Myford 254 thread dial indicator
Philip Slater08/09/2019 19:03:38
22 forum posts
Hi
Would anybody be able to tell me where I can obtain a thread dial indicator for the the Myford 254 please.
Philip Slater09/09/2019 09:47:34
22 forum posts
Hello again I'm guessing from the lack of response that thread dial indicators are not available anymore. Certainly all the Google searches that I've done don't show anything, plenty of Myford super 7 TDIs but nothing for the the 254.
Is it feasible to cut threads by closing the leadscrew half nuts and using forward and reverse motor directions for each cut. Obviously not disengaging the half nuts until the threads complete. I've got a DC brake fitted to the lathe which stops the chuck instantaneously.
Neil Wyatt09/09/2019 10:46:57
18894 forum posts
734 photos
80 articles
Posted by Philip Slater on 09/09/2019 09:47:34:
That's the usual way; reversible lathes are often supplied without thread cutting indicators.
Philip Slater09/09/2019 11:14:56
22 forum posts
Thanks for that. Maybe not so good on the motor and all the switch gear but looks like the only way out.
Phil
not done it yet09/09/2019 11:27:57
6518 forum posts
20 photos
Nearly everyone with a metric lathe needing to cut imperial threads do it that way. Same for those with imperial lathes who wish to cut metric threads...
Clive Hartland09/09/2019 12:19:39
2758 forum posts
40 photos
I have the sales brochure and available parts for the 254. the part. no. 95/136 for metric threads, in the listings priced at £100.81.
Note. it is only for use with metric threads. it goes on to say that if used with the imperial conversion set. 95/078 on a 254 lathe the leadscrew nut must remain engaged.the part no. for the imperial thread ind. iis 95/105 and cost £36.89.
Hope this is some help Clive
speelwerk09/09/2019 12:38:45
429 forum posts
Is it not possible that the imperial TDI is the same as used on the 7 series? Niko.
Philip Slater09/09/2019 17:15:36
22 forum posts
Thanks Clive I'm assuming the sales brochure you have is from when the lathe was in production or are you suggesting that the parts are still available, in which case I'm all excited. My lathe is metric I had a similar thought that the 7 series TDI might be compatible but it's a 3mm pitch leadscrew.
lfoggy09/09/2019 17:34:47
174 forum posts
17 photos
I have a metric 254 with the 3mm pitch leadscrew and it has an indicator fitted for cutting metric threads. It is a simple device and it would be possible to make one. It is basically a metal body which holds a gear against the leadscrew. There are two gears to choose from (28 and 30 tooth) depending on what pitch you are cutting. There is a dial with divisions connected to the gears that then indicates when to re-engage the half nuts. The metal body would be basic machining and you would need to be able to cut the gears You would need to find an original to copy, particularly for the divisions on the dial.
If you are anywhere near Birmingham you are welcome to inspect and measure up mine....
Philip Slater09/09/2019 19:09:58
22 forum posts
Thanks for the offer Ifoggy I'm up in North Lincolnshire so a bit far to travel. I've never machined gears but I've got a milling machine so have the tools. Thinking aloud I wonder if I could machine the gears from Tufnel. Not sure what you mean by having 2 gears, are you saying you need to change gears on the Thread dial indicator?
DC31k09/09/2019 19:57:59
586 forum posts
Posted by Philip Slater on 09/09/2019 19:09:58:
Do not be alarmed: a thread dial indicator is in no way a precision mechanical device. Almost any kind of tooth shape will work; the important thing being the number of teeth (even so far as straight gashes around the perimeter of a thin gear.
You would do very well to buy Martin Cleeve's book on screwcutting as it probably the most concentrated source of information on leadscrew indicators out there. You can also search this site (using Google with site:model-engineer.co.uk as part of the query string - since the forum search is totally useless) as the subject has been done to death here as well.
Very briefly, thread dial indicators for an imperial leadscrew are very simple because of the way imperial threads are defined (teeth per inch) and one gear will do all pitches.
TDI for metric leadscrews are more complicated because metric threads are defined by pitch. One gear will not do all pitches. However, in some ways metric pitches are simpler because any pitch that is a factor of the leadscrew pitch does not need an indicator at all - you can drop the nuts in anywhere they will engage.
For your 3mm pitch leadscrew, this means 3.0, 1.5, 1.0, 0.75, 0.6, 0.5, 0.3, 0.25 and 0.2 pitch threads do not need a gear. The remaining common ones (especially 1.25 and 1.75) will need an indicator gear (1.25 needs a gear with teeth 'by fives' and 1.75 needs a gear with teeth 'by sevens'.
Philip Slater09/09/2019 20:04:30
22 forum posts
Very interesting. As your probably realising I still consider myself a novice when it come to machining. Looks like I need to be getting that book you mention. Thanks for the input.
Clive Hartland09/09/2019 21:48:02
2758 forum posts
40 photos
Hi Phil, the brochures are 1999 vintage so not current and as you say the lathe is out of production.
I had just purchased an ML10 so wanted the brochures to get bits I wanted.
ian j09/09/2019 22:51:52
307 forum posts
285 photos
Phil.
May be worth emailing David of "Quillstar" as he says on his web site
A few 254 bits including lathe beds, aprons, tailstocks, screws, nuts, dials etc. "
http://www.quillstar.co.uk/
Quillstar
not done it yet09/09/2019 23:50:13
6518 forum posts
20 photos
Using a plastic gear against the lead screw would reduce any risk of wearing the lead screw. A spur gear will wear in OK as there is no real load on it.
lfoggy09/09/2019 23:52:44
174 forum posts
17 photos
There are two gears on the indicator and you choose the one appropriate for the pitch you are cutting. The gear is selected by undoing a nut, removing and replacing the gear. As stated above, as long as the tooth count is correct it wont matter too much if the tooth profile on the gears is not perfect. If you are planning to do a lot of thread cutting I think making an indicator is definitely a realistic prospect.
Thor 🇳🇴10/09/2019 05:14:41
1480 forum posts
41 photos
I used Delrin to make a 28T gear wheel for my metric lathe (3mm pitch leadscrew), it has worked well for many years so Tufnol (sheet) should work well. A 30T gear was supplied with my Thread Dial Indicator.
Thor
Edited By Thor on 10/09/2019 05:15:01
ian j23/11/2019 20:26:53
307 forum posts
285 photos
Phil. I've just spotted this one on ebay:
0sAAOSwXrld1ua~">Myford 254 thread indicate
IanH24/11/2019 08:36:54
112 forum posts
65 photos
Hi,
I have an imperial 254 in Cheshire if you want a look.
Ian
Derek Greenhalgh13/04/2020 14:00:15
26 forum posts
4 photos
Some very helpfull information in this thread for all I don't have the said lathe, mine is an HBM 250g with a metric 3mm lead screw that came without a thread dial. It also came with a gear to change to imperial threading.
Reading the thread it seams i can make a thread dial, disengaged for most metric threads but with a 20 and 21 tooth gear engaged I'm covered for 1.25 and 1.75 metric pitches that are very common
what gear cutter would i need to cut a gear compatible with a 3mm pitch lead screw? if I'm on the right track its like a 3mm rack as in rack and pinion. In effect i have the 3mm rack(lead screw) so all i need to do is make the pinion and skew it a couple of degrees to get it to mesh better
I have never made a gear before but have a mill, rotary table with chuck and tailstock, The gear cutters for metric are identified M0.5 M1 M2 etc in sets of 8, how do you work out which set I need to match the 3mm pitch? It would be nice to have them all but they are not cheap.
thanks
Derek
walker midge
JD Metals
rapid Direct
