M8x1 left hand tap.
Pete Savage17/09/2019 22:59:50
23 forum posts
8 photos
Hi guys!
I'm making new lead screw nuts for my unimat but I'm having problems. Has anyone ordered an M8x1 left hand tap and received one that was actually correct? The eBay ones seem to all be absolute crap, with the pitch being closer to 1.1mm. I currently don't have access to a lathe with metric screw cutting facility so i can't have a go at making my own. Any trusted sources?
Cheers,
Pete
Nigel Graham 217/09/2019 23:30:34
588 forum posts
Try Tracy Tools. (01803 325603.
Their catalogue states Left-hand taps & dies available, though more expensive than plain old right-hand. However, their quality and service are good, and they are one of "Our" established suppliers!
I don't have an eBay account but I wouldn't buy anything that way unless it was a private second-hand sale (as the site was originally designed to handle), and then only with care! Judging by many comments I've seen, it seems to have become an outlet for manufacturers of bottom-of-the-range stuff.
Bill Pudney18/09/2019 03:12:55
443 forum posts
16 photos
Drill Service at Horley would be another suggestion. I got a couple of M10 x 1.0 LH taps and a die from them, some time ago.
cheers
Bill
JasonB18/09/2019 07:00:30
17874 forum posts
1954 photos
Rotagrip have them and are usually do decent stuff though they do several brands of taps, they also have an e-bay shop.
Brian G18/09/2019 09:32:10
676 forum posts
26 photos
I would definitely agree with the suggestions of Drill Service Horley (who I relied upon in my working life) and Tracy Tools, but would also add another. When I repaired my SL tailstock I didn't want to go to the expense of HSS for a one off, so I bought HBM carbon steel taps and die from RDG tools.
They did the job perfectly, and I just re-checked the pitch. (I never thought to do so BEFORE using them as I tend rightly or wrongly to trust anything engraved not just with the size, pitch and direction, but also with the makers name AND the required drill size!
Pete Savage18/09/2019 11:18:10
23 forum posts
8 photos
I haven't rung up anyone yet but had a check on the websites, I found an RH m8x1 on tracy tools. 18 quid for the rotagrip HSS looks good as long as it is genuinely a 1mm pitch, 65% discount sounds a bit suspicious.
I must say the only reason I checked the pitch was because it was about a tenner for a set of 3, of a non standard pitch, and if that wasn't uncommon enough it is left hand!
The idea was to make phosphor bronze sacrificial anti backlash nuts to try and get the backlash and friction down to help with the fitting of CNC, so an investment in a tool likely to last a few sets sounds good.
Pete Savage18/09/2019 15:44:50
23 forum posts
8 photos
I just checked back through my emails, and my dodgy tap set did come from rdg tools. They offered me a refund if I sent it back recorded but that would have been half the value of the product.
None of the shops mentioned have one on stock so hopefully ordering they won't just get a bad one from rgd and pass it on!!
Tony Pratt 118/09/2019 15:51:12
1105 forum posts
Posted by Pete Savage on 18/09/2019 15:44:50:
Pretty sure the retailer has to pay postage on faulty items as per UK consumer goods act[or similar distance selling regulations]
Tony
Brian G18/09/2019 18:17:06
676 forum posts
26 photos
You panicked me there Pete, so I cut a thread using the taper tap from my RDG set (bought in April 2017) and set up the plug tap as shown in this photo. 10 turns came to 10.01mm, (+/- perhaps 0.02mm, I don't think my judgement that the wrench was level was more than 5 degrees out). It looks like you got a bad batch, but the worry is, what is in their stock now?
Nick Hulme19/09/2019 09:29:31
743 forum posts
37 photos
Posted by Pete Savage on 18/09/2019 11:18:10:
If going the CNC route go straight to Ball Screws, suitably sized ones for your machine will not break the bank.
Pete Savage19/09/2019 13:22:04
23 forum posts
8 photos
I bought the tap September 2018, I lost interest in sending it back but it was bizarre because all 3 taps in the set were wrong according to my pitch gauge.
I would be interested to look into ball screws, but the unimat is absolutely tiny, I don't think anything more than the m8 leadscrew would fit in the cross slide area
Roderick Jenkins19/09/2019 16:28:45
1856 forum posts
473 photos
Looks like they could actually be 5/16 x 24 (UNF).
Rod
Niels Abildgaard19/09/2019 18:20:06
272 forum posts
96 photos
A continental source
MF8 LH
Pete Savage19/09/2019 18:22:47
23 forum posts
8 photos
Hopefully Roderick! At least that might actually be useful at some point!
Below is the one I have just received from RotaGrip.
And here is the RGD one!
JasonB19/09/2019 18:55:22
17874 forum posts
1954 photos
Good to see my suggestion of Rotagrip worked out, is it a brand name one or just one of their imported ones which I have found fine for threads you are not going to use much, I've a few fine pitch metric ones for them that crop up on gas fittings.
Definately something wrong with that RDG one.
Pete Savage19/09/2019 19:24:10
23 forum posts
8 photos
Yes, they ended up special delivering me one out for 4 quid postage which wasn't bad! Only ordered it yesterday!
Pete Savage20/09/2019 10:27:46
23 forum posts
8 photos
It was branded TWT UK, never heard of them but looked of decent finish etc.
Pete Savage20/09/2019 14:56:25
23 forum posts
8 photos
The nut worked amazingly even without any anti backlash mechanism. The handwheel free spins about 0.01mm worth which isn't too bad.
Edited By Pete Savage on 20/09/2019 14:57:34
