Brass sheet
John Hilton23/10/2019 22:08:47
113 forum posts
22 photos
I am now starting the tender for 3.1/2 gauge County Carlow.
The plans specify 18g brass sheet, and the sides are made from 20 inch lengths.
So can anyone suggest a supplier I might try. All my usual sources seem to stop at 12 inch lengths.
Very many thanks
Baz23/10/2019 22:21:37
374 forum posts
Pretty sure GLR will do 24 inch lengths but not on their website, you may have to phone and ask.
Rockingdodge23/10/2019 22:25:35
210 forum posts
35 photos
Try M-Machine at m-machine-metals.co.uk, they price by the foot but will cut to your requirements and charge accordingly.
Roger
Adam Mara24/10/2019 09:18:54
103 forum posts
I might be able to help if your are unsuccesful in obtaining elsewhere. My son is an engraver and uses 600mm x 1200mm engraving brass sheets for solicitors signs and similar. I know he uses 1.5mm or thicker normally, but I think there may be 1.0mm or 0.9mm. PM me if you are interested, I'm on holiday in deepest Dorset at the moment, and won't be in touch with him until the weekend!
Neil Wyatt24/10/2019 09:51:15
17876 forum posts
705 photos
77 articles
I made the platework for Southam from the remains of a meter square brass sheet that was quite light gauge, so definitely available.
D.A.Godley24/10/2019 15:32:46
99 forum posts
37 photos
I am sure you will find what you require if you talk to ; John Keatley (Metals ) Ltd , Shadwell St , Birmingham ,
B4 6HD 0121 236 4300. www.johnkeatlymetals.com .
I have no connection other than that of a satisfied customer .
roy entwistle24/10/2019 16:36:04
1172 forum posts
If you you need to bend it, engraving brass is not suitable, it will crack
Roy
Kevin Murrell24/10/2019 16:59:16
32 forum posts
Fixed web link: **LINK**
Mike Crossfield24/10/2019 17:54:00
212 forum posts
19 photos
John,
Try Ian T Cobb at www.clockmaking-brass.co.uk. He stocks a wide range and will cut to pretty much any size.
Dave Shield 124/10/2019 18:44:50
13 forum posts
Use M-machine, Very good service
roy entwistle24/10/2019 18:46:46
1172 forum posts
Clock makers usually use engraving brass, not suitable if you have to bend it
Roy
Mike Crossfield24/10/2019 20:03:59
212 forum posts
19 photos
Despite the name of his website, Ian Cobb supplies a range of different brass, not just engraving brass.
Essm24/10/2019 20:05:48
21 forum posts
8 photos
Blackgates Model Engineering in Dewsbury will cut any size you need and charge by weight
roy entwistle24/10/2019 20:38:06
1172 forum posts
I was just making sure that the OP new what he was asking for
Roy
John Hilton05/11/2019 09:35:30
113 forum posts
22 photos
Just to update this post.
Thanks to everyone for your suggestions.
Eventually I went with John Keatley metals. (Thanks D A Godley).
They were happy to supply a few other small bits of steel I wanted (like 30mm lengths) and prices for the brass were very good.
They even saved me £20 Plus VAT on postage by discussing what I was using it for and suggesting an appropriate cut to the Brass.
Well recommended, and they even answer the phone!
D.A.Godley05/11/2019 22:16:10
99 forum posts
37 photos
Posted by John Hilton on 05/11/2019 09:35:30:
John ;
So very pleased you found what you required and that they saved you a few pence , it always helps . I had absolutely no doubt that they would be able to satisfy you .
regards ,
David
