Heartbroken!
Brian H16/08/2019 15:18:33
2147 forum posts
113 photos
As is the 8BA Plug tap that is broken in a 1/8" inch deep blind hole!
Any (sensible) suggestions welcome, as is an offer of spark erosion near Mansfield with a financial contribution from me.
Please don't suggest heating it to red (it's a carbon steel tap) because it's in a silver soldered assembly!
Edited By Brian H on 16/08/2019 15:25:43
Dave Smith 1416/08/2019 15:43:57
174 forum posts
26 photos
This comes up on an internet search.
Address
Meden Square
Pleasley
Mansfield
NG19 7SQ
United Kingdom
Website
KWIL16/08/2019 15:51:05
3395 forum posts
66 photos
You do not say what metal the tap is in.
tractionengine4216/08/2019 15:54:49
378 forum posts
111 photos
I broke a 7 BA tap in a blind hole the other day, I managed to grind away the tap using a small diamond coated burrs with a Dremel. I basically ground away the centre portion of the tap after initially grinding the top surface reasonably flat to get a good start. I used a fine pointed burr and a very small spherical burr, alternating between the two.
I did this with the aid of a desk illuminated desk magnifying glass.
It took 15 - 20 minutes and I was surprised how well the it went. 8ba is a little smaller though but I think manageable by this method.
Nigel
old mart16/08/2019 16:04:57
3067 forum posts
194 photos
Take the offer of spark erosion and cough up the money.
Trevor Drabble16/08/2019 16:19:54
244 forum posts
5 photos
My suggestion would be either carbide drill from M A Tooling on Attercliffe in Sheffield on 07973843152 or a carbide burr from J B Cutting Tools in Dronfield on 01246 418110 . I got some minature burrs from J B at last year's Midlands show , and they are very good . Also , if you visiting Meadowhall in the near future , Took Shed in The Lanes has a small stock of Proxxon carbide burrs . Hope t all helps . Please post your progress so we may all learn . Trevor.
Brian H16/08/2019 17:57:24
2147 forum posts
113 photos
Many thanks for the suggestions all. The material that the broken tap is in is a mixture of brass and gunmetal.
I seem to remember that there is a chemical solution that has been mentioned before on here, that disolves the steel, but I can't remember what it is.
Rod Renshaw16/08/2019 18:05:13
271 forum posts
Memory suggests that the chemical is alum, as used in cooking, but I can't remember the details. I seem to remember it takes quite a long time.
Roderick Jenkins16/08/2019 18:21:38
2086 forum posts
557 photos
With respect, you wouldn't need to heat the fabrication up to red heat in order to soften a carbon steel tap. Tools are usually considered to be spoiled if they get to blue, which is about 300C. You've another 300C to play with before the silver solder starts to soften - and that's ignoring any liquation effect which will raise the solder melting temperature even further.
Cheers,
Rod
Tomfilery16/08/2019 18:45:46
131 forum posts
4 photos
Brian,
The chemical you mention is Alum, however, I managed to get a broken small drill (1.5mm dia) out of a brass item by leaving it soaking overnight in citric acid. The next day the drill had basically turned to rust and could be poked out with a scriber.
If you use clean citric acid, rather than some which has had copper in it, you won't get a deposit of copper on your item.
Good luck.
Regards Tom
Samsaranda16/08/2019 19:44:20
1116 forum posts
5 photos
If you need Alum it is readily available on the internet, when I ordered some it took only a day to arrive, can’t remember where I ordered it from but there are plenty of suppliers..
Dave W
ian j16/08/2019 19:48:01
301 forum posts
268 photos
broken tap remover.jpgremoved broken drill.jpgrecently I broke a No. 50 drill in a block of Aluminuim . Some time ago I bought a product called BTR-10-broken tap remover, (Translunar technology Ltd , Bucks) it contains 33% aluminum sulphate.
The instructions say to dissolve a quantity in water in a aluminum /glass container and simmer the part . It states no action occurs at a lower temp.
After approx 1 hour enough of the drill had been dissolved and it just fell out.
norman royds 216/08/2019 20:41:09
48 forum posts
the chemical I use is hydrochric acid it dissolved carbon taps the problem is tirying to buy these days regards norm
John Reese16/08/2019 21:18:18
934 forum posts
Is alum safe on copper alloys?
peak416/08/2019 22:38:31
1407 forum posts
159 photos
BrianH, whereabouts in Derbyshire are you?
If you're in easy reach of Buxton, I had some Alum arrive a month or so ago off ebay, You're welcome to a bit.
I bought it ready for when I brake a tap in a bit of motorbike one day.
Bill
Ian S C17/08/2019 08:24:37
7468 forum posts
230 photos
Alum is usually available in garden shops, and the cooking dept of the super market.
Ian S C
Mick B117/08/2019 08:50:05
1904 forum posts
96 photos
Have you an option to move the hole and drill and tap elsewhere?
You can see the attempted expiation of my sin in the position of the LH bearing strap retaining bolt (also due to a broken 8BA tap) here:-
laugh
Anthony Knights17/08/2019 08:52:33
509 forum posts
209 photos
Hi Norman. Hydrochloric acid is the main constituent of B&Q's Brick Cleaner.
Brian H17/08/2019 14:38:32
2147 forum posts
113 photos
Many thanks to all on here for the suggestions and offers. I've now managed to secure a small amount.
I first came across alum as a young apprentice with Crossley-Premier Engines. One of my first jobs was to pressure test valve guides which where hollow cast iron castings with water passages to cool the valves on diesel and gas engines.
They were tested to 25psi (as I remember) and any porosity or leaks were fixed by the addition of a teaspoonful of alum which VERY quickly rusted any defects so that a second pressure test could be carried out to ensure no leaks.
Brian H17/08/2019 17:47:31
2147 forum posts
113 photos
Just discovered that I needn't have made the holes blind! They will just go through without leaving a witness in the mating parts.
Also realised tht the two holes that I broke a tap in,needn't have been put in at all.
Must get my brain in gear next time.
JD Metals
