On The Wire -ARC Cutter Review
Additional content to accompany the review in MEW 289
JasonB07/11/2019 16:07:33
18318 forum posts
2024 photos
Two videos and some larger photos to go with the review of the ARC Euro Trade indexable endmills and shell mills in MEW 289. Video best viewed direct on You-tube so the captions can be read more easily.
The cutters being used on Sieg X3 & SX2.7  Mostly the 63 & 80mm shell mills on a mix of cast iron, steel and aluminium.
25mm Indexable Endmill being used on Sieg KX-3. It would have taken a faster feed so a bit slow in the video, I was wary of the larger amount of engagement in the internal radii causing chatter but need not have been
Two larger photos of the finish on some unknown steel cut with the 80mm Shellmill on the SX2.7, click any image to enlarge further.
Assortment of materials cut, from L to R - Cast Iron 6082 Aluminium EN3 and unknown steel with the CNC machined 6082 part in the foreground.
Closeup of the CNC machined part
Edited By JasonB on 26/12/2019 07:25:05
JasonB26/12/2019 13:33:19
18318 forum posts
2024 photos
Just bumping this one up to the top now that I am informed that the paper mags have landed, I think whoever makes the digital one available must be on Holiday.
Ian Johnson 126/12/2019 15:37:31
274 forum posts
81 photos
Nice demo! They look like really good quality tools, as is most stuff from Arc.
I have a small 50mm dia indexable face mill, but rarely use it, mainly because I end up with the workshop full of little razor sharp swarf everywhere! I need to get myself a fully enclosed mill.
Ian
fizzy26/12/2019 17:16:16
1716 forum posts
116 photos
What spindle speed Jason? Is it likely to give the same results on a non cnc machine? Thanks.
JasonB26/12/2019 17:33:27
18318 forum posts
2024 photos
Cutting speeds are in all the captions and only the last fancy shape was on the CNC so rest done on machines with a max of 2000rpm, again machines used in captions. Cuts on the SX2.7 also show th espindle speed display
Depending on diameter the face mills were run at 600-800rpm on steel and cast iron and 1750-2000rpm on Aluminium and smaller 25mm dia one at 1750-2000rpm on steel and iron on tmanuals and 5000rpm on te hCNCto give the cutting speeds shown.
Bazyle26/12/2019 18:12:55
5292 forum posts
201 photos
Why does someone invent tooling that goes in steps giving 40mm, 50mm, 63mm, 80mm diameters? Would it have been so bad to go for 65mm?
XD 35126/12/2019 20:05:34
1430 forum posts
Posted by Bazyle on 26/12/2019 18:12:55:
Possibly a close approximation to the old 2 1/2 inch ?
Ron Laden27/12/2019 08:34:23
1972 forum posts
391 photos
Hopefully we will see the digital MEW289 today.
John Hinkley27/12/2019 09:23:54
899 forum posts
298 photos
I've had no problem viewing the digital copy of 289 on this forum and Pocketsmags on my iPad since last Saturday.
P.S.  The paper copy came on Monday!
Edited to add P.S.
Edited By John Hinkley on 27/12/2019 09:24:57
Emgee27/12/2019 09:32:59
1542 forum posts
219 photos
Jason, what is the weight of the 80mm with inserts please ?
Emgee
JasonB27/12/2019 09:51:06
18318 forum posts
2024 photos
That's odd John, although 289 shows on teh home page and at the top of all pages when I go to Magazines and select MEW they only start at 288?
Emgee, I will get back to you shortly.
Michael Topping27/12/2019 09:58:10
74 forum posts
5 photos
I bought one of the 25mm end mills, been using it on black mild steel and it works very well, good finish. The inserts seem to last quite well also.
michael
JasonB27/12/2019 10:07:55
18318 forum posts
2024 photos
80mm Head with the torx screws is just about bang on 1000g and another 70g for six inserts
Edited By JasonB on 27/12/2019 10:08:22
Ron Laden27/12/2019 10:44:28
1972 forum posts
391 photos
No I am only seeing 288 as the latest in Magazines..?
Edited By Ron Laden on 27/12/2019 10:51:25
John Hinkley27/12/2019 11:37:08
899 forum posts
298 photos
Ron/Jason,
You are both right, of course. Only on Pocketmags from Saturday. It normally appears on here the same day for me, at least, so I got confused. Easily done, these days, I'm afraid.  I'd blame it on too much mulled wine, but I'm only allowed one pint of Guinness a week due to medication! To paraphrase the old saying - "Read twice, post once!"
Happy New Year.
Spelling corrected.
Edited By John Hinkley on 27/12/2019 11:37:59
Emgee27/12/2019 12:10:32
1542 forum posts
219 photos
Jason, thanks for the weight, so 1070g is that inc the arbor or not ?
Reason i'm asking is that's very close to being too heavy for my machine, especially at 2k rpm.
Emgee
roy entwistle27/12/2019 12:27:43
1190 forum posts
XD351 wrote Possibly a close approximation to the old 2 1/2 inch ?
It's possibly a close approximation to the current 2 1/2 inch as well
Roy cheeky
JasonB27/12/2019 13:37:25
18318 forum posts
2024 photos
Emgee, without arbor. What do you have I can weigh MT3 & R8
Emgee27/12/2019 16:05:10
1542 forum posts
219 photos
Thanks Jason but I can add the weight of a BT30 arbor.
Nice surface finish on all those pieces, good demo's.
Emgee
Andrew Johnston29/12/2019 10:54:04
5556 forum posts
650 photos
I just tried ordering some indexible bodies and arbors from Arc. Both R8 and ISO40 arbors are out of stock, with no restock date. Seems pointless to review items that one can't buy. sad
EngineDIY
