Which ignition system for 1/4 x 32 spark plug
Richard Cox29/08/2019 12:31:13
44 forum posts
15 photos
Hi what ignition system of the rcexl style would you recommend as I can only find ones suitable for the bigger plugs it’s for a Nemett Lynx 15cc
Rich
pgk pgk29/08/2019 12:44:23
1729 forum posts
287 photos
Any help:
hobbyking
JasonB29/08/2019 13:00:38
17856 forum posts
1954 photos
I went with the one from S/S in the states, have used them quite a bit on the hit and miss engines too, they do a nice neat plug boot for the small 1/4 x 32 plugs and small diameter silicon insulated wire not that ugly braided stuff.
You could also look at Minimag's offerings like the MCL1 which would work OK
A lot of of the Rcexl systems have auto advance that does not work well on these engines.
Roger B29/08/2019 14:28:25
96 forum posts
41 photos
The RCexl systems will work but the sensor needs to be on the crankshaft, not on the camshaft, as these are designed for 2 stoke engines. The wasted spark on the other TDC is not a problem as there is no combusible mixture.
They start with full advance, 28°, which drops to 4° at around 400rpm and then starts rising at 1000rpm reaching full advance again at 4000rpm. This should be ok for a Lynx but is not suitable for low speed hit and miss type engines.
1/4-32 versions are available from Just Engines and I assume other suppliers.
Best regards
Roger
Richard Cox29/08/2019 19:50:13
44 forum posts
15 photos
Jason the cap and wire is ugly on the rcexl and out of proportion I will have a look into the ss type thanks
Rich
Richard Cox29/08/2019 19:51:24
44 forum posts
15 photos
Thanks roger relating to the sensor issue I did think of adding two magnets 180 degrees opposed on a disc on the cam and run it as a wasted spark potentially
Rich
Roger B30/08/2019 07:31:47
96 forum posts
41 photos
The RCexl screened cable and plug cap are probably necessary if you are flying the engine in an RC aircraft but as you say otherwise somewhat bulky.
Best regards
Roger
JasonB30/08/2019 07:36:37
17856 forum posts
1954 photos
They use the screen and outer metal casing of the cap as the ground, S/S and Minimag have a separate small wire
