Just for fun what’s this stuck in my tyre?
Ian Parkin27/08/2019 22:03:19
995 forum posts
235 photos
I noticed this the other day stuck in my tyre driven about 50 miles on it...still held air over the bank holiday weekend
what was revealed when the fitter removed the tyre ?
Answer tommorow
David Davies 827/08/2019 22:10:33
152 forum posts
9 photos
'Sparklet' CO2 cartridge? Blunt end of course!
Harry Wilkes27/08/2019 22:16:51
1262 forum posts
64 photos
Mini grinding stone
Jeff Dayman27/08/2019 22:20:55
2200 forum posts
45 photos
Looks like a Smith and Wesson .44 round. Is Clint Eastwood filming anywhere nearby?
Neil Wyatt27/08/2019 22:40:39
18894 forum posts
734 photos
80 articles
Dinosaur tooth
Phil P27/08/2019 23:05:04
792 forum posts
194 photos
Dunno what that is, but I had a bizzare puncture the other day that cost me a new tyre. It had 4" nail through it.
Now that may not sound all that strange, until I tell you the head was inside the tyre with the pointy bit on the outside. work that one out ?
Phil
ken king, King Design27/08/2019 23:52:11
144 forum posts
239 photos
I would guess a golf tee.
vintage engineer27/08/2019 23:55:37
254 forum posts
Ragbolt
I.M. OUTAHERE28/08/2019 00:43:48
1468 forum posts
Cap screw or torx screw .
I once had a 6mm hex driver punch a hole a tyre - it was the long type you use in a drill/driver , the front tyre must have flicked it up when it ran over it and it landed at just tue right angle for it to puncture the back tyre . The other one was when i got a new car i took the entry to my drive a fraction wider than usual and as my water meter is buried in a cut out in the concrete driveway i ran over it and the shaft for the shut off valve went straight through a brand new tyre - i have now fabricated a cover for the meter !
Enough!28/08/2019 00:58:43
1719 forum posts
It's the tip of Clint Eastwood's finger which got sheared off when you drove into him in his wheelchair.
wink
Jeff Dayman28/08/2019 03:31:54
2200 forum posts
45 photos
yessmiley
Brian G28/08/2019 08:19:14
805 forum posts
35 photos
This was annoying as with a Smart I had no spare tyre.
Spark Plug
Nicholas Farr28/08/2019 08:32:18
3137 forum posts
1432 photos
Hi, I recon a socket head bolt.
Regards Nick.
Mick B128/08/2019 08:43:25
2084 forum posts
121 photos
Posted by Neil Wyatt on 27/08/2019 22:40:39:
Dinosaur tooth
Triassic belemnite?
Ian Parkin28/08/2019 09:23:55
995 forum posts
235 photos
David Davies was right straight away
a NO cylinder
David Standing 128/08/2019 09:58:10
1297 forum posts
50 photos
Ah, 'hippy crack', N2O - you have no doubt parked in a quiet corner of a public car park, where the sniffers gather.
I suspect some smart Alec deliberately wedged it under your tyre at an angle, so it did what it did and penetrated the tyre.
Ian Parkin28/08/2019 10:18:07
995 forum posts
235 photos
David i did wonder if someone had done that
but up here in the north the streets are littered with the little blighters
David Standing 128/08/2019 10:30:57
1297 forum posts
50 photos
Ian
Plenty down here too!
My guess it was wedged deliberately - their shape means it is unlikely one will flip up if driven over.
Did you park in a multi storey car park prior to discovering it?
KWIL28/08/2019 12:26:01
3477 forum posts
66 photos
Pointy end just right for wedging in the tread gap, my guess deliberate.
David Davies 828/08/2019 12:27:30
152 forum posts
9 photos
Ian
Can I claim my prize? Someone said it is a Hardinge HLV-H lathe?
Seriously, the gutters are littered with these cartridges around the Cardiff/Newport area. I see them lying there as I cycle in to work.
Is your Comet back in one piece now?
Cheers
walker midge
rapid Direct
JD Metals
