Looking for a locking stay for machine canopy.
Alistair Robertson 112/08/2019 19:25:01
89 forum posts
6 photos
I have a Denford Novamill and to gain a bit more room in the workshop I altered the central pivoting of the Perspex "bubble" top cover to a rear hinge. This allowed me to place the machine against the wall saving about 200mm space.
I was going to fit a couple of struts that lock when they are extended then release when you push them up again to allow the guard to lower. I measured up the length I would need and went to my local hardware store to be met with stony silence when I explained what I was after. I had fitted the same sort of strut to a previous machine for a customer a few years ago. "You can't get anything like that" I was told, But I had bought them previously so I went home and looked up my old paperwork as to where I had bought them. I had bought them from a different shop so a few days later I went to town and strode confidently in to the counter to be told "Never seen anything like that!" I showed them my old invoice which said "Self Locking Strut" but no part number and they also said "Never seen them!!"
I have looked on the Internet but I am not sure what the correct description should be! They are like a drawer slide but with no balls (I think) and when they fully extend a bit of metal pops out of a square hole locking the strut in place. Push the strut further up and it releases.
Can anyone give me a correct description as I can't remember what I asked for about 10 years ago!
Vic12/08/2019 19:38:05
2494 forum posts
14 photos
Hi Alistair, is there anything Here that may do the job?
Brian G12/08/2019 19:40:24
672 forum posts
26 photos
How about these? **LINK**
MichaelR12/08/2019 19:47:14
369 forum posts
75 photos
Hold Open Stay Here may be what you are looking for.
Robert B12/08/2019 20:58:59
9 forum posts
Posibly these?
https://www.catchesandlatches.co.uk/lid-stays-hinges/
John Hinkley12/08/2019 21:37:39
850 forum posts
286 photos
I seem to remember that my Frogeye Sprite had a similar strut arrangement to support the open bonnet. Replacements are available, but at a price ( around forty quid !). Could you not use a gas strut such as are used for tailgate lifts? Plenty on eBay in various sizes and specs for under a tenner.
Nigel Graham 212/08/2019 22:39:17
585 forum posts
I would not use a car gas-strut to hold a small plastic machine-guard. They are designed to balance a far heavier mass than that, so would be physically very hard to handle.
Some machines, including my Myford VMC, use a basic toggle: just two links pivoted together at mid-point when both are in line. Pushing the joint while closing the cover down slightly makes the links go past alignment by a couple of degrees of so, against a small stop on one of them.
Clive Foster13/08/2019 00:20:44
2154 forum posts
73 photos
The friction slide thingies used on modern windows instead of hinges ought to be well up to the support job. I have a stash of used ones in the "gotta be useful" box. If you fancy trying the idea PM me and a pair are yours for postage costs.
The locking struts in Brians link are effective but, if the ones I saw are the same model, quite hefty.
Eurofit offer a variety of lid stays :- **LINK** including light duty gas struts, smallest is 50 newtons force, about 11 lb.
The ordinary folding desk stay like this :- **LINK** can quite easily be modified to work as an over centre toggle type support as described by Nigel. I did one many years ago which worked OK. Darned if I can remember exactly what I did tho'.
An ordinary drawer slide will do the deed just fine if you ass a sprung clip. In principle its easy to come up with a two position clip which releases if you push the lid beyond its holding position and re-arms ready to support the lid next time as you swing it shut. In practical its probably more works than the job is worth.
Alistair Robertson 113/08/2019 09:36:23
89 forum posts
6 photos
Hi, All.
Thanks for all the valuable information. I have bought a pair of the type suggested by Brian G from RS. Why I didn't look there before i don't know. I ordered some bits and pieces from them last week!
I didn't want to use a gas strut as when they have to be compressed to "go overcentre" they put a big strain on the perspex cover which weighs about 25 Kgs. as I well know when I knocked out the plastic tube I was holding it up with and had to visit the hospital for a neck X-Ray. It was sore for more than a week.
The pair I bought a few years ago were not the same as the Camloc I have bought from RS they were more like a drawer slide that locked when extended.
Nick Hughes19/10/2019 11:24:13
217 forum posts
131 photos
A bit late, but I just came across these when searching for something completely different and remembered this thread:-
From here:- Small Bonnet Stay Auto-Close
