Hello from the Lake District
Mark Eden 117/11/2019 11:52:16
3 forum posts
Hi all, I'm a recently early retired mechanical engineer having spent almost 31 years with Ford Motor Company designing and developing engines (I was Chief Engineer for the DuraTorque range of diesel engines for many years). My workshop is almost exclusively woodwork based at present but I've found a corner in which my late fathers lathe can fit and intend to get back into metalwork after many years (my father taught metalwork at secondary school in the 60-70's and taught me as a teenager). The lathe is a Myford (Drummond) M Series long bed that my Dad reclaimed from a skip and rebuilt in the early 1970's. I'll post some pictures once I work out how to do so. I'd love to hear from anyone else out there who has one as they isn't much info on them I can find. Cheers,
Mark
Nick M0NPH17/11/2019 21:41:08
24 forum posts
Hello and welcome i don't have a Drummond lathe but have a look hear
http://www.lathes.co.uk/drummond-m-type-post-1924/
Nick M0NPH
Edited By Nick M0NPH on 17/11/2019 21:41:59
JohnF17/11/2019 21:44:01
1145 forum posts
188 photos
Hello Mark and welcome to the forum, lots of interesting questions and answers on here ! I am sort of "local" to you in the Lune valley near Lancaster.
David George 117/11/2019 22:13:06
1807 forum posts
503 photos
Hi Mark welcome to the forum I have an M Type and if you need any information just ask. Pictures help if you can, to sort out problems. What sort of things are you interested in.
David
Edited By David George 1 on 17/11/2019 22:16:38
David Noble18/11/2019 08:33:36
308 forum posts
15 photos
Hello Mark, there is a lot of help available on the forum. What aspect of engineering interests you?
David
Mark Eden 118/11/2019 20:10:59
3 forum posts
Thank you all for your kind words. Great to have joined such a friendly and knowledgable group! I've got some small bits and pieces lined up mainly jig type fixtures for woodworking. However I expect to try my hand at something more substantial once I've got to grips with the M Type, at which point I'll no doubt come back looking for advice. The only question I have right now (David) is whether you have managed to acquire or make a quick change tool post? The standard "Norman Patent" design I recall being very fiddly to get the correct tool height. Thanks again for the warm welcome.
Mark
Nigel Rice18/11/2019 20:24:09
12 forum posts
Welcome to the forum Mark. I live in Kendal and have established my workshop behind my house. I have an Aciera F3 mill and have just installed my pride and joy, a Hardinge HLV lathe. You are welcome to call in.
Nigel
David George 118/11/2019 22:59:34
1807 forum posts
503 photos
I removed the old tool post and machined a diamiter to suit location on toolpost then drilled and tapped for bolt.
David
Mark Eden 119/11/2019 09:02:34
3 forum posts
Thanks David, your mod looks exactly what I need although not sure how to get over the hurdle of needing to machine the machine that machines? What was your solution? Did your post look like the attached? It looks like its threaded 1/2"BSW so not compatible with your M10 fixings?
Nigel Rice19/11/2019 11:24:44
12 forum posts
Posted by Mark Eden 1 on 19/11/2019 09:02:34:
Mark
A possible solution would be to find someone locally with suitable machines! How local is Kendal to you?
Nigel
David George 119/11/2019 13:27:22
1807 forum posts
503 photos
My lathe was just like yours and the post was only drilled part way down. I just hacksawed the post down and got a friend to machine the post base and tap the hole through. The hole in the toolpost was smaller than the location diamiter so he also milled that to size for me.
David
Neil Wyatt19/11/2019 19:21:45
18990 forum posts
734 photos
80 articles
Welcome to the forum Mark,
Dreweatts
Rapid RC
