Changing a Motor from Star to Delta
Brian H04/11/2019 18:07:37
1637 forum posts
108 photos
I'm hoping that one (or more) of our electrical boffins can help me with this one.
I have done this task successfully where there have been links to remove and replace but I've now come across a different system.
The motor is a Brook Crompton Parkinson 1.5kw one and normally sits in the base of a Tom Senior Major Mk 2 ELTmilling machinel.
I eventually managed to remove the motor which has a plate stating that is is 220/380-420 volts and alongside this are the Delta & Star symbols.
When I opened up the junction box on the motor I found 4 terminals plus earth.
3 of the terminals were for the individual phases with one black wire to each from inside the motor.
The other terminal had 3 black wires from inside the motor all connected to the one terminal.
I have a 240v 3 phase inverter rated at 1.5kw, how do I connect it to the motor?
Any help will be most welcome!
John Haine04/11/2019 18:18:30
3080 forum posts
162 photos
Aha! You need to...
  • remove the 3 black wires from the common terminal
  • don't remove any of the other wires!
  • identify which of the wires you just removed are the other ends of the connections to the other terminals. Suppose the other terminals were 1a, 2a, 3a, they would be 1b, 2b, 3b.
  • connect 1b to 2a, 2b to 3a, 3b to 1a
  • You're done.
Emgee04/11/2019 18:28:31
1485 forum posts
217 photos
The 3 black wires on the same terminal will be the ends of the windings, if there are no markings at all you will have to identify the pairs of windings so you can connect in delta mode.
If you have an ohm meter you can remove the 3 wires and separate the ends, then check across the end of 1 and find it's mate still connected on the terminal block, mark the 2 with some number so you know they are a coil.
Do the same again with 1 of the other 2 free ends, then check the remaining 1 just to be certain you have 3 coils, all coils should be the same resistance within a few ohms.
If someone doesn't beat me to it I will post a drawing on further connections and links.
Emgee
John beat me to it again so follow his advice.
Edited By Emgee on 04/11/2019 18:29:52
Brian H04/11/2019 19:37:04
1637 forum posts
108 photos
Many thanks John & Emgee. I've now cleaned the areas and can see that there are tags on the wires.
The wires on the individual terminals are marked U1, V1 & W1. The 3 wires on the other terminal are marked U2, V2 & W2.
I have dismantled the motor further and found that the bearing just behind the pulley is siezed and have removed this. It is marked 6205Z which I know is an easily obtained one. I'm assuming that the other bearing will be the same but will remove the nylon fan and end cover to check. Any suggestions on removing these without damage?
noel shelley04/11/2019 19:41:55
92 forum posts
Hi Brian, I may be telling you what you already know but To reverse the rotation just swap any two incoming phases. Though if your using an inverter then this may not be needed.
Good luck, Noel.
noel shelley04/11/2019 19:45:16
92 forum posts
And then-- When ordering the bearings tell the supplier that there for an electric motor and likely will be C3 fit.
Noel.
Brian H04/11/2019 20:02:44
1637 forum posts
108 photos
Many thanks Noel, yes, I knew about swapping 2 wires and the bearings I've ordered are C3 but I'm very grateful to you for replying.
Brian H04/11/2019 22:22:37
1637 forum posts
108 photos
Just to confirm that I have understood correctly.....do I then connect each of the phases from the inverter to the same terminals that I connect both ends of the coils to?
Vic04/11/2019 23:13:47
2500 forum posts
14 photos
I had a Brook Crompton three phase motor on my Elliot Omnimill and after rewiring from star to delta I ran it on single phase with just a capacitor between two of the phases. You only get about 80% of the rated power but I never noticed the mill struggle.
Emgee04/11/2019 23:48:10
1485 forum posts
217 photos
U1, V1 and W1, the original terminals that were connected,
ignore the lettering on the 2's you removed from the other terminal.
Emgee
peak405/11/2019 02:00:22
1094 forum posts
124 photos
Posted by Emgee on 04/11/2019 23:48:10:
Emgee
Emgee, I'm not quite sure what you meant to say there, but I'm not sure it came out right in print.
3 individual windings U, V, & W, each with ends 1&2 and all end 2s currently commoned together in Star formation.
To transform to Mesh (i.e. Delta), whilst still maintaining the correct orientation of each coil, as follows.
Leave U1, V1, & W1 where they are, U2 goes on top of V1, V2 on top of W1, and W2 on top of U1
The three phases go to each of the three terminals ( which now have 2 wires on each one)
To reverse the motor, swap any two phases (not windings)
Bill
Bill
Emgee05/11/2019 08:10:50
1485 forum posts
217 photos
Sorry Bill, I apolpgise for my bad description, yes you only have 3 terminals and 3 incoming wires to connect so 1 phase on each is the only option.
As said for reversing swap any 2 supply cables, no doubt easier to do at the VFD.
Emgee
Brian H05/11/2019 08:58:43
1637 forum posts
108 photos
So, please excuse me for being pedantic but;
Quote Leave U1, V1, & W1 where they are, U2 goes on top of V1, V2 on top of W1, and W2 on top of U1
The three phases go to each of the three terminals ( which now have 2 wires on each one) End of quote
So the end of one coil is connected to the start of the next coil?
Micky T05/11/2019 09:26:48
56 forum posts
29 photos
Hi Brian that is correct the end of one coil is connected to the start of the next
Mickyt
Brian H05/11/2019 10:14:52
1637 forum posts
108 photos
Thanks for clarifying Mickey, and thanks to all who replied.
Wonderful Forum this!
not done it yet05/11/2019 10:24:53
4631 forum posts
16 photos
One can consider it as connecting them in series, but being careful that each coil is pulling in the same direction as the others. What one does not want is one coil connected such that it is opposing the the other two!
Mike Poole05/11/2019 13:41:51
2572 forum posts
60 photos
A picture can be worth a thousand words.
Edited By Mike Poole on 05/11/2019 13:42:06
Brian H05/11/2019 14:51:54
1637 forum posts
108 photos
Many thanks Mike, that very helpful.
Emgee05/11/2019 16:18:37
1485 forum posts
217 photos
Brian, nice clear detail in Mike's picture, are you up and running now ?
Emgee
Brian Oldford05/11/2019 17:27:27
649 forum posts
15 photos
Posted by not done it yet on 05/11/2019 10:24:53:
Been there, done that.frown Eventually sorted it out.
Edited By Brian Oldford on 05/11/2019 17:27:56
