Miitutoyo caliper error
BOB BLACKSHAW21/09/2019 17:53:08
299 forum posts
64 photos
I have a old Mitutoyo DIGIMATIC calliper which must be 25 years old, it packed up quite a few years ago, so finding it again in the shed is it repairable.
When installing the battery a very dim E comes up, and that's about it, I must state that the E is just about recognizable.
If its no good then a single parallel can be salvaged, but chopping the calliper up seems criminal as its so smooth to use.
Bob.
old mart21/09/2019 18:46:00
1750 forum posts
138 photos
If you go on the Mitutoyo website, they sell spares, but you need to register before getting the full information. I bought part of the electronics of a digital mike from them about 7 years ago, with great success. Check the voltage of the battery, it should be 1.5V.
Vic21/09/2019 18:59:02
2500 forum posts
14 photos
As it’s very dim are you sure it’s an E? Mine comes up with B when the battery is low.
BOB BLACKSHAW21/09/2019 22:13:23
299 forum posts
64 photos
Its a new battery and still hard to make out the E.
JohnF21/09/2019 23:09:45
981 forum posts
142 photos
Not impossible for a new battery to be a dud ! try it in another tool or a different battery first, also are the contacts clean with no corrosion ? Stating the obvious but !!!!
Brian G22/09/2019 08:33:23
696 forum posts
27 photos
According to this Practical Machinist Link "E" could mean the scale needs cleaning, but like the others, if it is faint I would first suspect the battery.
BOB BLACKSHAW22/09/2019 08:48:33
299 forum posts
64 photos
I will try another battery later to day if I have one, but I did notice the terminal the negative --- looks like its been arcing on the terminal.
Diogenes22/09/2019 08:53:41
37 forum posts
6 photos
I have paper instructions here.. .."E" does indeed mean the scale needs cleaning - the instruction say to clean the scale, and if the "E" error message still remains, it is necessary to then remove and re-install the battery.
If still no go, I would try disassembly and cleaning the inside "track reading" area of the head unit before I consigned it to the scrap bin..
Hope this helps
D
Michael Gilligan22/09/2019 09:05:49
15702 forum posts
687 photos
Posted by BOB BLACKSHAW on 22/09/2019 08:48:33:
Bob,
May I just ask exactly what batteries you use ?
I may be reading too much into your statement [in which case, please forgive me], but it sounds like you might have 'stock' ...
Edit: I've just searched  back on this forum ... Almost six years ago, I wrote:
I use Energizer 357/303 Silver Oxide in my Mitutoyo caliper.
... Long shelf life, and excellent performance. [*]
Using cheap Alkaline cells in good equipment is a false economy.
Ref. https://www.model-engineer.co.uk/forums/postings.asp?th=88252
Edited By Michael Gilligan on 22/09/2019 09:19:19
BOB BLACKSHAW22/09/2019 09:12:58
299 forum posts
64 photos
The battery is a AG13, the sort I've got are a multipack button cell, I've used them on my height gauge an seem to work ok.
They are not the best quality.
Michael Gilligan22/09/2019 09:27:06
15702 forum posts
687 photos
Thanks, Bob
My edit crossed with your reply ... but I think we may be onto something:
Have a look at the Voltage Duscharge curves on this page, that I've literally just found on the web:
**LINK** http://www.lr44batteryequivalent.org/
BOB BLACKSHAW22/09/2019 10:26:31
299 forum posts
64 photos
Thanks for the link Michael, well worth getting a silver oxide battery and try it.
I will let you know on this post.
Thanks all, Bob.
BOB BLACKSHAW25/09/2019 18:48:49
299 forum posts
64 photos
I put the new silver oxide battery in today but its still showing a very faint E symbol, so it looks like its finished as a calliper.
Bob..
Michael Gilligan25/09/2019 18:51:15
15702 forum posts
687 photos
Sorry to hear that, Bob
Ron Laden25/09/2019 20:29:53
1920 forum posts
367 photos
Bob, I have a Mitutoyo Digimatic which is well over 30 years old and it still works but I do have to nurse it along. My problem is battery related also, I have to keep cleaning the contacts or the display dims even with a new battery fitted. Also the central contact which is angled upwards has lost its spring so I have a thin washer between the battery and battery cover to maintain contact.
Have you thought of giving the Mitutoyo service dept a call, I have been meaning to but havnt got around to it yet. They may have a standard charge for repair/service of their products, but it may also be a case of replacement parts plus an hourly rate and other charges which costs more than the calliper is worth.
I will have to look into it as I would like to keep it going, its till very nice to use and head and shoulders above the cheapo versions.
Grindstone Cowboy25/09/2019 20:45:46
300 forum posts
27 photos
Just for reference, here is a link to their website, which states " Direct end user contact is encouraged on spares/repairs to enable prompt, cost effective service and communication. A dedicated customer support telephone team is always on hand for assistance, you can call them on 01264 353123. "
BOB BLACKSHAW05/11/2019 17:59:38
299 forum posts
64 photos
dscn1130.jpgTried allsorts of batteries with no success, but this works a treat, tried and tested.
Bob
Michael Gilligan05/11/2019 18:12:59
15702 forum posts
687 photos
Nice big display too, Bob
... Every cloud has a silver lining yes
Neil Wyatt05/11/2019 18:29:03
17883 forum posts
705 photos
77 articles
Posted by BOB BLACKSHAW on 05/11/2019 17:59:38:
Bob
Aldi body?
not done it yet05/11/2019 18:39:31
4637 forum posts
16 photos
I somehow disbelieve the negative terminal has been arcing. 1.5 volts doesn’t do that trick too well. Corrosion is, by far, more likely. That could mean a high contact resistance, so much less voltage across the electronics than required.
