lathe part supplier asking questions over my head...help
Chris TickTock14/08/2019 10:34:34
361 forum posts
25 photos
hi I was asking my Sherline parts supplier if he supplies various lathe cutters for metal including a radius cutter. He has responded with right hand , left hand and boring cutter but no radius cutter . He states it is better to grind your own and do I have a radius gauge.
my question is: What is a radius gauge?
regards
Chris
RobCox14/08/2019 10:51:09
27 forum posts
19 photos
Hi Chris,
Not surprised they don't stock such a thing. There's an infinity of possibilities for the radii and whether it's to cut an internal or external radius, hence the suggestion of grinding your own.
A radius gauge is kind of like a feeler gauge, but instead of the thickness being the calibrated dimension, it will have either a protrusion or cutouts with a specified radius. To use it, you'd grind a curve on your tool then hold it in the cutout in the gauge up to the light to see how well the tool matches the gauge curve and grind the tool to adjust as required.
Rob
Chris TickTock14/08/2019 11:19:44
361 forum posts
25 photos
Thanks Rob, its time to buy a set/
Chris
JasonB14/08/2019 11:38:21
17821 forum posts
1948 photos
You don't need to buy one, for a concave gauge just drill a hole twice the radius you want in something thin and then cut/file away the waste until you have a 1/4 circle left to use as a gauge.
For a convex gauge just use a drill who's diameter is twice the radius and offer that upto your tool.
If you are wanting to round over a corner or add a concave mounlding to a corner then it is also possible to hold a round over milling or router cutter or in the toolpost and use one of the flutes to cut with.
For tools with a concave cutting edge you can also just drill a hole in some gauge plate and then saw/file away half to form a bead or 3/4 to form a round over cutter and then harden.
Vic14/08/2019 12:32:26
2489 forum posts
14 photos
Perhaps of interest.You can use a boring head for ball and radius turning etc.
Chris TickTock14/08/2019 12:34:47
361 forum posts
25 photos
Great posts guys thanks
Chris
larry phelan 114/08/2019 13:50:57
649 forum posts
22 photos
I bought two sets, convex /concave from China for pence [or cents ! ]
Very simple to use.
Chris TickTock14/08/2019 14:29:25
361 forum posts
25 photos
Hi I have just bought 3 quality sets off Ebay for £10 delivered. having done that I have a small confession to make I get you can measure the radius of an object but can they be used to create a form cutter/
Chris
Jeff Dayman14/08/2019 15:25:37
1789 forum posts
45 photos
You could use them to mark out a piece of tool steel to make a form cutter, but not likely they will be usable to cut metal - they are NOT meant for that - they are an inspection tool.
Please re-read Jason's post above - he's told you how you can make radius form tools already.
Chris TickTock14/08/2019 19:38:29
361 forum posts
25 photos
Thanks alot guys yes get the radius gauge is to see if you have made the radius correctly. Surely the gauges could be used to check the form tool msade as Jason's method is correct as well as testing the machined work is also correct.
Chris
JasonB14/08/2019 20:15:19
17821 forum posts
1948 photos
I would imagine that most radii shown on clocks which seems to be your intended use would be more for decorative purposes and more often that not would be turned freehand with a graver than using a form tool so "look " is more important than absolute accuracy.
Even grinding to a printed template that can be stuck to the tool or cut out and used to mark the tool will do, this picture shows a tool in th emaking, with a hole drilled as I mentioned above to form the half round then the printed template has been used to mark th erest of the shape.
The completed tool in use
And completed part
And a bit of big boy 5" dia hand graving
