Polishing Acetal/Delrin and other plastics
Mike Donnerstag01/11/2019 18:38:42
170 forum posts
35 photos
Can anyone tell me the best way to polish plastics such as acetal once hand-turned in the lathe? I'm just turning some knobs for the Myford lathe.
Many thanks,
Ian Welford01/11/2019 18:51:58
289 forum posts
sand it from 180 grit through to 600 preferably with steam ate lubricated paper or ABRANET at slow speed in the lathe .Then wet sand with wet n dry upto about 1200 grit, follow with metal polish eg t cut if you want a really gloss finish.
doesnt take long with each grit but wipe the work between grits with. damp paper towel to remove dust and possible grit parictles before using the next grit.
Mike Donnerstag01/11/2019 19:05:37
170 forum posts
35 photos
Many thanks Ian. Just the advice I needed. I’ll give it a try.
JasonB01/11/2019 19:45:28
18098 forum posts
1993 photos
I use Micro-Mesh to finish Clear acrylic to a glass clear finish.
As turned
Polished inside and out
Edited By JasonB on 01/11/2019 19:50:24
Ian P01/11/2019 20:03:55
2380 forum posts
100 photos
A lot of plastics like, acrylics (Perspex) and hard PVC are easy to polish, some like Acetal (Delrin) are more of a challenge and probably near impossible. I machine a lot of parts out of black Acetal and have not found any practical way of making even a very fine machining marks disappear.
Jason, the ER collet in your pictures look a tad unusual in that the gaps between the tines look unequal, is it just an optical illusion?
Ian P
JasonB01/11/2019 20:14:38
18098 forum posts
1993 photos
Ian, I think it is just teh angle of the photo, will check tomorrow and report back if it is something else.
I wonder if flame or chemical polishing would work one some of these plastics like it does with perspex
Alan Wood 401/11/2019 20:46:29
141 forum posts
6 photos
Slightly relevant but Polywatch is a compound for polishing scratches out of watch faces and is particularly good. It appears to fuse the material over the blemishes. Think it is on Amazon.
Ian P01/11/2019 20:50:15
2380 forum posts
100 photos
Acetal is quite a low friction slippery material a bit like PTFE, filing or abrading with even the finest wet and dry just leave a matt, white-ish surface. I'm not sure what temperature it melts at but I have never heard of it being flame polished.
Most, maybe its all, commercially manufactured Acetal components have visible signs of the machining so I have just assumed its not economic or possible to polish.
Ian P
Derek Lane01/11/2019 20:56:45
324 forum posts
73 photos
Like Jason I use micro mesh to 12,000 grit sanded wet, also another method I have used is sand with wet and dry to 1200 grit and then apply burnishing cream. I get a good result with either method.
I have heard of people using T Cut to polish as well as brasso
This is one done with micro mesh
Edited By Derek Lane on 01/11/2019 20:57:38
Edited By Derek Lane on 01/11/2019 20:59:07
Cornish Jack01/11/2019 20:59:20
1120 forum posts
159 photos
Final gloss finish using Jeweller's rouge, perhaps? or, for cheapskates like me , toothpaste. Won't do for anything other than the very fine stage. Use to use it for watch glasses.
rgds
Bill
Paul Lousick01/11/2019 21:59:33
1408 forum posts
540 photos
Toothpaste is a fine abrasive and often suggested for cleaning and polishing the outer glass on car head lights.
Paul.
Mick B101/11/2019 22:15:47
1575 forum posts
84 photos
I've been machining black and white acetal for years and it's never occurred to me to polish it - I've always thought the machined surfaces looked fine. If the tool's sharp and nicely stoned on the edge, you can get a very attractive finish.
Edited By Mick B1 on 01/11/2019 22:16:16
Sam Stones01/11/2019 22:21:30
740 forum posts
296 photos
The two basic families of materials being discussed here are either crystalline or amorphous.
I'd like to suggest (although I haven't tried), that polishing items of crystalline materials, e.g. polyacetal, Nylon, polyethylene, polypropylene, etc. need to be deep frozen, or at least taken below their glass transition temperature.
I have machined (trued up) with some success, polyester (rubber) skate wheels directly from the freezer.
I also question, during the abrasion and polishing, if the surface of crystalline materials is being continually 'pulled apart', thus introducing (let me call it), a broken surface. Someone with good microscopy (and photographic) skills might like to intervene here.
Acrylic, and other amorphous materials on the other hand, are (generally) a breeze to polish.
Good luck,
Sam
Ian Johnson 101/11/2019 23:12:30
262 forum posts
81 photos
Try flame polishing with a Butane/Propane torch, just waft it carefully over the surface and it will leave a very pleasant looking satin/gloss finish. It also has the effect of making the surface more 'tactile', so knobs are ideal for this technique as all the edges are smoothed over and machining marks are erased. I've had good results with black Acetal but don't linger with the flame or it will melt, burn or bubble.
Ian
Sam Stones02/11/2019 00:05:21
740 forum posts
296 photos
And ... don't sniff the smoke if you happen to overdo the flame treatment of polyacetal. You'll know why (and never forget) if you do.
Other than this (after a bit of practice on something which doesn't matter), I'd go along with Ian's 'flame polishing'.
It's also a useful (actually a commercial) technique for oxydising (oxidizing US) the surface of a crystalline polymer (plastic) prior to painting.
Incidentally, there are many grades of amorphous plastics which are blended or otherwise modified with other materials, rendering them less polish-able (Ugh!)
Sam
Play safe
Ian Johnson 102/11/2019 01:17:15
262 forum posts
81 photos
Here's a mobile phone holder with a fluted screw I made a few months ago. It's made from black Acetal, and flame polished. Although some machining marks are visible because of the hand ground ball cutter, I think it looks pretty good, and it feels nice to hold, it's weird how Acetal feels different after flame polishing.
Oh and like Sam says don't breath in the fumes if it starts burning, it's probably Phosgene or something equally horrid!
Ian
Sam Stones02/11/2019 01:47:32
740 forum posts
296 photos
Nice work Ian, and I trust you didn't mind my interjection re the fumes. I'm no chemist, but I think burning POM liberates formaldehyde.
Compared with nylon and polypropylene, I much preferred machining p.acetal.
Sam
Sam Stones02/11/2019 02:02:12
740 forum posts
296 photos
I didn't have this picture loaded in my albums, hence this delayed follow up.
This device for testing rotary switches features various uses of polyacetal. Black for bearings, and I think there's a slab of white with all those 'spikes' poking through. It may however have been high density polyethylene but I can't remember.
Sam
Circlip02/11/2019 09:24:37
1101 forum posts
For Acrylics, solvent vapour polishing works.
Regards Ian.
Ian Welford02/11/2019 10:09:43
289 forum posts
I have the micromesh system and use it but for making a few knobs it seemed a bit OTT so hence the advice given. It shou”d have said STEARATE lubricated paper, fingers faster than brain as usual !
Circlip, I have no ever heard of sovent vapour polishing, please elaborate on that one !
regards Ian
