diameter calculation
SillyOldDuffer11/10/2019 11:26:56
5328 forum posts
1090 photos
Posted by Nicholas Farr on 11/10/2019 10:05:06:
Hi S.O.D., I've found this in one of my books, but it does give a couple of dimensions and an angle, but you've asking about random placed points and I suspected it would involve Algebra as Andrew has said. However I could never get to grips with Algebra, which seems that MichealG's search is full of.
Regards Nick.
This simple example has left me in the dust! I've confirmed it works by drawing it with QCAD but why is the diameter of the circle given by dividing distance AC by sin( 41° ) ?
I don't understand the method. The calculation isn't solving the triangle ABC, or calculating the length of line AB.
I can do trigonometry on right angled triangles, but ABC isn't right angled.
Andrew says it's simples and I believe him. He said:
"The Equation of a circle has three unknowns. Three unique points give you three indpendent equations. Three equations and three unknowns allows a unique solution for the centre and radius, with a bit of algebraic manipulation." It's the 'bit of algebraic manipulation' that finishes me off. Michael's Wolfram and Weebly examples may help clear the fog.
Meanwhile I found this discussion on StackExchange. It goes with Quadratic equations and matrices.
It's like being back at school. I did a class called 'Maths for Scientists'. This was a euphemism. It should have been called "Remedial Maths for Silly Boys Who Should Have Chosen an Arts Subject".
sad
Edited By SillyOldDuffer on 11/10/2019 11:27:23
Kiwi Bloke11/10/2019 11:37:45
344 forum posts
1 photos
Dave (S.O.D), look up 'sine formula'. Not all trig needs right-angled triangles...
Michael Gilligan11/10/2019 11:43:13
14963 forum posts
638 photos
Dave,
I think it's useful to remember that this is an example in polar geometry ... so the correct solution will only be obtained by polar 'construction'.
Any 'rectangular co-ordinates' solution will inevitably be an approximation: When I was using Autocad it worked to fourteen decimal places [it may have improved since then], but that's still an approximation.
"Michael's Wolfram and Weebly examples may help clear the fog."
... I sincerely hope so.
Edited By Michael Gilligan on 11/10/2019 11:45:47
Kiwi Bloke11/10/2019 11:50:41
344 forum posts
1 photos
Michael: 'I think it's useful to remember that this is an example in polar geometry'. You mean 'R - theta' geometry? Not really, although I agree a bit of construction is required to get to this, 'sine-formula'-like answer. Co-ordinate geometry is good, if only because it's easy to transfer that approach to machining co-ordinates.
SillyOldDuffer11/10/2019 12:12:44
5328 forum posts
1090 photos
Posted by Kiwi Bloke on 11/10/2019 11:37:45:
Good clue: Wikipedia gives an explanation of the Law of Sines and this diagram (credit) shows where the diameter comes from:
Although I understand it now I shall have forgotten everything by bedtime. Sad isn't it.
Ta,
Neil Wyatt11/10/2019 13:02:45
17326 forum posts
690 photos
77 articles
Posted by SillyOldDuffer on 11/10/2019 11:26:56:
Draw a right angled triangle with AC as its base, and the other vertex, E on the circumference and A as the right angle.
The line CE is now a diameter, as the hypotenuse of a right angled triangle in a circle is always the diameter.
So from trig AC / CE is sin e
As CE = D and AC =B then, if the formula is correct, sin e = sin b.
Who can do the geometry that proves e= b ?
Neil Wyatt11/10/2019 13:03:24
17326 forum posts
690 photos
77 articles
Damn beat me to it!
Michael Gilligan11/10/2019 13:11:17
14963 forum posts
638 photos
Posted by Kiwi Bloke on 11/10/2019 11:50:41:
dont know ... if you say so
What I should perhaps have written is that the geometry only works accurately in polar co-ordinates
... but I thought that what I wrote, and the links that I provided, might help Dave's thinking.
Oh well ...
paul rayner11/10/2019 13:23:32
136 forum posts
40 photos
Hi all
worked a treat thanks guys.
I'm not very good at "sums" I've just read through the postings and I think my head is going to explodesurprise
thanks again.
regards
Paul
Nicholas Farr11/10/2019 13:43:53
2114 forum posts
1025 photos
Hi S.O.D., I guess I should have filled you in with the proceeding piece of text to example 26 above, which is;
Of course you need to understand the Sine rule, which I'm a bit rusty on now having not used it for a long time. Apologies if I've confused you and others of course. This rule though, would have solved Paul's question also, but the other diagram was already in my album.
