Ashley ferguson | 05/08/2019 18:05:51 |
9 forum posts | I'm in need of a drill chuck to fit a super adept lathe if I'm not mistaken it's the same side a the end of a 0mt and the same angle but we'll smaller, need some help finding one that will fit or finding someone who can make me one that will fit or make me a tail stock that will take a normal 0mt any help appreciated |
thomas oliver 2 | 05/08/2019 21:46:46 |
108 forum posts | Plenty of small keyed drill chucks are available cheaply for around £4 on ebay and usually have a 3/8in UNF thread or a small taper fitting, 3/8in bolts were used on British and US cars prior to Metrication and should not be too difficult to obtain. Presuming your lathe is otherwise in operation, it should not be too difficult to turn the correct taper to fit the tailstock. If you have never done this a trick is to put a solid centre in reverse along the side of the topslide and set so that it brings the centre line in line with the lathe centre line. Otherwise you can use Blue compound the test the fit. It is always a great advantage to have more than one chuck to use so buy at least two. If you can manage to produce the correct taper, make a tapered arbor and drill it 1/8th inch. Fit an 1/8th centre drill with Loctite or Superglue and this means you always have a centre drill at the ready. . T. Oliver. |
Ian S C | 06/08/2019 11:45:52 |
![]() 7468 forum posts 230 photos | The drill chuck that I use on my Super Adept is from a Stanley wheel brace, the orrigional shaft has the taper on it, and just at the begining of the thread there is a transverse hole for a tommy bar. Ian S C |
Ashley ferguson | 06/08/2019 12:33:05 |
9 forum posts | Posted by thomas oliver 2 on 05/08/2019 21:46:46:
Plenty of small keyed drill chucks are available cheaply for around £4 on ebay and usually have a 3/8in UNF thread or a small taper fitting, 3/8in bolts were used on British and US cars prior to Metrication and should not be too difficult to obtain. Presuming your lathe is otherwise in operation, it should not be too difficult to turn the correct taper to fit the tailstock. If you have never done this a trick is to put a solid centre in reverse along the side of the topslide and set so that it brings the centre line in line with the lathe centre line. Otherwise you can use Blue compound the test the fit. It is always a great advantage to have more than one chuck to use so buy at least two. If you can manage to produce the correct taper, make a tapered arbor and drill it 1/8th inch. Fit an 1/8th centre drill with Loctite or Superglue and this means you always have a centre drill at the ready. . T. Oliver. I'll definitely try and make one if I can don't know if I have the skill to do that yet but I'll give it a try, my big problem is I have nothing for the end stock not even a center |
Ashley ferguson | 06/08/2019 12:33:34 |
Ashley ferguson | 06/08/2019 12:36:33 |
9 forum posts | Posted by Ian S C on 06/08/2019 11:45:52:
The drill chuck that I use on my Super Adept is from a Stanley wheel brace, the orrigional shaft has the taper on it, and just at the begining of the thread there is a transverse hole for a tommy bar. Ian S C That seems like a much easier solution might have to have a look online for one
Former Member | 06/08/2019 12:41:59 |
1329 forum posts | [This posting has been removed] |
Ashley ferguson | 06/08/2019 13:30:36 |
9 forum posts | Posted by 34046 on 06/08/2019 12:41:59:
PM sent - check your inbox. Bill Thank bill sent you a reply |
thomas oliver 2 | 06/08/2019 20:47:43 |
108 forum posts | Ashley, Tapers can be made by measurement. For your lathe the widest diameter is 0.340ins and the smallest diameter is 0.285 in. at a distance apart of 0.960ins . I have a Wizard lathe which is a slightly superior clone of the Adept in that it is cast from spheroidal cast iron, so I have checked these measurements form my own centres. Set your topslide at a small angle and take a few cuts. Measure the two diameters at the distance apart of 0.960ins. Keep resetting the cross slide so that the plus diameter is the same at both ends ie. 0.340ins plus x and 0.285ins plus x. This should fix the correct angle. Then slowly take further cuts until the stated dimensions are achieved. This should enable you to reproduce the taper for centres. You should be able to feel a snug fit if accurate with no wobble We all started the same as you knowing very little so get started and have a go. "Practice makes perfect" I hope the above is clear enough. |
Former Member | 07/08/2019 07:39:35 |
Robert Dodds | 07/08/2019 12:22:50 |
320 forum posts 62 photos | The cross hole that is mentioned is, for me, quite important. Stick a tommy bar through it and it makes it easy to extract chucks, centres etc. from the tailstock. As you wind back the barrel the bar strikes against the nose of the tailstock and out pops the chuck, centre, why. Regards Bob D |
