Water Lifter Hose
tom hardy18/09/2019 12:24:54
11 forum posts
5 photos
where can i buy steel reinforced lifter hose for a 1 1/2 traction engine
tom hardy
Brian Sweeting19/09/2019 14:57:53
396 forum posts
1 photos
What size tube are you looking for and material type?
There is a good range of 'plastic' reinforced tubing available.
JasonB19/09/2019 15:04:16
17005 forum posts
1823 photos
1 articles
Quite a few makers get a small rubber hose and then wind thing galvanized wire around it. You can leave as that or add a layer of self amalgamating tape. MJ Engineering do some suitable black rubber hose for just that job
Heritage steam sell scale water lifter hose but only for the large scale engines
Clive Brown 119/09/2019 15:16:27
313 forum posts
7 photos
For the 1 1/2" Allchin, W Hughes described wrapping tinned copper wire around 1/4" rubber tube. He suggested grey tube, which is not common, and fuse wire, 10 or 15 amp, I forget which, but it's 0.015" dia or 28 swg.
His method was to wrap 3 lengths of wire side by side, then remove 2, to give the spacing.
Oldiron19/09/2019 15:20:55
354 forum posts
22 photos
Nip over to your nearest hydraulics & hose supplier or agricultural outlet. Depending where you are you could try these people. They will always help the small user. Hose supplier     regards
Sorry just noticed you are in WA from your earlier posts.  The info should be of help to yourself and others though I hope
Edited By Oldiron on 19/09/2019 15:22:18
Edited By Oldiron on 19/09/2019 15:25:27
Trevor Drabble19/09/2019 15:25:07
205 forum posts
5 photos
As per Jason's suggestion , Blackgates also sell a selection of suitable hose in different diameters.
Trevor.
tom hardy21/09/2019 00:52:22
11 forum posts
5 photos
thank you people for the info well done
tom
Neil Wyatt21/09/2019 21:37:41
17045 forum posts
690 photos
76 articles
I came across a suggestion of winding a loose spring with hard stainless steel wire, then inserting it into a tube of heat-shrink tubing. I imagine it isn't very flexible, but not sure how much you need it to bend.
Nick Clarke 322/09/2019 09:46:32
501 forum posts
12 photos
Does it need to be steel reinforced or to have the appearance of steel reinforced?
In an article about making vacuum brake pipes W.A (Bill) Carter described how to wrap wire around a pipe and run an electric current through it to burn the appearance of the corrugations into the pipe.
If you need it I will dig out the reference to the issue.
Nick
Ausee.com.au
