citric acid
Philip Burley23/09/2019 17:26:26
173 forum posts
A couple of weeks ago I made a mix of citric acid from powder , I used it for cleaning some copper parts before I soldered them . Today I took the lid off to use it again and found it contaminated with a lot of small black balls of something . I would have thought that the mildly acid solution would kill off any fungus etc Any ideas what this might be ?
Phil
Neil Wyatt23/09/2019 17:52:17
17712 forum posts
697 photos
77 articles
Probably fungus... citric acid a.k.a. vitamin C isn't very toxic and in dilute form it's probably even food source for some things.
Michael Gilligan23/09/2019 18:02:55
15462 forum posts
668 photos
Posted by Neil Wyatt on 23/09/2019 17:52:17:
... citric acid a.k.a. vitamin C ...
dont know Really ?
https://www.uwhealth.org/files/uwhealth/docs/pdf/kidney_citric_acid.pdf
Edited By Michael Gilligan on 23/09/2019 18:03:19
Michael Cox 123/09/2019 18:16:10
529 forum posts
27 photos
Vitamin C is ascorbic acid.
SillyOldDuffer23/09/2019 18:30:52
5616 forum posts
1154 photos
Posted by Philip Burley on 23/09/2019 17:26:26:
Phil
Fungus and bacteria having a feast probably. Citric Acid is common in many fruits and edible. The crystals are fairly resistant to hungry bugs but add water and Citric Acid goes off just like a rotting Lemon or Lime.
'Acid' always sounds a scary but most of them are weaklings. Citric is one of the mild organic acids: it's not in the same league as Sulphuric, Hydrochloric, or Nitric which are strong mineral acids.
Philip Burley23/09/2019 18:52:38
173 forum posts
So should I dump this and mix some fresh , or carry on using it , Will it still have the cleaning effect ? Should I have made a stronger mix ?
Phil
JA23/09/2019 19:03:43
895 forum posts
50 photos
I would guess it is a fungus or some form of lower life. These can turn up in unexpected places such as in petrol and aviation fuel.
Why don't you just try using your citric acid. It will either work or not work. What ever it is will not eat your copper.
Fungi are more likely to be killed by copper than citric acid.
JA
Edited By JA on 23/09/2019 19:05:47
Howard Lewis23/09/2019 19:05:31
3146 forum posts
Amazing where fungi will grow.
At school, we found that the winchester of fuming sulphuric acid had a white fungus growing in it. In THAT environment?
Try out your solution on a some metal. If it works satisfactorily, use it.
If it doesn't, dispose of it safely
Hacksaw23/09/2019 20:35:12
427 forum posts
173 photos
If it tastes mouldy it probably is
Bandersnatch23/09/2019 22:11:12
1592 forum posts
55 photos
citric acid ....... it's probably even food source for some things.
Like humans?
wink
Michael Gilligan23/09/2019 22:51:57
15462 forum posts
668 photos
Phil
Possibly aspergillus niger, which [oddly enough] is used in the production of Citric Acid
Photos, or a rough estimate of size might help.
James Alford24/09/2019 07:25:59
374 forum posts
73 photos
I used citric acid to pickle copper a lot a while ago. It regularly grew mould on the surface, irrespective of the strength of the solution. However, it worked just as well with or without the fur coat. It just looked a bit grim.
James.
Clive India24/09/2019 07:54:51
213 forum posts
Adding a small amount of bleach fixes the mould problem for me.
Edited By Clive India on 24/09/2019 07:58:27
thaiguzzi24/09/2019 09:23:13
689 forum posts
131 photos
Posted by Philip Burley on 23/09/2019 18:52:38:
Phil
Nah, add a double Vodka in there, it'll be fine...
Neil Wyatt24/09/2019 09:51:07
17712 forum posts
697 photos
77 articles
Posted by Michael Cox 1 on 23/09/2019 18:16:10:
D'oh! Engage brain before keyboard...
Michael Gilligan24/09/2019 10:25:04
15462 forum posts
668 photos
Posted by Neil Wyatt on 24/09/2019 09:51:07:
Sulking ... Why does Michael Cox get the credit ?
sad
JA24/09/2019 12:57:04
895 forum posts
50 photos
Posted by Howard Lewis on 23/09/2019 19:05:31:
If it just citric acid I guess you pour it down the sink.
My pickling acid, made from powder bought from CuP Alloys, is now a nice green colour since used acid is returned to bottle. I guess the green is copper citrate. I would think the powder I bought contained a biocide since I never had anything grow in the liquid.
JA
Tim Stevens24/09/2019 17:07:28
1159 forum posts
I wonder if the 'mould' seen by Howard Lewis was actually crystals of SO3, and not a fungus at all. Fuming H2SO4 is so eager to combine with the tiniest speck of water that it would not make a good environment for anything living - mould, germ, or virus. Just because it looked fluffy, do not be misled.
Cheers Tim
Clive India25/09/2019 09:03:15
213 forum posts
Posted by Clive India on 24/09/2019 07:54:51:
Just a reminder wink
