Scale gauges
merlin21/08/2019 18:38:32
141 forum posts
1 photos
I dare hardly show my ignorance of this subject on this forum, but after years of rubbing shoulders with clever model railway engineers I have realised that I don't know what eg 71/4" gauge means. Is it the inside measurement between rails? Are the enginese and stock to 71/4" to the foot? Wikipedia tells me so much that I become confused.
Years ago I walked the footpath past the McAlpine house near Henley and could see the layout throught he trees; it is this gauge that interests me.
not done it yet21/08/2019 19:04:54
3911 forum posts
15 photos
First hit on ‘goggle’, from Ride on Railways, says distance between the rails, not scale.
Good enough for me.
Bill Chugg21/08/2019 19:47:56
962 forum posts
6 photos
As ndiy confirms, gauge is distance between rail inner to rail inner, so 7.25 inch in your post
7,25 inch locos and rolling stock are built to a scale of 1.5 inches equals 1 foot.
Going down in size, 5 inch gauge locos are built to a scale of 1 inch to the foot and 3.5 inch gauge locos are 3/4 inch to the foot.
The railway you mention as far as I recall was standard gauge 4ft 8.5 inch
Bill
Edited By 34046 on 21/08/2019 20:16:36
Howard Lewis22/08/2019 09:44:02
2699 forum posts
2 photos
The gauge of the railway on the estate of the late Sir William McAlpine, at Fawley Hill, is the standard 4 ft 8.5 inch.
Bill Chugg22/08/2019 10:13:00
962 forum posts
6 photos
Posted by Howard Lewis on 22/08/2019 09:44:02:
Thanks for confirming Howard.
Bill
SillyOldDuffer22/08/2019 10:44:15
5119 forum posts
1073 photos
Posted by 34046 on 21/08/2019 19:47:56:
Bill
Like Merlin I'm confused slightly by scale and gauge.
A scale of 1½" to 1' is 1:8 so standard gauge ( 4'8½" ) rail track should be modelled 7¹⁄₁₆" apart. Not that it makes any difference, but why jump to 7¼" or even 7½" as is popular in the USA?
Edited By SillyOldDuffer on 22/08/2019 10:45:12
Bill Chugg22/08/2019 11:08:02
962 forum posts
6 photos
Posted by SillyOldDuffer on 22/08/2019 10:44:15:
Bill
You are quite correct in what you say but it is rounded up or down to make it easier - it is not an exact science.
Not sure why USA have 7.5 but will see if I can find out.
It took me along time to get my head around it all .
Bill
Bill Chugg22/08/2019 11:18:41
962 forum posts
6 photos
Dave, to take your point on scale a stage further.
1 inch to the foot scale in Uk runs on 5 inch gauge track
Mathematically this equates to 4.75 inch gauge.
Canada and USA run on these track widths - so a bit of regauging required if in USA and you buy a Uk loco from a UK dealer ?
Bill
Bill Chugg22/08/2019 11:32:44
962 forum posts
6 photos
Dave - ref your accurate 7 and 1/16 calculation.
3/4 inch scale run on 3.5 gauge track
1.5 inch ie 0.75 x 2 equates to 3.5 x 2 ie 7 inches so why 7.25 in UK ?
Standardisation would make life simpler.
Bill
JasonB22/08/2019 11:43:23
17028 forum posts
1825 photos
1 articles
Then the whole scale thing goes out the window when you put narrow gauge models onto standard gauge based track widths
For example a 2ft narrow gauge model built to run on 7.25" track is approx 1/3rd scale or 4" to the foot.
Ron Colvin22/08/2019 12:08:48
58 forum posts
3 photos
Bill
With passenger hauling model locomotives it is the gauge that is important, the scale is nominal. If someone is a stickler for having a correct scale/gauge ratio, they can tweak the scale accordingly. With small scale scenic model railways the scale is generally kept constant, and it is the gauge that is adjusted by the purist.
Bill Chugg22/08/2019 12:40:53
962 forum posts
6 photos
That is interesting Ron
i always understood back along when I spoke to Reeves that drawings for locos were drawn to scale ie 0.75 inch for 3.5 gauge, 1 inch for 5 gauge and 1.5 for 7.25 gauge ?
Is this correct please ?
Bill
Perko722/08/2019 13:04:16
291 forum posts
23 photos
In Australia some 5-inch gauge models of standard (4ft 8-1/2inch) gauge locos are built to a scale of 1-1/16inch to get the scale/gauge proportions correct. Like model railways there are always compromises to be made, either for ease of construction, or to provide greater clearances, or because a scale reduction of actual dimensions would not provide sufficient tolerances or clearances for satisfactory operation. As others have said, narrow-gauge prototypes have different scale/gauge combinations. My model of a 3ft6inch gauge Queensland loco is built to 1-1/2inch scale to run on 5inch gauge track. It's not exactly correct, but I'm not going to use a scale of 1-27/64inch just to make it so.
