4 jaw chuck axial allignment
Martin of Wick17/08/2019 18:31:26
245 forum posts
5 photos
How is one supposed to set either stock for machining, or work undergoing second operations to run to a true axis within the 4 jaw chuck?
Radial setting - no problem I can set up to les than half a thou TIR, on a point but move the DTI out or back along the work and the run-out can quite literally go 'off the clock' especially when working with 4 or 5 inch stock.
There must be a way to set up for a true axis but I can find no reference to this problem in my meagre stock of literature. It is causing me some stress at the moment as no amount of nudging, thumping, hammering of the work piece or praying and swearing seems to be helping me set the work to run true down the axis. When I set zero TIR adjacent to the chuck the tailstock end goes out of true. If I clock in the tailstock end, I find the chuck end is now off centre. OOOF!
I thought that one of the great benefits of the 4 jaw was the ability to clock in a repeat setting - but how is that achieved without some reliable way to get the axis running true?
I clearly have a major learning gap here, so would be very interested to learn what approach others have used.
Pete Rimmer17/08/2019 19:03:09
1127 forum posts
70 photos
Start with a faced-off part and use a dial gauge on the face to check it every time you clock it in radially. Or keep the faced-off face against the chuck and keep it there with a dead blow when dialling in the OD.
not done it yet17/08/2019 19:18:50
6518 forum posts
20 photos
And in addition to PR, use a centre on the original if replacing it in the same orientation. Turning between centres is the ultimate, I suppose.
John P17/08/2019 19:35:23
360 forum posts
238 photos
The jaw faces are not parallel to the lathe axis use a pencil grinder held in the top slide and regrind each jaw face in turn in situ not under power, you will need to apply an inward load to the jaw to stabilize .Not much needs to be ground off mark with a felt tip pen to see the grinding along the jaw length.
Michael Gilligan17/08/2019 19:39:26
19589 forum posts
997 photos
Posted by Martin of Wick on 17/08/2019 18:31:26:
I regret to say that you are probably describing a defect of your chuck.
In a perfect world, the gripping faces of all four jaws would be parrallel to the lathe axis, and would remain so at every setting.
Clearly, we do not live in a perfect world and some chucks are further from perfection than others.
To the best of my knowledge, there is no 'adjustment' available to overcome your difficulty ... 'though you might consider grinding the jaws in-situ, to effect a general improvement.
Edit: John has described the grinding process.
Edited By Michael Gilligan on 17/08/2019 19:41:13
Peter Tucker17/08/2019 19:39:57
183 forum posts
Hi Martin,
Did you make sure the mating faces between the chuck and lathe spindle were scrupulously clean before you assembled them, tiny particle of swarf can throw your chuck out.
If the mating faces between chuck and spindle are clean check that the face of the spindle is running true.
If the lath/chuck is old/secondhand the chuck jaws may be out of alignment ( knackered).
Hope this helps.
Peter.
JasonB17/08/2019 19:45:15
21999 forum posts
2539 photos
Provided your chuck face is true then this can help. useful when putting stock that is sawn on both ends into the 4-jaw.
Firefly46
Clive Brown 117/08/2019 20:13:08
747 forum posts
37 photos
I think you're asking a lot for many 4-jaw chucks, especially well used ones.
Can you arrange your machining sequence to drill an accurate centre hole in what will be the RH end of the workpiece? This might need a reasonably sized bore through the mandrel.
If so, grip the LH end in the 4-jaw, with not too much jaw engagement and adjust to run true while the RH end is centred by a tailstock mounted centre, preferably a live centre.
duncan webster17/08/2019 20:44:37
3706 forum posts
69 photos
use a small length of engagement, set true near the chuck, then move the dti to the far end and set it true by tapping it with a lead weight, then go back to the chuck end, repeat till you get fed up
old mart17/08/2019 21:05:56
3510 forum posts
216 photos
If your chuck is on a backplate, separate them and check the face of the plate. Double check the cleanliness of the fitting to the lathe spindle before any skimming of the faceplate.
Before doing anything, remove the jaws and check that the face of the chuck body is true with a dti.
Edited By old mart on 17/08/2019 21:09:03
Mikelkie17/08/2019 22:20:46
127 forum posts
13 photos
Posted by duncan webster on 17/08/2019 20:44:37:
I like your last six wordslaugh
Mick B117/08/2019 22:46:28
2084 forum posts
121 photos
Posted by Mikelkie on 17/08/2019 22:20:46:
Exactly.
Or why not run a clock along the inside of the chuck jaws and see if they're parallel to the carriage motion? My guess is they'll be well out.
Michael Gilligan17/08/2019 23:36:13
19589 forum posts
997 photos
Posted by Mick B1 on 17/08/2019 22:46:28:
Because the jaws will not be in their 'clamped' alignment when they are accessible to be clocked.
That's O.K. if all the error is in the actual jaws ... but I bet some of it is sloppy fit of the jaws in their slots.
Martin of Wick17/08/2019 23:50:43
245 forum posts
5 photos
Thanks for all the feedback and some very good advice.
