O ring sizes?
Vic10/10/2019 16:45:24
2500 forum posts
14 photos
Do any of you know off hand how small a section O Rings are available? I’ve just ordered some 1mm ID 1mm cross section O rings but they may be a bit too big in cross section.
David George 110/10/2019 17:09:36
1226 forum posts
415 photos
I believe that 0.5 mm section is the smallest size have a look on simply bearings web site.
David
Vic10/10/2019 17:25:11
2500 forum posts
14 photos
Pretty sure it was simply bearings I looked at, smallest was 1mm. I’ll check again.
Michael Gilligan10/10/2019 18:20:37
15740 forum posts
687 photos
Browse around here, Vic: **LINK**
https://www.marcorubber.com/o-ring-size-chart-index.htm
Vic10/10/2019 21:10:12
2500 forum posts
14 photos
The smallest standard size seems to be 1mm CS but I’ve found a specialist supplier that make miniature O rings. I’ve now found a supplier though that has O rings specifically for my needs. Not sure what size they actually are so I’m going to see if the ones I’ve ordered elsewhere fit first.
S.D.L.10/10/2019 21:19:05
217 forum posts
37 photos
Seen down to 0.1mm cross section x 0.3mm OD
Steve
Edited By S.D.L. on 10/10/2019 21:19:24
Grindstone Cowboy10/10/2019 21:51:59
301 forum posts
27 photos
You could try Polymax
Vic10/10/2019 21:57:57
2500 forum posts
14 photos
Thanks for the link GC. smiley I’m sure they go down small enough and the prices look good although I’ve not checked the postage.
