Mitutoyo DRO Fault
Stuart Bridger17/11/2019 20:34:49
434 forum posts
25 photos
That's a shame but probably a symptom of the age of the unit. I would make sure everything is seated firmly and give the cables a wiggle. Other than that it is probably time to cut your losses and get a new console. Machine DRO offer adapter cables for Mitutoyo scales, to connect into current products. They do recommend speaking to them for compatibility.
Brian H17/11/2019 22:20:23
1637 forum posts
108 photos
Posted by Ian P on 17/11/2019 19:37:58:
Posted by Brian H on 17/11/2019 19:04:15:
Ah well, all this swapping of plugs and amplifiers has resulted in the one that WAS working, now isn't!
Brian
That really clarifies things.
The 'one' what?
Ian P
I thought that it was obvious; the display that was working now isn't. In other words both displays do not move when handles are turned.
Brian
Nick Hughes17/11/2019 22:39:45
221 forum posts
132 photos
If you want to retain your original readout, contact Darren at Goodwin Technology, to see if they could repair it.
Goodwin Technology
Brian H18/11/2019 08:44:10
1637 forum posts
108 photos
Thanks for that Nick I may well give them a call, but first I,m going the check the wires in the armoured cables as I know some of the plastic in other parts of the machine are stiff and brittle and I thought that the problem might lie with broken wires and it's any easy check to make.
I'm in no hurry and I'm not even sure how useful a DRO is on a horizontal mill. ( plus, I'm a miser)
Brian
Michael Gilligan18/11/2019 09:38:44
15704 forum posts
687 photos
Posted by Michael Gilligan on 16/11/2019 22:27:23:
Edit: If all else fails, it might be worth trying here
Mmm ... deja vu
Nick Hughes18/11/2019 09:51:20
221 forum posts
132 photos
Ha, I did scan through the earlier posts to see if Goodwin had been recommended, but obviously missed that part in your post.
Michael Gilligan18/11/2019 10:28:14
15704 forum posts
687 photos
No problem, Nick
It was the ‘No fix, No fee’ offering that first attracted me.
i’ve never had cause to use them, but assume that you have.
Machine-DRO18/11/2019 11:47:10
22 forum posts
25 photos
Good morning,
We do manufacture and stock adaptor cables that will suit your Mitutoyo encoders to connect with a M-DRO / Easson display unit (others consoles will also be suitable)- which will give you all the modern features of a display console while retaining the use of existing encoders
If you have any questions then please do not hesitate to contact us 01992 455921 or sales@machine-dro.co.uk
Machine-DRO team
Brian H19/11/2019 15:31:48
1637 forum posts
108 photos
Sent a message to M-DRO. I have one of their units on another machine and am very leased with it, otherwise, It's back to modelling because I'm fed up with fiddling!
Thanks to all who tried to help.
Brian
Brian H15/04/2020 19:52:21
1637 forum posts
108 photos
I'm back fiddling with this Mitutoyo DRO again!
I convinced myself that the fault MUST lie with the cables so I sent them to an electronic repair specialist (www.electronic.partners) for testing and they cannot find anything wrong!
I then decided to have a look at one of the glass scale units which labeled as "AT2-N250" with a Mitutoyo code number of "529-102-5", which I had previously cleaned using optical cleaning wipes.
There appear to be three lights and three 'receivers' for want of a better word, on opposite sides of the glass scale.
Does anyone knew if these are indeed three lights and should they light up when the unit is taken out of the track with the power switched on?
Brian