I didn't want to blame the tools, so was kind of in denial about the possibility of the chuck being bad ( 4 jaw came with new machine and had been unused until recently so had assumed it would be as good as the 3 jaw).
Subsequent to MG's and other posts I had a bit of an investigation. Checking jaws 2 by 2 clamped on some silver steel showed beyond any shadow of a doubt the jaws were absolutely diabolical. Not only was the grip wobbly and insecure in the plane of the pair of jaws, but clocking the steel bar showed 20-25 thou off axis over 3 inches for one pair and the other pair could be set at almost any position you like, none of which gave a true axis.
Checking against a backlit straight edge was utterly disheartening - some jaws were convex, some hollowed, others had uneven teeth (serrated jaws). A new chuck!! If you wanted to make one as bad as this it would actually be quite hard work Doh!.
Other parameters like spindle TIR checked out at half a thou and half thou wobble on the spindle plate mounting which is bit disappointing but probably OK for a CML. Slightly concerned, for as I recall there was almost undetectable run out when I unboxed the new machine 18 months ago and it has been fitted with angular contact bearings.
So replaced what is now a large heavy paperweight with the original 3 jaw that I had recently spurned for having a totally outrageous 1.5 thou TIR and an axial drift of half a thou over 6 inches. Incidentally, both chucks are from the same 'no name' manufacturer (orbiting stars brand from the logo!).
A new chuck is called for I think. I quite like the idea of attempting to re-grind but is a bit of a scary prospect, although difficult to see how any remedial action could make this specimen any worse..
At the moment all I would like to do is throw the chuck at the head of person that QA'd it. Interestingly, the gaudy check sheet that came with the chuck gives expected parameters for run out on the various planes and axis, but has no data for a chucked test bar (like the 3 Jaw has). Why is that I wonder!!!
Thanks again to all for your help.
Michael Gilligan18/08/2019 00:17:02
19589 forum posts
997 photos
Deepest sympathy, Martin
One perfectly practical thing you could do with the 'paperweight' is ditch the jaws and screws, and use it as a tee-slotted faceplate.
... Then you could make some 'dogs' to fit the slots [which is, of course, what the independent 4-jaw chuck evolved from]
Meanwhile, it's probably time for some sleep.
Vasantha Abey18/08/2019 05:47:47
16 forum posts
Dear ,
It may be your headstock is misaligned by a few 1/00 degree, ie not 90 degree to the bedways.
You can adjust this by removing all the jaws from the chuck, fix a dial gauge to touch the chuck face, let the gauge start reading a max of 10 thous after touching. This will make sure the dial gauge tip but will not unnecessarily get stuck on the circular grooves on the chuck faces when you move your cross slide forward and backwards. These grooves help one to center the jaws quickly by observing those line relative to the jaw end position.
if your chuck face is not perpendicular to the bed you will find a variation on the dial reading.
loosen the bolts that clamp the Head stock to the bed, give a smart tap on the head and it will move a few thou till you get the reading constant. Tighten the bolts and you are on. Your problem could be this.
with love from Sri Lanka, a 75 year guy.
Neil Lickfold18/08/2019 07:30:42
754 forum posts
129 photos
Using a finger type DTI can help in setting the swash of the part on the side of the jaws if it has a flange to reference from. If it is a piece that has flat sides, then running an indicator up and down the length is the only way to check it is running true. You have to spend Serious money on a 4 jaw chuck that can hold flat stock true to the run of the chuck. Another option is to use sacrificial pads that are used to hold the part. Then it can be held and as you indicate the length, tap it true at the free end. It can take some time to set up some jobs and not that long with others. Having more than 1 indicator can be helpful, as well as 2 keys for the 4jaw chuck.
Brian G18/08/2019 07:49:56
805 forum posts
35 photos
I've done this using a soft-faced hammer before drilling a centre on a long workpiece, but wonder if it would be easier just to make a bump centring tool (basically a knurling tool fitted with a roller bearing instead of a knurl).
JasonB18/08/2019 07:59:42
21999 forum posts
2539 photos
As Nick says more than one dti or dti and square as I showed above may be needed. Although good jaws help it makes little difference how true the faces are if you are trying to hold a cast part as the surface you are gripping is unlikely to be true to the parts axis. Same applies to short large diameter work where you will need to clock it for wobble as well as eccentricity, eg large flywheels. This is where Dubcan's tap-test-tap-etc come in.
See how little jaw contact there is on the uneven cast inside of the rim, would not make any difference with the jaws you have or true one sin cases like this.
Michael Gilligan18/08/2019 08:44:27
19589 forum posts
997 photos
Posted by JasonB on 18/08/2019 07:59:42:
Jason,
Your example shows the chuck holding a 'short' workpiece ... which is perfectly reasonable, but does not address the issue that Martin described in his opening post
[quote]
[/quote]
Do you consider it over-ambitious for him to want to work on a five inch length of [modest diameter] material ?
walker midge
rapid Direct
JD Metals
