Flat bottom hole 3/16 o/d
Bill Chugg11/08/2019 10:20:24
962 forum posts
6 photos
Need to drill a hole 1 inch deep by 3/16 inch o/d in brass and end up with a flat botton - cylinder for a small mamod type engine.
I am thinking use a normal drill to start with and then use a milling cutter or a flat bottom drill to finish.
Just wondering which method is the norm ?
Thanks
Bill
David Standing 111/08/2019 10:33:32
1285 forum posts
48 photos
I would use a slot drill for that. Clear the swarf regularly.
Brian Wood11/08/2019 10:34:16
2069 forum posts
37 photos
Bill,
The usual approach is to drill the hole almost to full depth and then swap the drill for a specially ground flat bottomed drill to create the bottom of the hole.
The skill lies in getting the geometry of the second drill end correct but it can be done in drills of this diameter. In my professional life we used to call on the services of a particular man in the toolroom to create flat bottomed holes in all manner of exotic aero engine materials. These were 0.050 inch diameter [ actually 3/64 inch] and about 1/2 inch deep. Skilled work indeed with sensitive drilling machines.
Regards Brian
JasonB11/08/2019 10:51:17
17028 forum posts
1825 photos
I doubt the bottom needs to be totally flat, so grind a drill to an almost flat end or make a D bit. Not worth trying to find an extra long series slot drill to reach that deep.
Kiwi Bloke11/08/2019 11:13:40
290 forum posts
...or, if appropriate, you might consider a through hole with an inserted plug - secured by your favourite method.
Speedy Builder511/08/2019 11:28:35
1884 forum posts
131 photos
'D' drill anyone ??
Nicholas Wheeler 111/08/2019 11:54:35
301 forum posts
19 photos
I normally use a milling cutter for flat bottom holes, but none of my 3/16 cutters are any where near long enough for a 1" deep hole
Bill Chugg11/08/2019 12:56:53
962 forum posts
6 photos
Thanks all
Bill
Bill Chugg11/08/2019 12:56:54
962 forum posts
6 photos
Thanks all
Bill
old mart11/08/2019 18:52:28
1075 forum posts
109 photos
If you look closely at a slot drill, you will see that it will not produce a flat bottomed hole. Nearly flat may be within your tolerances, however.
Ian P11/08/2019 21:12:04
2299 forum posts
93 photos
I have just realised what it was about this thread that had unsettled my tiny brain. I have followed it from the start hoping to find out what engine had a piston 3/16" diameter (I thought a Mamod would be larger than that).
The unsettling bit was trying to get my head round a hole with an 'outside' diameter of 3/16". All the holes I have come across have an inside diameter!wink 2
Ian P
(As to the hole in question, for me its a long series slot drill to clean up after normal drill, or investigate why the hole needs a flat bottom and whether it can be eliminated.)
Michael Gilligan11/08/2019 21:24:03
14758 forum posts
635 photos
Posted by Ian P on 11/08/2019 21:12:04:
If you succeeded in getting your head round it, Ian ... I think you have effectively demonstrated that it must have an outside diameter.
angel MichaelG.
Edited By Michael Gilligan on 11/08/2019 21:25:25
