Tour of my workshop
Phil Whitley19/10/2019 18:12:44
1194 forum posts
145 photos
Hi Chaps, a workshop tour, or at least, the story so far, showing stuff I have finished, and stuff I haven't!
Enjoy, and comment and subscribe if you like it!
Phil,
East Yorkshire,
UK
https://www.youtube.com/watch?v=pJ7wqLi1_QY&t=8s
https://www.youtube.com/channel/UCKf0nWnXKXltBjj7MWtdjWA?
Edited By Phil Whitley on 19/10/2019 18:14:48
Edited By JasonB on 19/10/2019 19:31:33
Phil Whitley21/10/2019 17:12:53
1194 forum posts
145 photos
Hi JasonB, did your edit put the pic up instead of the ICON? thankyou, I couldnt do that and the picture you picked is perfect!!
Phil
East Yorkshire
Sam Longley 121/10/2019 22:12:04
751 forum posts
26 photos
Lovely to have all that space, but one has to wonder--------Is there anything that does NOT need a job doing to it before you can use it????sad
Edited By Sam Longley 1 on 21/10/2019 22:15:15
Bazyle21/10/2019 22:20:47
5222 forum posts
201 photos
Wow, that's huge, bigger than my house and lots of clear floor space - you are not a true model engineer until all the floor is hidden under machines and projects. laugh
Andrew Evans22/10/2019 09:06:57
316 forum posts
8 photos
Thanks Phil, I am jealous of the amount of space you have. Plenty of room for a big Holbrook or DSG lathe.
mechman4822/10/2019 12:21:52
2663 forum posts
410 photos
Nice set up Phil. You have more space in there than the whole floor area of my bungalow. Do I assume that it is on an industrial estate, as you mentioned something about 'industrial water' or is it/attached part of you property?.
George.
Phil Whitley22/10/2019 19:56:37
1194 forum posts
145 photos
Posted by Sam Longley 1 on 21/10/2019 22:12:04:
Oh yes, both lathes are finished and the Harrison milling machine, I only have suds on the Colchester, shaper is fully working, as is the hacksaw and 2 drilling machines, and all the welders, so all the basics are there. trouble is that I continued to aquire machines even when I didnt have use of the workshop (long story), so now I am back in the shop, I have a backlog to catch up on, but you need tools to fix tools, so when a machine is desperately needed, it gets finished, but generally, I go to work, pick a machine, and work on it till it's done!
Phil
Phil Whitley22/10/2019 20:07:08
1194 forum posts
145 photos
Posted by Andrew Evans on 22/10/2019 09:06:57:
Thanks Andrew, my first lathe was a DS&G 13Z, a bit battered, but a good workhorse! I would love a Hollbrook, but they are heavy, and seem to prefer the south of England (where they were made, Harlow, Essex) There is a nice one in the railway museum workshop at York! Here I am, in the seventies, in the same, workshop, with the DS&G, which is in the same position as the Covmac is now. I have less hair on top now, but more down the back! Thanks for the comments
Phil
East Yorkshire
Phil Whitley22/10/2019 20:25:28
1194 forum posts
145 photos
Posted by mechman48 on 22/10/2019 12:21:52:
George.
Hi George, Not an industrial estate, couldn't afford the rent!! My late father and I built this workshop in the seventies on a plot of land we bought for £150! It is across the road from the house and shop I grew up in, but we no longer own that , so I commute 6 minutes every day! The workshop is a registered commercial premises as we ran a business from it back then and the LA have advised against changing it back to private as I get small business rate relief, and it now has a new water supply with a meter, but I installed the rainwater system to the existng victorian beehive cistern in the seventies, so it makes sense to use it for toilet flushing and hand (and pressure) washing, thus saving cash on my water bill. Because sewage charge is calculated as a percentage of the water supplied through the meter, I do not pay a sewage charge, just pay for the water through the meter, and a surface water charge, as technically, I am disposing of my surface water into their drains every time I flush! Thanks for the kind comments,
Phil
East Yorkshire
