Turning a recess in the end of a bar
larry phelan 122/10/2019 12:00:54
831 forum posts
17 photos
I need to turn a recess in the end of a bar of 40mm dia. The recess needs to be 30mm x6mm deep.
What type of tool bit or cutter do I need and how should I go about it ?
I will have to produce a number of these. I think they are intended to with some form of supports
I need to turn a recess 30mm x 6mm deep in the ends of a bar 40mm dia and I have a number of these to do.
What kind of toolbit or cutter do I need and how do I begin ?
All ideas welcome
larry phelan 122/10/2019 12:02:36
831 forum posts
17 photos
Please excuse my double post stubby fingers !
old mart22/10/2019 12:17:25
2006 forum posts
155 photos
I would start with a small drill making sure the tip only went 6mm deep and then a succession of end mills up to the size of the tailstock chuck capacity. Then a boring bar just small enough to increase the size of the hole until there was room for a larger boring bar to finish the job.
SillyOldDuffer22/10/2019 12:20:53
6335 forum posts
1393 photos
I'd drill a 13mm / 1/2" hole of the required depth and then open it out to full diameter with a boring bar. That's assuming the work is short enough to be held in a chuck or the lathe can take a long 40mm diameter bar through the spindle!
If not, to deal with a long bar, I'd take the tailstock off, clamp the bar to height on the saddle, and bore the end recess with a cutter spinning in the chuck. I could probably do a 1500mm long bar that way, before the far end hit the wall, but the method is only limited by the need to support the free end of the bar and plenty of room beyond the tailstock end. (Which I don't have unless I turn the lathe through 90 degrees and open a door!)
My problem is, how does a lazy bloke with no money get someone else to sort out the brambles he's allowed to take over his garden. As it's I nice day I've been forced to tackle it this morning, and I HATE GARDENING.
Edited By SillyOldDuffer on 22/10/2019 12:22:50
IanT22/10/2019 12:24:11
1620 forum posts
151 photos
Generally concur with Old Mart - but I think you will probably get away with just some (stepped) drilling to start with - and then a small boring bar to follow. You might want to move to a larger boring bar as you get deeper in.
For shallow (but wide) recesses, I can often get away with just a turning tool run back from a centre hole...
IanT
Ian P22/10/2019 13:03:41
2420 forum posts
101 photos
Posted by larry phelan 1 on 22/10/2019 12:00:54:
All ideas welcome
As others have said, start with a drilled hole (about 6mm to the correct depth) I would then switch to an endmill held in the toolpost that is used in the same manner as a boring bar. The endmill can have 2 or more flutes so just line up one flute on the centerline. Even if the endmill is not a centre cutting one, up to about 10 or 12mm diameter it will plunge into the drilled hole and then just wind out the crosslide to the bore needed.
Without knowing the intended purpose of the recess all you can do is make the part to the specification given, but it may be that it would not matter if there was a pip or the remnants of the drilled hole still present at the bottom of the recess.
Ian P
not done it yet22/10/2019 13:23:24
5031 forum posts
20 photos
Length of bar protruding from the chuck is important. If bore of spindle will accept 40mm - a simple boring tool or any suitable cutter once the recess is started at the centre.
If too big for the bore but short enough for “between centres”, use a fixed steady and then as above. If very long, as SOD
JasonB22/10/2019 13:35:26
18915 forum posts
2082 photos
Any boring bar that takes CC** inserts will cut a flat bottom provide you have the height right
larry phelan 122/10/2019 14:33:39
831 forum posts
17 photos
Many thanks to everyone for such speedy replys.
I was called away by "A Higher Authority", and have just got back.
I am lucky in that my spindle will take 40mm, so overhang is not a problem,
I will attack that job tomorrow morning [Higher Authority willing ]
Dave, I know exactly how you feel about those brambles, I had to attack mine this year, was like the rain forest ,some of them 10 ft long and they fought back.
Be brave ! When it comes to getting rid of them, I just put a match to them some Sunday morning as an offering to the Sun God !
pgk pgk22/10/2019 16:26:46
1914 forum posts
288 photos
Posted by SillyOldDuffer on 22/10/2019 12:20:53:
Since the OP has been answered . I hate brambles too- and got acres of them. They have a habit of pulling the chain off chainsaws and not doing too well with brushcutter blades. Local farmer in't pub last friday stated a specific weedkiller for them but the name escapes me...it;s too late in the season really for weedkillers anyway but I understand the DIY weedkiller way is to mix glyphosate with wallpaper paste and soak trails in a bowl - the wallpaper paste lets you know which one's you've done. Again impractical when you have as much as I do. They're going to die back now anyway. If the ground is suitable then a front deck lawn mower will mulch them down (my method around the garden edges) or a tarctor and topper round field boundaries--- back up and lower the topper on 'em.
I had a few to cut my way through before felling some trees last week and , yeah, took the chain off the saw just before i finished (again)
larry phelan 123/10/2019 15:54:34
831 forum posts
17 photos
Based on the advice given, I attacked that job this morning and am happy to be able to report success.
I do not have one of those boring bars mentioned by Jason but will look into getting one, since I suspect this job will crop up again.
Again, my thanks to all who responded, it is much appreciated.smiley
SillyOldDuffer23/10/2019 17:18:04
6335 forum posts
1393 photos
Posted by pgk pgk on 22/10/2019 16:26:46:
...it;s too late in the season really for weedkillers anyway but I understand the DIY weedkiller way is to mix glyphosate with wallpaper paste and soak trails in a bowl - the wallpaper paste lets you know which one's you've done. ...
Thanks for the hint, sounds like a good idea, and practical in my garden if I grit my teeth and get stuck in. As the brambles are mixed in with wanted plants I've tried carefully spraying glyphosphate . Not worked well because it's hard to gauge coverage and see where I've been, Soaking the trails in a bowl is a clever way of ensuring take up too.
Can't wait to try it next year!!!
Ta,
EngineDIY
