What would you call this tool
David K11/11/2019 13:09:19
258 forum posts
259 photos
I bought this at Action a while back and don't seem to have any use for it so might sell.
Not sure what to advertise it as , it has a Parvalux geared motor so turns the chuck fairly slowly.
not done it yet11/11/2019 13:28:19
4639 forum posts
16 photos
Don’t know but it is fitted with an expensive chuck!
Ian Johnson 111/11/2019 13:32:16
263 forum posts
81 photos
Looks like a rotary 4th axis for a milling machine. The tenon locates in the tee slots of the mill bed.
Looks well made too, and the chuck looks like a grip tru type and is worth a few bob itself, is it a 3 inch or 4 inch chuck? I've got a rotary 4th axis otherwise I'd buy it off you.
Ian
Emgee11/11/2019 13:34:06
1485 forum posts
217 photos
Powered spindle including 3j SC ?" chuck mounted on a tilting and rotating table.
You need to state some dimensions such as centre height when horizontal and degrees of tilt + and -
Looks like a Grip-tru chuck which is a bonus, useful bit of kit, especially with a stepper fitted in place of the fixed speed motor.
Emgee
JasonB11/11/2019 13:41:57
18104 forum posts
1994 photos
The yellow bit looks like it was originally from a T&CG and the motor has been cobbled onto the end, chuck on a 5C? or similar mount.
Jeff Dayman11/11/2019 13:43:05
1818 forum posts
45 photos
Maybe you could call it "Powered auxiliary spindle with three jaw chuck". I think it will be no problem to sell it - those that could use it would be glad to have it. Looks like good quality stuff.
peak411/11/2019 14:01:35
1094 forum posts
124 photos
Not sure what you'd call it as it's a bit of a home brew special.
I could be interested in using it in my own workshop though, as I'd been thinking about knocking up something similar.
Bill
Brian Wood11/11/2019 14:38:22
2186 forum posts
37 photos
Possibly a positioning aid for precision welding
David K11/11/2019 14:55:39
258 forum posts
259 photos
OK interesting thoughts, thanks I will have to have a think about it now although
its probably a bit bulky for my mill.
I will make some measurements tomorrow .
mechman4811/11/2019 15:36:03
2663 forum posts
410 photos
Posted by Brian Wood on 11/11/2019 14:38:22:
My thoughts too, also consider it to be a set up to cut / grind some form of Helix angle on the mill.
George.
JohnF11/11/2019 18:25:07
981 forum posts
142 photos
I am sure Jason is spot on, very similar to the one on my Boxford T & C grinder --- try Google " tool grinder universal workhead" and look at the images. The motor does look a bit of flash up but even so may well be original ? I can see a badge on the base in the first photo - a clue here maybe ?
An Other11/11/2019 18:34:52
161 forum posts
Don't know what its for, but I have an identical Parvalux motor/gear assembly. It contains two worm drives, so the output shaft rotates very slowly. The worm drives are very good quality - the worm gears in mine seem to be chrome plated.
Edited By An Other on 11/11/2019 18:35:08
Pete Rimmer12/11/2019 08:27:36
713 forum posts
49 photos
That's a powered work head for a tool and cutter grinder. It'll fetch good money if you put it up for sale.
Martin King 212/11/2019 08:51:02
684 forum posts
260 photos
David,
You have a PM
Martin
Tony Pratt 112/11/2019 09:13:36
1124 forum posts
5 photos
Looks very like a Cincinnati T & C work head.
Tony
