers, with no QC checks by themselves. Not so good as there may be a lot of shoddy ones supplied to them by shoddy manufacturers. The worst scenario is one of couldn’t care less and no replacement until proven faulty on return of the product at the buyer’s expense. Not such a good system for retaining custom. |
Bazyle | 24/11/2019 17:11:12 |
![]() 6296 forum posts 222 photos | Are any of our suppliers ISO9000 compliant? I would imagine companies like Boxford, original Myford, Colchester were but are any of the current main traders? |
Michael Gilligan | 24/11/2019 17:53:37 |
![]() 20081 forum posts 1041 photos | I was ‘somewhat surprised’ to read this, on Cyclex : ”We opened our doors before ‘Modern Britain’ began and waited as two World Wars made demands upon UK manufacturing. It controlled our workforce and our output but it didn’t change our belief in standards or our pursuit of quality and reliability.” So it would appear that the good folks at Mytholmroyd are asserting ‘continuity’ from the Beeston operation. MichaelG. . Ref. : https://mytholmroyd.cylex-uk.co.uk/company/myford-ltd-12921164.html Edited By Michael Gilligan on 24/11/2019 17:54:13 |
duncan webster | 24/11/2019 18:16:39 |
3927 forum posts 61 photos | I bought 2 off 50t 'myford' gears fro RDG a few years ago, the idea being to have 60/40 or 50/50 without moving the changewheel studs. The 60/40 came with the lathe from Beeston Myford many moons ago, and I presume are good, so I used them to set the centres. The 50/50 had huge backlash, back to RDG for immediate no questions refund, and bought a pair from Beeston Myford. Seems like then at least they were relying on the customer to do the inspection. |
Mark Rand | 24/11/2019 22:11:47 |
1238 forum posts 28 photos | I'm assuming that RDG didn't buy Myford's gear shaper at the auction... |
Dave Wootton | 25/11/2019 21:32:50 |
290 forum posts 65 photos | Very interested to see this post as within the last month I have been through a saga with these Myford fine feed gears. I bought one from Myford via Ebay for my ML7R , when it turned up the bore was tapered and would only fit on the shaft for about a third of its length, trying with a piece of silver steel confirmed that the bore was tapered rather than any fault with the shaft, after a few exchanges of messages I returned it. After a number of days of hearing nothing I had to send an inquiry as to what was going on as far as a replacement was concerned, followed by a phone call. The impression I was given on the phone was that this was a rare occurrence and was I sure the fault was not with my machine. A new gear was sent which fitted the shaft, but ran out so badly that it would only revolve half a turn, to use it would I feel have stripped the fibre gears. At this I gave up and returned it via the Ebay returns scheme, and received a paypal refund. I bought a secondhand gear off ebay which was cheaper and fitted perfectly. Very disappointed that such poor quality items are being sold under the Myford name, I suppose I could have fettled the second gear sent, but at just less than £40, why should I have to? At the same time I bought two changewheels for my Colchester Bantam from RDG, these needed a bit of fettling to remove burrs, but they did fit ok and run true and mesh well. They were very cheap, much less than used ones go for, so I didn't mind doing a little work on them. As ever you get what you pay for, but if you pay genuine article prices, I believe some quality control should be carried out before sending out. Dave W
Michael Gilligan | 25/11/2019 22:03:49 |
![]() 20081 forum posts 1041 photos | We should probably distinguish between RDG Tools Ltd. and Myford Ltd. ... Although some of the same people are involved in both businesses, I understand that they are separate limited companies and ‘ring-fenced’. MichaelG. [ please correct me if you know better ] |
peak4 | 26/11/2019 00:00:23 |
![]() 1675 forum posts 179 photos | Posted by Michael Gilligan on 25/11/2019 22:03:49:
We should probably distinguish between RDG Tools Ltd. and Myford Ltd. ... Although some of the same people are involved in both businesses, I understand that they are separate limited companies and ‘ring-fenced’. MichaelG. [ please correct me if you know better ] There's also RDG Tools online Ltd, which seems to be a different company again. Bill |
Michael Gilligan | 26/11/2019 00:07:16 |
![]() 20081 forum posts 1041 photos | That’s interesting, Bill ... thanks Interesting but not at all unreasonable, I hasten to add. MichaelG. . Edit: curiously, RDG Tools Ltd. appears not to be listed at Companies House ... so presumably it’s just an abbreviation of RDG Tools online Ltd. Ref. https://www.rdgtools.co.uk/cgi-bin/mf000001.pl?ACTION=SHOWFORM Edited By Michael Gilligan on 26/11/2019 00:26:39 |
Dave Wootton | 26/11/2019 08:19:15 |
290 forum posts 65 photos | Sorry if I gave the impression in my above post that I thought RDG and Myford were the same vendors I got the gears from, they were of course entirely separate transactions. I just wanted to illustrate that expectations of quality differ between vendors, and of course reflect in the price paid. Sadly as a long term Myford user I do believe not done it yet has hit the nail on the head in his post and that Nick and I did not just get a bad one out of the batch, but the QC is left to the customer. In fairness I should say that other parts bought from Myford since the change of ownership have been fine, and hope this is a one off. Dave
Michael Gilligan | 26/11/2019 08:40:24 |
![]() 20081 forum posts 1041 photos | Posted by Dave Wootton on 26/11/2019 08:19:15:
Sorry if I gave the impression in my above post that I thought RDG and Myford were the same vendors […]
. … and please accept my apologies, Dave; if it seemed that my comment was directed at you. It was simply a broad observation, prompted by having seen such conflation several times in the past. MichaelG. |
ega | 26/11/2019 10:21:59 |
2498 forum posts 200 photos | Posted by Bazyle on 24/11/2019 17:11:12:
Are any of our suppliers ISO9000 compliant? I would imagine companies like Boxford, original Myford, Colchester were but are any of the current main traders? I admit I haven't perused ISO 9000 or any of its derivatives lately but experience years ago suggested that the certifying body was more interested in whether you were complying with your own rules than the absolute merit of how you went about your business. So if your system required checking one in ten thousand products and you did so, and documented the fact, you were compliant |
Mike Poole | 26/11/2019 10:36:05 |
![]() Moderator 3305 forum posts 73 photos | It seems to me that ISO9000 does consist of declare what you do and keep records of it, I am sure there must be more to it than that but that is the impression I get. Mike |
