Source of Stainless Strip
Neil Wyatt06/11/2019 11:39:54
18241 forum posts
714 photos
77 articles
I have found a source of 20mm x 0.5mm half-hard stainless strip
In an ideal world I could do with 19mm x 0.6mm although the width isn't critical.
Can anyone suggest a source - I can only find carbon steel in 0.6mm and it's long coils.
To make four of these:
Fowlers Fury06/11/2019 11:59:58
351 forum posts
78 photos
Though not for identical dimensions, when needing similar strips of s/s I've purchased a set of feeler gauges.
Cheap enough and seem pretty tough.
Martin Kyte06/11/2019 12:07:00
2066 forum posts
37 photos
Stainless hose clips maybe?
regards Martin
Speedy Builder506/11/2019 12:11:02
2109 forum posts
146 photos
stainless strapping as used around lamp posts etc for attaching signs ??
Hopper06/11/2019 12:19:13
4817 forum posts
105 photos
Can you cut strips from a piece of .6 sheet? Those new thin cutting discs about 1mm thick for a 4" angle grinder work a treat for that kind of thing.
peak406/11/2019 12:47:33
1203 forum posts
143 photos
Maybe find someone who makes bandsaw blades for butchers, and blag a short length; they are likely to be stainless strip.
Bill
David George 106/11/2019 13:13:33
1342 forum posts
448 photos
There is a local supplier Nefco within walking distance. They will cut a strip of the correct width from a sheet. It comes in polished and brushed Finnish.
David
Neil Wyatt06/11/2019 14:20:47
18241 forum posts
714 photos
77 articles
Thanks folks, I'd like polished if possible. I'm rapidly thinking the best idea might be to pop in The Range with a digital caliper and take a look in the kitchen supplies section
Mike Poole06/11/2019 16:24:40
2748 forum posts
64 photos
Have PM,d you Neil.
Grenville Hunt06/11/2019 16:26:24
23 forum posts
What about s/steel banding used by packaging companies for pallets
Gren.
Ian P06/11/2019 17:11:40
2420 forum posts
101 photos
I've not heard of SS being specified as Half-Hard but from the description I presume you are looking for springiness as a characteristic feature.
Nowhere near the size you mention but I have a more than ample supply of 'flat' SS spring wire. It is 2.5mm wide and 0.7mm thick with rounded edges, I have lost the Certificate of Conformity that gave its metalurgical content but you are welcome to have some if you could use it, it might mean changing your design but several strips could be fixed side by side etc.
Ian P
EngineDIY
