Kennedy Hacksaw bearing replacement
Graeme Durant 123/08/2019 16:08:26
9 forum posts
Thanks, Bill. That confirms my suspicions! I had looked at the info on the lathes.co.uk site when I started out a few weeks back, but not since. They show a lovely picture of the underside, complete with two nuts - just as you describe. Sounds like I just need to be more brutal getting this incorrect and oversized bolt out!
Graeme
Howard Lewis23/08/2019 16:15:22
2738 forum posts
2 photos
Maybe the original bolt stripped the thread in the casting? Whatever, it sounds like a bush will be needed to take up the clearance between the current fastener and the original size bolt (seems to be M8? )
Graeme Durant 123/08/2019 16:22:12
9 forum posts
I don't think the bolt has to be fixed solid in the casting. There has to be wriggle room anyway,as this is the way to tension the drive belt. So a clearance hole is all that is required, and when I take out the stuck bolt, I reckon it will be good to replace with a clearance fit bolt.
The originals are Whitworth by the look of them, but replacing with metric like Bill is probably perfectly acceptable - unless you are keen to retain authenticity!
Graeme
AdrianR23/08/2019 16:22:40
274 forum posts
20 photos
Graeme,
All the bolts are with nuts underneath.
Did you notice in the manual that you move/ the saw, not the motor to tighten/align the belt. The two holes for the saw should be oval.
Adrian
Graeme Durant 123/08/2019 16:44:38
9 forum posts
Thanks Adrian - more confirmation! And yes, my base casting holes are oval.
Still begs the question why someone put an oversized but too short a bolt in the main casting by force or design....
Graeme
AdrianR23/08/2019 17:33:44
274 forum posts
20 photos
Brut force and ignorance?
Dave Halford23/08/2019 20:47:58
561 forum posts
5 photos
Don't forget these were made for black iron pipe, conduit or scaffolding fitters to carry around. Any repairs required on site would have been basic
Ausee.com.au