Regards Nick.
Andrew Johnston11/10/2019 13:55:04
5184 forum posts
599 photos
I'm mystified as to why polar co-ordinates should be inherently more accurate than Cartesian co-ordinates. They are both Euclidian geometry and there are precise equations for converting from one to the other, albeit involving trigonometric functions which are inherently irrational. There are functions that are more elegantly expressed in polar terms, but that's not the same as accuracy.
A supplemental question is that if different co-ordinate systems in one geometry have different accuracies how do different geometries, such as spherical, fit into the picture?
SillyOldDuffer11/10/2019 14:02:59
5328 forum posts
1090 photos
Posted by Nicholas Farr on 11/10/2019 13:43:53:
Hi S.O.D., I guess I should have filled you in with the proceeding piece of text to example 26 above...
This rule though, would have solved Paul's question also...
Regards Nick.
No need to apologise Nick! It made me think a bit and I need the practice. When I've laid out a ring of bolt holes I've always started by knowing the PCD: give that it's straightforward to calculate the angles. Interesting to know how to get the PCD from the holes, and Paul shows it's sometimes necessary.
Another example of a calculation easier in one direction than the other: given a sequence of change wheels on a lathe's banjo, it's easy to calculate the pitch. Much harder to work out which change wheels are needed to produce a given pitch, or a reasonable approximation of it. Perhaps that's one for a new thread. Like Paul my brain has exploded!
Ta
Andrew Johnston11/10/2019 14:17:32
5184 forum posts
599 photos
Posted by SillyOldDuffer on 11/10/2019 14:02:59:
For those whose brains have exploded don't bother reading this!
The problem of working out what change wheels are needed for a given pitch is an example of the travelling salesman problem. In mathematical terms it is NP-complete, in that a solution can be found by a brute force, but finite, search. However, an algorithm to reach the answer quickly doesn't exist.
Michael Gilligan11/10/2019 14:35:49
14963 forum posts
638 photos
Posted by Andrew Johnston on 11/10/2019 13:55:04:
Perhaps I am wrong there, as well, Andrew
... I’m having a bad day; so why not ?
My simple understanding though, is that anything which would be properly expressed in polar co-ordinates can only be approximated by Cartesian; thanks to Pi
Edited By Michael Gilligan on 11/10/2019 15:06:59
Howard Lewis11/10/2019 16:14:05
2885 forum posts
2 photos
Being simple, I drew a circle with three chords 65 mm long. Then a 30/60/90 degree triangle, with one side being half the chord = 32.5 and used Sine or Cosine to calculate the Hypotenuse. Then doubled the answer to get the diameter, which my calculator said was 75.055535, if you want be frightfully accurate. Me? I'd settle for 75 as being about as good as i could get, although I might set the machine to 75.06 mm or 2.955 inches in old money.
That is about as complicated as my puny brain can tolerate.
blowlamp11/10/2019 16:19:02
1245 forum posts
82 photos
What about the large circle tangent to the three small circles, inside or outside the large circle? devil
JasonB11/10/2019 18:25:20
17280 forum posts
1859 photos
1 articles
I just looked in the Zeus book and took the figure for the distance between two holes in a three hole pattern and with a bit of simple maths got
1/0.86603 x 65 = 75.055
Every workshop should have one.
Michael Gilligan11/10/2019 18:33:22
14963 forum posts
638 photos
Posted by JasonB on 11/10/2019 18:25:20:
Indeed it should yes
‘though I don’t recall it covering the question posed by Dave/S.O.D.
Andrew Johnston11/10/2019 22:03:30
5184 forum posts
599 photos
Posted by Michael Gilligan on 11/10/2019 14:35:49:
Indeed; in the majority of cases I'd expect nice round numbers in polar co-ordinates to translate to irrational numbers in Cartesian co-ordinates due to the circular trigonomic functions involved. I expect the reverse is also true, nice round numbers in Cartesian co-ordinates could translate to irrational numbers in polar co-ordinates.
Michael Gilligan11/10/2019 22:32:03
14963 forum posts
638 photos
I’m relieved to see that we are in agreement, Andrew yes
My earlier point about accuracy comes down [in practical terms] to:
For Polar jobs, polar co-ordinates are ‘definitive’
For Rectangular jobs, rectangular co-ordinates are ‘definitive’
A classic example being the NEMA hole pattern for stepper motor flanges ... devised as holes on a pitch-circle, but often specified as holes at each corner of a square [which requires expedient approximation].
Ausee.com.au
