At last - no more chattering when parting off!
Alan Charleston07/10/2019 08:11:25
85 forum posts
20 photos
Hi,
Came across this solution to chattering when parting off on youtube.
https://www.youtube.com/watch?v=lboJ95ZlvV0
Go to 58:26
Alan
Paul M07/10/2019 08:44:25
38 forum posts
Should have a health warning prior to the clip.
Pete Rimmer07/10/2019 08:50:00
710 forum posts
49 photos
That's nearly as bad as that idiot Steve Jordan's idea of lapping lathe slides by hand - and then having to put two locking screws on his compound when he's realised that he's ruined it, and called that an 'upgrade' too.
David Standing 107/10/2019 08:55:21
1288 forum posts
48 photos
Darwin Award contender!
David Standing 107/10/2019 09:07:35
1288 forum posts
48 photos
Posted by Pete Rimmer on 07/10/2019 08:50:00:
I just looked at that. Oh my word! And commentators on the video are praising him! surprise
Lainchy07/10/2019 09:47:15
244 forum posts
95 photos
Ahhhh Mustie He's very entertaining though.
John MC07/10/2019 10:04:51
279 forum posts
38 photos
A good reason why videos of this nature should be peer reviewed before put on the 'net! Not going to happen though.
I've done similar occasionally, difference being I made a tool post clamp for the angle grinder. Recently reduced the width of a case hardened gear in a motorcycle gearbox. Also used PPE, something the guy in the video was probably not to bothered about.
And before anyone mentions the evils of grinding dust , I do cover the important bits.
David Davies 807/10/2019 11:08:53
100 forum posts
8 photos
I thought it was camera shake at the beginning of the ''parting off'' then looked again and realised that the lathe was moving!
martin perman07/10/2019 11:11:12
1827 forum posts
78 photos
Me thinks the slideway gentleman has forgotten more than he learned whilst he worked, he didnt notice that he was adjusting the end gib strip screws in free space and then found it didnt lap in the centre smiley
Martin P
Mick B107/10/2019 12:28:14
1575 forum posts
84 photos
Yes, beware of You Tube 'tutorials'.
My missus wanted me to make a plaster-of-paris slab for drying out surplus wet pottery clay, and we wasted spent 3/4 of an hour watching some famous potter failing to make one. He made up an elaborate frame to contain the plaster, then couldn't get the slab off the car window he'd used as a base, and just gave up.
We used an old cat-tray lined with polythene. That was 5 years ago and the slab still works well.
larry phelan 107/10/2019 12:44:20
718 forum posts
14 photos
And I thought I was bad ??? That makes me feel MUCH BETTER !!smiley
Neil Wyatt07/10/2019 15:52:29
17878 forum posts
705 photos
77 articles
Ian Johnson 107/10/2019 17:45:52
259 forum posts
79 photos
Posted by Alan Charleston on 07/10/2019 08:11:25:
Hi,
Go to 58:26
Alan
Eeeek!!! at 58.26 Did you actually watch all of the video Alan it's over an hour long, if so much respect, you have more patience than me! And thanks for the fast forward alert, I just couldn't be bothered with all the waffle, and ten advert breaks.
Ian
Mark Rand07/10/2019 20:34:02
887 forum posts
5 photos
Just being picky here, but it seemed to me that there was still quite a lot of chatter in the 'tool'. It might have needed a more sturdy 'tool holder'.
JasonB07/10/2019 20:36:53
18096 forum posts
1993 photos
Mark, I'm surprised nobody has suggested he should have stood at the rear of the lathe yetdevil
Stuart Bridger07/10/2019 21:01:33
434 forum posts
25 photos
Thought it was amusing that he reversed the spindle rotation before starting his parting adventure
Nick Hulme09/10/2019 20:21:17
743 forum posts
37 photos
Posted by Mark Rand on 07/10/2019 20:34:02:
There was a lot of chatter in the tool, but it's his video........
I'll get me coat! :D
Lee Rogers02/11/2019 18:29:11
45 forum posts
I have seen worse on YT. Bored a hole on the lathe then wrapped a piece of emery around his finger and inserted into live hole to debur. I left a comment and reported to YT .
Howard Lewis02/11/2019 18:38:24
3264 forum posts
haven't the time to watch an hour or so of video, especially since it sounds as if it might be bad for my bloodpressure.
But seems to have produced quite a bit of chatter on here!
Edited By Howard Lewis on 02/11/2019 18:38:51
Emgee02/11/2019 19:35:28
1485 forum posts
217 photos
Pictured with my Quorn set up on the toolpost, cut the end off the arbor fitted to an Eriksson tenthset boring head and then changed the cut-off disc for an internal stone to grind a 3mm long internal bore. Converting an ISO30 arbor to BT30 to fit my Emco F1 mill.
