Myford
Felt ?
john brown 1718/08/2019 18:59:48
114 forum posts
The bed scaper on the myford needs replacing ,the one on it is felt,am thinking of using leather,my southbend seems happy with leather,any opinions please.
HOWARDT18/08/2019 19:07:18
556 forum posts
15 photos
Industrial bed wipers are rubber as their function is to wipe off coolant and swarf as the saddle travels, lubrication is fed through the saddle, so two separate systems. Felt can be oil filled but can also retain small swarf particles, leather can be soaked in oil to a degree and is probably less prone to swarf retention. Either will do the job, but I think neither is ideal.
john brown 1718/08/2019 20:07:41
114 forum posts
Well thanks for that ,in fact l do have some rubber that l could make the wiper from,will give that ago,but as l said the leather ones on the southbend work great,myford just sell the felt ones still.
Pete Rimmer18/08/2019 20:13:18
711 forum posts
49 photos
More modern machines might have rubber wipers but traditionally they are mostly felt for all sizes of lathe.
Rod Renshaw18/08/2019 21:22:45
93 forum posts
These felts are still available for Myford 7s.
I understand that you can make your own and that chiropody felt ,available on the web, is a good material to use.
Rod
Mark Gould 121/08/2019 11:09:10
212 forum posts
120 photos
If you decide to make them yourself, here are the dimensions you require. You’ll have to scroll down 3 or 4 posts to see the drawing. I think thats valid for both ML7 and S7 lathes.
Edited By Mark Gould 1 on 21/08/2019 11:11:20
Baz21/08/2019 11:24:37
374 forum posts
Home and workshop machinery sell the proper thing, described as bridge or rifle type, look on their website, I believe they are the remaining stock from the Myford factory. Why bother wasting time making some when the correct thing is available off the shelf?
