Surface Mount Switch
Retro fitting NVR switch.
Colin Wilks16/10/2019 09:58:38
30 forum posts
I am wanting to fit a surface mounted NVR switch to both my Myford Lathe and Fobco drill. Ideally they will have on, off and emergency off buttons like the Axminster item here https://www.axminster.co.uk/kedu-nvr-switch-230v-1ph-e-stop-200093.
I can't believe I'm doing anything out of the ordinary, but this seems to be the only product available, since all other offerings are flush mounted and searching for "surface mount switch box", "pattress box" etc yields no results. Obviously I can make something up to attach any switch to, but I wanted a "proper job" with knock outs to install cable conduit.
Am I missing a trick here, or is the Axminster item the sole contender?
Michael Gilligan16/10/2019 10:13:19
15747 forum posts
688 photos
If it’s any help Colin ...
Searching for: “KEDU NVR Switch 230V 1ph E Stop“
returned several suppliers of that item, and also Kedu’s own website
Journeyman16/10/2019 10:14:38
802 forum posts
141 photos
Something like this on Amazon
Edited By Journeyman on 16/10/2019 10:20:20
SillyOldDuffer16/10/2019 10:22:35
5791 forum posts
1232 photos
Tricky one! Dunno what the correct search term is for this type of mounting.
Looking for 'Dustproof' and 'Waterproof NVR Switch' gets results worth checking through, but they're imperfect.
Clive Foster16/10/2019 10:37:08
2206 forum posts
73 photos
Deleted post, slow typing!
Edited By Clive Foster on 16/10/2019 10:38:06
Colin Wilks16/10/2019 11:13:02
30 forum posts
Thanks all. No easy answer!
The eBay offering of the Axminster Kedu switch seems to also come from Axminster and their eBay seller's rating seems excellent. One worrying review of the product was that the emergency stop needed pressing "for several seconds" in order to cut the power, which seems a pretty fundamental flaw and I'm guessing was due to either a faulty unit or incorrect wiring.
I don't think Journeyman's Amazon suggestion does the job as I do not think a momentary switch is the same as a NVR (no volt release) switch, the idea of the latter being that if I switch my pillar drill off at the wall socket and then switch it back on at the socket the next day the drill will not start up and surprise me. Why the hell I would do that I don't know, but in my case any degree of idiot proofing is welcome and appropriate!
Still hunting for a supply of surface mount boxes in which to mount all those flush mount switches. I suspect they are so cheap they are not worth anyone's while stocking them for retail.
The internet's wonderful in many ways, but I had hoped to go to a local trade counter and get hold of one of these things before buying. Does that make me an old fart?
Michael Gilligan16/10/2019 11:22:57
15747 forum posts
688 photos
Posted by Colin Wilks on 16/10/2019 11:13:02:
I am not familiar with “all those flush mount switches” ... so the obvious first question is:
Are they made in a format [depth, fixing-centres, etc.] which is compatible with any standard box ?
Stuart Smith 516/10/2019 11:28:14
96 forum posts
25 photos
I live near the CPC warehouse, so buy quite a few things from them .
They have a whole range of boxes and switches. Is this the sort of box you are looking for?:
the range of switches and boxes is at :
I have no connection with the company, just a customer.
Stuart
Martin Kyte16/10/2019 11:43:40
1847 forum posts
33 photos
Try this offering from Axminster Tools
regards Martin
Martin Kyte16/10/2019 11:45:18
1847 forum posts
33 photos
Which is exactly where you started, sorry I should read posts more carefully.
Martin
Colin Wilks16/10/2019 11:46:25
30 forum posts
Thanks for the link Stuart. To answer you and MichaelG, if you Google "NVR Switch" you get a large selection of on/off and emergency stop switches, but only very few are surface mount (i.e. have a box on the back). The majority are flush mount to replace existing switches in machines, and nobody seems to sell the empty plastic back boxes. As I am fitting the switch to the metal cabinet of a Myford lathe I need to surface mount the switch.
Lambton16/10/2019 11:49:06
694 forum posts
Colin, you are correct the Amazon switch referred to by Journeyman is not suitable for proving NVR to very simple machines that have just plain on/off stiches. To provide NVR here must be latching relay in the on circuit that keeps the power on to the machine unless either the off or emergency switch is operated. If the power goes off remotely the relay "drops out" cutting power to the machine and the machine cannot self restart. If the E stop has a rotating knob which stays down when activated this must be reset by twisting it to make it pop out. The machine can them be started normally.
Axminster provide a very simple NVR switch "Unimac magnetic switch" that incorporates a relay that provide NVR but not an E switch. I have had one for many years on a fearsome Duet woodworking machine via a foot switch with every satisfaction.
To do the job properly you should consider fitting a Direct online motor starter + E stop as this set up would provide protection for motor should it become overloaded.
Eric
Harry Wilkes16/10/2019 11:54:17
896 forum posts
61 photos
I fitted a NVR on the side of my drill as shown in photo, the on/off was on the side of the drill and difficult for me to use so I purchased on off ebay popped it in a box and extended the wires .
H
Emgee16/10/2019 12:36:49
1493 forum posts
217 photos
Posted by Lambton on 16/10/2019 11:49:06:
Eric
+1 for Eric's suggestion
Emgee
Colin Wilks16/10/2019 12:58:26
30 forum posts
Cracked it. Googling "enclosure junction box" produces what I am after.
Regarding a direct on line motor starter with a separate emergency stop, this makes sense as it protects against overload and allows me to position the stop switch in the most appropriate position, but is this technology compatible with my Crompton Parkinson 240v motor which uses a condenser to start via a centrifugal switch?
IanT16/10/2019 14:21:45
1535 forum posts
144 photos
I've fitted these Axminster 'KEDU' switches to a number of my older machines - most recently a Coronet Consort table saw I've been restoring (last week). I've also had one fitted to my Super 7 for some years now and I've not had any problems with them. They cut power immediately if you hit the red 'STOP' button, although I normally just use the 'off' button provided - but I certainly tested this function on the Consort last week and it worked just fine.
They do seem to be sneaking up in price but are still affordable. For anyone with an older machine (with just a simple on/off switch - or even worse no switch at all) I think they are a very sensible improvement to make. Of course if I'm working on a machine (e.g. changing a saw blade) - I do still pull the plug out!!
IanT
Emgee16/10/2019 23:37:32
1493 forum posts
217 photos
Posted by Colin Wilks on 16/10/2019 12:58:26:
Overload size depends on the motor FLC, usually stamped/printed on the motor plate.
This is listed in Classifieds.
Edited By Emgee on 16/10/2019 23:38:41
peak417/10/2019 01:49:44
1095 forum posts
124 photos
When you're looking for something generic, rather than specific. it's sometimes useful, when using Google, to go for Image, rather than the normal default text output of the results.
It's much more like thumbing through an old paper catalogue so look for something that fits the bill
e.g. NVR Start stop which quite quickly leads to a variety of sources. e.g. ebay
Bill
Douglas Johnston17/10/2019 09:42:09
689 forum posts
34 photos
Posted by peak4 on 17/10/2019 01:49:44:
Bill
That's very interesting but I can't seem to replicate it. How do you get the option of text or image? All I can see when I try is the text version. What am I missing?
Doug
peak417/10/2019 09:59:27
1095 forum posts
124 photos
Doug, probably should have mentioned, PC, rather than phone/tablet; just checked and works on my phone with Chrome as a browser on Android.
Under the Google search box, there are options for "All", "Shopping" "Images" " Videos" "News" more etc.
This option is how the results are displayed, so only shows up after the search.
Bill
