Good inserts For (t6 i think) aluminium
Nathan Turner 102/08/2019 00:07:39
9 forum posts
I have a six inch rough Alu disc that i would like to face off and use as backing plate for a gem faceters plate which is quite flat, i'd like a nice finish so any recommendations would be brilliant, thanks in advance
DC31k02/08/2019 19:50:13
571 forum posts
It would be beneficial to you to tell us what holder you have for the inserts (i.e. the insert shape).
Assuming you have a rhomboid one, I have had good luck with Korloy CCGT inserts. Available on eBay via China if you do not mind waiting, or Cutwel Tools.
In general, aluminium inserts will have a 'G' in the code (for ground/polished after sintering) and will be shiny silver in colour and very sharp.
Be sure not to get ones for aluminum, or you will have to source your material from USA.
Hollowpoint02/08/2019 20:17:23
442 forum posts
56 photos
I agree with the above. The CCGT tips work a treat. You can get an almost Glass like finish with these if you take a fine finishing cut at high rpm. 👍
Nathan Turner 105/08/2019 00:55:56
9 forum posts
Brilliant thanks for the recommendations, i'm waiting for the lathe i want to either come into stock or something similar so i'll be ordering some as soon as it arrives.
walker midge
BOLDON
JD Metals
rapid Direct
