What grade
Harry Wilkes14/10/2019 10:28:14
767 forum posts
60 photos
I've noted on many occasion the wheel hub caps on my 3" Burrell tarnish easily and have copper spots appear on them so I'm thinking that over the winter I may make some new ones, so what's the best grade of brass to use to get a good finish and polish ?
H
pgk pgk14/10/2019 11:26:36
1500 forum posts
285 photos
Is it daft to suggest gilding?
Harry Wilkes14/10/2019 14:36:37
767 forum posts
60 photos
Thanks for suggestion but I don't think it would be suitable, correct me if I,m mistaken
H
JasonB14/10/2019 14:40:52
16922 forum posts
1818 photos
gold plating won't tarnish
HOWARDT14/10/2019 14:44:36
489 forum posts
14 photos
C464 marine grade, will still tarnish but won’t pit.
old mart14/10/2019 14:47:38
1008 forum posts
109 photos
I seem to remember a polish for brass which claimed to extend the life between polishing.
Brian Wood14/10/2019 15:55:12
2064 forum posts
37 photos
Harry,
Why not try a clear varnish after polishing? Rustins made a good one that works well and would save you the effort of making new caps.
I agree with you that gold plating might look too bright; it does dull slightly with aging but the process is slow.
Edited for punctuation.
Edited By Brian Wood on 14/10/2019 15:56:04
Grindstone Cowboy14/10/2019 16:44:50
173 forum posts
9 photos
I can heartily recommend Renaissance Wax to prevent tarnishing once you have polished them. And for the polishing, I'd go with Solvol Autosol.
(Other suppliers are available, it was just the first link I found)
Rob
pgk pgk14/10/2019 16:56:23
1500 forum posts
285 photos
Posted by Brian Wood on 14/10/2019 15:55:12:
I believe it's possible to get gilding foils in all sorts of metal colours and shades Also many moons ago I dismantled and re-lacquered an ancient saxaphone using cellulose rattle can that was essentailly a clear coat with a tint of brass. Not sure if that's still available (came from an auto paint shop in Uxbridge)
pgk
SillyOldDuffer14/10/2019 17:58:15
5036 forum posts
1063 photos
The copper spots are appearing because of de-zincification suggesting the hubs are made from an ordinary high zinc brass. This stuff is easy to buy and nice to machine but not good at resisting corrosion.
An alternative might be Naval Brass (CZ112) or CZ132, or even a low tin Bronze like Admiralty Brass.
Finding someone to sell it in small quantities may be tricky. My quick web search only found people set up to sell to industry. Dunno how big the hubs are but if there's enough metal in scrap plumbing fittings, they're made of corrosion resistant alloys.
David George 114/10/2019 18:34:57
1020 forum posts
320 photos
You can get naval brass from M-machine metals.
David
Harry Wilkes15/10/2019 16:07:10
767 forum posts
60 photos
Thanks for all the answers, I don't mind a quickly with the Brasso but the copper colored spots on the present one do annoyed me wink
H
Mick B115/10/2019 17:23:15
1293 forum posts
72 photos
Harry,
Their clear metal lacquer works well for me.
Neil Wyatt15/10/2019 18:59:31
16965 forum posts
690 photos
76 articles
I used Windsor and Newton spray lacquer on the brass parts of this Westone Thunder 1 when I smartened it up. It works well and can be removed with White Spirit, it's meant for protecting artworks and for conservation of articles. The original lacquer came off with meths so may have been shellac.
mid gard rail Jan 2020