I don't know where or when the adoption of 7-1/4inch gauge occurred in the UK and Australia, but that is what has become common use so we adjust the necessary dimensions to suit the 'slightly wider than scale' track gauge while keeping the rest of the loco to scale.
Ron Colvin22/08/2019 14:01:47
58 forum posts
3 photos
Posted by 34046 on 22/08/2019 12:40:53:
Bill
More likely that someone who has chosen to build with a correct scale/gauge ratio has decided to build a model of a prototype for which no drawings or castings are available. There is a lot of extra design/drawing work involved in producing a more authentic representative of a given locomotive from a published standard design. For example see the current ME series of articles by Doug Hewson on updating LBSC's pannier tank locomotive "Pansy".
John Baguley22/08/2019 16:19:40
450 forum posts
48 photos
The scales and gauges were standardised way back in Henry Greenly's day. Standard gauge locos in 2½" gauge were originall built to a scale of 1/2" to the foot but this later became 17/32" to the foot to give more accurate proportions. As stated, Standard 3-1/2" gauge is a scale of 3/4" to the foot and 5" gauge is 1-1/16" to the foot. The Americans etc. mostly use 4-3/4" gauge which is 1" to the foot. 5" gauge in the USA is rare.
It's often stated that the American 7-1/2" gauge came about because of a mistake by someone as they did originally use 7-1/4".
Neil Wyatt22/08/2019 16:35:32
17050 forum posts
690 photos
76 articles
Posted by John Baguley on 22/08/2019 16:19:40:
Logic is in short supply with regard to gauges and scales in railway modelling... probably because the strange standard gauge of 4'8.5" doesn't scale accurately to anything convenient.
7 1/2 and 7 1/4 are found in the USA, although 7 1/2 is more common.
One thing I don't understand is that, for example, both 3 1/2" and 5" gauge locos happily run on the same dual gauge tracks. So why not use 3 1/2" gauge flanges on 5" gauge models to get a more scale appearance? I can see this might be a step too far for 7 1/4" gauge, but surely they would get away with 5" flanges?
I bear in mind that large 3 1/2" wheels are bigger than small 5" gauge ones...
Bazyle22/08/2019 17:48:34
4888 forum posts
195 photos
Posted by Neil Wyatt on 22/08/2019 16:35:32:
There is a sort of logic. Starting with G1 the gauges go up or down in a ration of root 2 so that the size of your model railway doubled or halved. That exact ratio was then rounded to a convenient, mostly imperial, dimension because most people didn't have a Babbage machine in their back room to do the scaling.
Also since G1 was started by those pesky Germans the Brits invented G2 to be 2in rail gauge which of course was logical at the time and is why 2 1/2 had to be called G3.
Then awkward people got in on the act and wanted things to be more accurate than cheap tinplate pressings so every size got split and some models can even be one scale at one end and another at the other.
Ron Colvin22/08/2019 18:37:41
58 forum posts
3 photos
The origin of having a set of standard gauges was introduced by a toy manufacturer in 1891 (Märklin ) . They were gauges numbered 1 to 5
Number 1 gauge = 45mm
Number 2 gauge = 54mm
Number 3 gauge = 67mm
Number 4 gauge = 75mm
Number 5 gauge = 120mm
The only one that has remained to its original dimension is gauge 1.
Bill Chugg22/08/2019 18:47:22
962 forum posts
6 photos
Posted by Ron Colvin on 22/08/2019 18:37:41:
And yet they waited until 1893 before they brought out their 0 gauge loco for some unknown raeson ?
Bill
Brian G22/08/2019 19:52:03
650 forum posts
25 photos
Posted by 34046 on 22/08/2019 18:47:22:
Bill
According to NEM10 issued by MOROP the current large scale gauges and scales are:
0 32mm (No equivalent stated) at 1:45 (7mm/ft is 1:43.5)
I 45mm (1 3/4" at 1:32 (G1MRA standard 10mm/ft is 1:30.5)
II 64mm (2 1/2" at 1:22.5 (Gauge 3 in the UK)
III 89mm (3 1/2" at 1:16
V 127mm (5" at 1:11 (but we use 1:12 in the UK)
VII 184mm (7 1/4" at 1:8
X 184mm (10 1/4" at 1:5.5
Personally, I won't lose any sleep over these differences, I quite enjoyed riding on the RHDR today, and wasn't worried about 1/3 scale locos running on 1/4 scale track.
Brian
Ausee.com.au
