Aldi Metal Bandsaw
Ray Lyons26/09/2019 16:50:33
173 forum posts
Anyone seen the new offering from Aldi today. Available on line only is a portable bandsaw which looks interesting. Only two reviews on the web page but it is capable of cutting through 2" steel bar. Could be a useful tool to have in the shop
Pat Bravery26/09/2019 17:17:07
96 forum posts
24 photos
I bought one last year and I have found it very good. I had to do some minor tweeks and now can cut very thin slices of steel. There are a few comments about the vice not holding tightly enough, I have found my one to be fine and it will cut through 127mm which is about 5 inches. Regards Pat
Graham Williams 1226/09/2019 22:39:43
41 forum posts
Thanks for pointing this out Ray. With the positive experience of Pat I have ordered one of these. I recently borrowed some large pruning loppers from my elderly mother bought from Aldi for a very good price and they were excellent, so am well aware their things can be better than the price suggests.
Thanks Graham
Bill Phinn26/09/2019 23:13:50
374 forum posts
70 photos
"Saw blade 114cm" - interesting!
Does anyone know how much a replacement blade would be?
Edited By Bill Phinn on 26/09/2019 23:14:50
mike T26/09/2019 23:21:45
173 forum posts
It would need to be 114cm if you want it to fit.
Edited By mike T on 26/09/2019 23:23:06
Graham Williams 1226/09/2019 23:56:29
41 forum posts
Hi Bill,
about £25 for pack of 3
Bill Phinn27/09/2019 00:28:37
374 forum posts
70 photos
Posted by Graham Williams 12 on 26/09/2019 23:56:29:
Hi Bill,
Thanks. That's good to know. I rashly assumed they'd be non-standard in some way.
I'd be tempted by one of these, as long as it can cut cleanly, squarely and reasonably quickly, and keep on doing so for longer than its guarantee.
Graham Williams 1227/09/2019 00:41:37
41 forum posts
Hi Bill,
you had me worried for awhile!
seems to be a fairly standard size for portable bandsaws, I think the ones I found were for the similar Milwaukee machine. I think the guarantee is 3 years. Apparently you can set this up vertically with abit of modifying, which is mainly what I want it for - hopefully roughing out parts from 10mm aluminium tooling plate to go on the mill.
Graham
Edited By Graham Williams 12 on 27/09/2019 00:42:23
Henry Brown27/09/2019 07:58:12
297 forum posts
83 photos
Mines supposed to arrive tomorrow. Thanks for the comments above...
Henry Brown27/09/2019 10:59:15
297 forum posts
83 photos
Well, it has arrived a day early! I have to say I'm impressed with the Yodel delivery side of things, being able to track the driver to my location is a real bonus.
I've just built it, which was easy enough, and it all seems to work as it should, it looks well made for the money. It is branded Ferrex, similar versions seem to start at £210 on the internet so it would seem to be good value. The proof of the pudding will be in the cutting I guess, I'll probably find something to cut up in the next few days just to try it out.
Graham Williams 1227/09/2019 11:02:50
41 forum posts
Let us know how you get on Henry. Delivery on my order said 3-5 working days...
Graham
Henry Brown27/09/2019 11:22:29
297 forum posts
83 photos
Posted by Graham Williams 12 on 27/09/2019 11:02:50:
Graham
Will do Graham. I ordered it on Tuesday pm this week, Yodel received it yesterday, so pretty good as they weren't supposed to be released by Aldi until the 26th!
Howard Lewis27/09/2019 19:04:37
3633 forum posts
Found, with my 4.5 inch generic Chinese bandsaw that getting the blade tension right made a world of difference to accuracy and blade life.
Made up a tension meter from an article in another UK M E magazine, some time ago. Time well spent.
Tension is set by measuring the blade extension, only a few microns.
Edited By Howard Lewis on 27/09/2019 19:06:03
Ray Lyons27/09/2019 20:39:10
173 forum posts
I was very tempted to buy one of these Aldi machines and if it had been iavailable in store the grocery bill this week would have been much more but I have two saws, the old favourite, a 6x4 horisontal bandsaw and a Kennedy. These take care of all my cutting now. I think that the Aldi saw would be a good addition to any model workshop since it appears to hace a small footprint and covers most of our needs.
On the subject of blades, I make my own for the bandsaw, silver soldering the lapped joint as described in the magazines on a number of occasions. I also have an Aldi wood cutting bandsaw. This is the small cheap machine. It only cost about £70. At first, I could not get it to cut straight, the blade just wandered all over the place at will. Reset the thing several times and was almost at the point of taking it to the tip when I found a Silverline blade of the right size. It turned out that these blades are thicker than those supplied with the saw and once set up, cut perfect, added to which,they have a lifetime warrantee.
Douglas Johnston04/10/2019 19:06:11
707 forum posts
34 photos
I also decided to buy one of the Aldi portable bandsaws and must say it seems very well made. I wasn't expecting too much at the price but I have been pleasantly surprised. In particular I expected the base to be pretty flimsy but it is a decent steel pressing and the vice, while rather basic, does seem to work ok.
The blade supplied also seems to be a quality one and at first I thought there was no joint in the blade as none was visible, but on closer inspection an almost invisible join can be detected. Overall it does seem a good buy, I just hope my initial impression is justified after I have used it for a while.
Doug
IanT04/10/2019 19:51:05
1620 forum posts
151 photos
Was wandering obediently around Lidl's yesterday (following the wife as she inspected their food products) - when I noticed that they had metal cut-off saws half price (£19.99). Note - it uses cutting disks not blades...
Might have been tempted but I'd already succumbed to the Aldi bandsaw a few months back...
IanT
Mick Henshall04/10/2019 20:50:04
541 forum posts
34 photos
This is mine seems to chop through anything, last job was 1"1/4 bms
Graham Williams 1204/10/2019 20:58:55
41 forum posts
That’s good to know Mick,
mine arrived a couple of days ago, but I’ve been so busy finishing the workshop I haven’t even had a chance to open the box yet!
Was that 1.25” rod using it in horizontal mode, or 1.25” bms plate in vertical mode? (I like the adaptation you have done to use it vertically).
Graham
Edited By Graham Williams 12 on 04/10/2019 21:01:27
Mick Henshall04/10/2019 21:15:37
541 forum posts
34 photos
Should say it is a Milwauke saw not an Aldi. It was 1.25" square bar went through nice and steady,tried to keep the base simple, yours should cope just as good I just like the Milwauke equipment, saw cost £230 battery and charger was extra, total cost around £300 its dearer than the Aldi version I suspect but wanted the back up of a big player in the portable equipment scene.
Good luck with yours Graham
Mick 🇫🇴
Mick Henshall04/10/2019 21:22:14
541 forum posts
34 photos
Sorry should have said I used it as shown in photo., vertically
Mick 🇫🇴
EngineDIY
