Screaming brass
JA04/09/2019 19:04:53
962 forum posts
52 photos
Just a simple question - When turning brass, why does it scream?
I apologise if this has been asked before.
JA
Neil Wyatt04/09/2019 19:31:53
18143 forum posts
713 photos
77 articles
Good question!
I would guess it's because it fractures into tiny similar-sized chips that can set up a vibration, rather than longer swarf.
Interested in other people's ideas!
old mart04/09/2019 21:02:35
1923 forum posts
151 photos
Leaded brass is the type that can be noisy, and those tiny chips are worse than cast iron dust.
Michael Gilligan04/09/2019 22:08:38
16214 forum posts
707 photos
Posted by Neil Wyatt on 04/09/2019 19:31:53:
Good question!
I think you are essentially correct, Neil ... but also that the problem can be exacerbated by inappropriate rake angle. Brass is usually 'happier' with either zero or negative rake.
IanT04/09/2019 22:26:14
1581 forum posts
145 photos
Yes, perhaps you are making it 'unhappy' JA.
IanT
JA04/09/2019 22:33:40
962 forum posts
52 photos
Posted by IanT on 04/09/2019 22:26:14:
IanT
I accept that. I am cutting it.
I use a very slight positive rake. This cuts well and cleanly.
JA
Edited By JA on 04/09/2019 22:37:24
Michael Gilligan04/09/2019 22:56:56
16214 forum posts
707 photos
I've just found this old thread from 2012, which might be of interest: **LINK**
https://www.model-engineer.co.uk/forums/postings.asp?th=65244&p=1
fizzy05/09/2019 08:07:52
1725 forum posts
116 photos
Hi. I turn brass pretty much every day and have never ever had it make any noise - nothing. I can only assume its a special grade or that your tool is rubbing not cutting. I find tips for steel useless as they sheer rather than cut, prefering very sharp inserts instead. Im making a batch of chimney collars today, all brass.
JA05/09/2019 10:12:38
962 forum posts
52 photos
fizzy
What grades of brass do you use?
I have always expected brass to squeal or scream irrespective of the lathe. However I am beginning to realise most of my experience is with CZ.121 bar (leaded free cutting brass).
JA
fizzy05/09/2019 10:30:22
1725 forum posts
116 photos
JA
Its cz121, it gets used on my boilers for burners and chimney parts and I use a lot of it up to 3" diameter down to 1/4" diameter. It honestly never makes so much as a squeek and I sometimes run it extremely hard in terms of cut depth and feed (you know its OTT when the 3/4" boring bar starts to bend!). What I have learned is to cut it at a relatively low turn speed. Ive got a fixed high speed lathe which refuses to cut brass. I now always use ccmt super sharp inserts, they cut very cleanly. If you are near me I would gladly help you resolve this issue hands on?
Nigel (Pendle Steam Boilers)
not done it yet05/09/2019 11:04:10
4905 forum posts
20 photos
Perhaps the younger members are more ‘prone’ to notice this phenomenon?
I cut brass at times and rarely have had more than normal chatter at extremes of the cutting envelope.
But, there again, I am oblivious to anything much over 8-9kHz, probably due in part to shooting, driving D8 Caterpillar earth movers, working in an extremely noisy industrial environments, along with probable genetic and age related hearing impediment!
I was often dragged in as the college ‘dummy’ when audible range (and colour blindness tests) were carried out for the student’s demonstrations! The physics and biology GCSE tutors would carefully organise those lessons for when I had free time, if they could!
Mick B105/09/2019 13:15:34
1667 forum posts
88 photos
Have you tried reducing tool protrusion or increasing its thickness or stiffness to reduce the risk or resonant micro-deflections causing the squeal?
I've certainly heard brass squeal but if I do it's because summat ain't right, and I'll fix it before carrying on. IME rake angle within normal limits for general use doesn't make a lot of difference, although a zero rake platform on twist drill lips cut the risk of snatch on breakthrough. I can't readily think of a case where it hasn't resolved to a rigidity issue and/or a blunt/rubbing tool edge.
Neil Wyatt05/09/2019 14:14:05
18143 forum posts
713 photos
77 articles
I'm minded to think of Kundt's Tube which relies on a brass rod and a rosined cloth.
Martin Hamilton 105/09/2019 14:47:39
179 forum posts
If i am looking for a mirror finish on brass off the tool i use HSS with either zero rake or negative rake for an even better finish still. If not being quite as fussy on finish but still a very good finish indeed or roughing down brass i use the excellent aluminium inserts.
JA05/09/2019 17:25:22
962 forum posts
52 photos
Many thanks for the comments.
As already stated I do not have a problem machining brass. It is easy and the finish is good to excellent. It is just the noise.
When I have a spare moment on the lathe (not in the next few days) I will put a 1" diameter bar in my biggest four jaw chuck and take a number of 0.030" deep cuts using my existing tool (left hand knife with about 5 degrees of top rake) and a similar zero degree top rake tool at various speeds and tool overhang. Photographs of the finish will be taken and I will report back.
I don't really want to spend time on this since it is not a problem!
Nigel, thanks for the offer but I am just outside Bristol.
JA
Edited By JA on 05/09/2019 17:26:36
EngineDIY
