Anyone recognise this mains connector ?
And where can I get the mating connector
Simon036228/07/2019 22:04:52
175 forum posts
63 photos
hi all,
i bought this little furnace for what I consider to be a bargain 15€ but I don’t know what the connector is...
the furnace was bought in France, apparently of German manufacture and helpfully, the date stamp is missing but I guess its 70s unless anyone knows better.
Pins are 6mm diameter and roughly 20mm apart
Connected it up with a botch job to confit works, need to do so more safely now.
As ever, the aid from fellow model engineers is very welcome. Simon
Emgee28/07/2019 22:21:16
1451 forum posts
217 photos
Looks similar size to the very old type kettle connectors that were 2 pole with scraper earth, probably not any around these days.
It may be better to fit a permanent cable to the furnace via a gland and fitted 13A plug with fusing to suit.
Emgee
Edited to include:-
I have asked a friend in Germany if that type of connector is still available, will know in a few days so if you want to stay original he could send to you at cost of part and postage.
Edited By Emgee on 28/07/2019 22:52:51
Mike Poole28/07/2019 22:33:37
2546 forum posts
60 photos
+1 for old style kettle and coffee maker type equipment. Unless you really want to keep it original I would go with Emgee and hard wire it or fit a modern euro style connector, be aware there is a hot condition version with an extra notch for kettles but the regular version is rated at 6A which would be ok for the 900W load you have.
Packmule29/07/2019 14:42:24
97 forum posts
5 photos
Looks as though one of the orange cut cable connectors sold in b&q may fit
Simon036229/07/2019 14:58:45
175 forum posts
63 photos
Thanks for the suggestions so far but since I am also based in France, I need a replacement that I can either buy over the web or get directly.
Looks like it isn't very common though...
Former Member29/07/2019 15:08:03
Engine Builder29/07/2019 15:43:00
224 forum posts
Not much help to you I'm afraid but I have an Efco oven like that. The connector is made of porcelain to withstand the heat. it has a simmerstat in the lead as a temperature control.
There is no access to the other side of oven connector so
replacing it as some suggest s not an option.
I have the original instruction book it's in German.
Edited By Engine Builder on 29/07/2019 15:44:19
Edited By Engine Builder on 29/07/2019 15:47:57
Edited By Engine Builder on 29/07/2019 15:48:20
Stuart Bridger29/07/2019 16:44:21
427 forum posts
24 photos
looks like the Efco 110 is still a current model.
The design may have changed, but you may be able to get some assistance from the manufacturer
Stuart Bridger29/07/2019 16:58:28
427 forum posts
24 photos
Further info, there is an image here, confirming it is a ceramic connector.
You also need an external temperature controller
Michael Gilligan29/07/2019 20:56:42
15493 forum posts
670 photos
This is probably worth bookmarking for reference: **LINK**
https://www.plugsocketmuseum.nl/ApplConn_overview.html
...it's a fascinating site, and well organised.
Robert Dodds29/07/2019 21:21:46
268 forum posts
36 photos
Simon,
Is this assortment of any use. I can't find dimensions on the site but could be worth a call or email to check dimensions.
https://www.pmseurope.com/collections/electrical-plugs
Bob D
Bandersnatch29/07/2019 22:00:47
1600 forum posts
58 photos
Posted by Michael Gilligan on 29/07/2019 20:56:42:
It is indeed a fascinating site, Michael ..... thanks for that.
yes
Grindstone Cowboy29/07/2019 22:05:31
276 forum posts
24 photos
Probably not much help but I used to have a waffle-maker from South Africa with that type of connector - don't know if they are still in use over there?
Mike Poole29/07/2019 22:12:48
2546 forum posts
60 photos
this German supplier still makes these plugs, there is a silicon version to stand 200°C. They are linked to at the bottom of Michaels link.
Max Tolerance29/07/2019 23:07:20
50 forum posts
The plugs are still available and used widely in industrial heating applications. Typically on injection moulding machines and plastic blown film lines, but also on any item where things get hot. Try R.S. or google industrial heating element suppliers. They are normally two piece ceramic with the brass or plated socket pins sandwiched between the two halves and with a stainless or aluminium shell. Though some can be found made of a temperature resistant plastic/ fibrous material instead of the ceramic. They are available in male and female forms though the female is most common. I have found old versions of these made with imperial pins 1/4" but your furnace obviously has the metric pins. Normally silicone sheathed heat resistant cable is used with these plugs and in some cases glass coated high temperature wire. The silicone stuff is good for maybe 250 degrees C and the glass covered wire can easily stand 800 / 900 degrees C. Important if you accidentally drop some hot metal on it.
All the plugs I have seen are rated at 250 volts,
Nick Clarke 330/07/2019 09:42:07
690 forum posts
21 photos
Posted by Packmule on 29/07/2019 14:42:24:
While it may physically fit the two pins it will not have the earth connection to the body of the oven connector, so not recommended.
Simon036230/07/2019 09:44:43
175 forum posts
63 photos
Thank you everybody for your input and comments:
@engine builder, @stuart bridger, thanks for confirming its a ceramic connector
@Michael, I cannot believe that you managed to find such a site - geeks of the world unite! (on a side note, we have visited a museum of combs and a museum of the corkscrew down here - the comb one was good, the corkscrew one not really)
@Robert Dobbs, great, thats the one!
@Mike Poole, @Max tolerence, also great, I will follow up
Proof once again that the ME site has a wealth of knowledge waiting to be tapped!
Robert Dodds30/07/2019 11:46:38
268 forum posts
36 photos
Simon,
The pity is your plug will cost more than the furnace!
But C'est la vie.
Bob D
Robert Atkinson 230/07/2019 12:24:56
617 forum posts
16 photos
Google DIN 49 491 and see if a local supplier comes up.
EDIT Don't forget to give those pins a good clean before you plug you new connector in even for a trial.
Robert G8RPI.
Edited By Robert Atkinson 2 on 30/07/2019 12:33:27
Packmule31/07/2019 16:50:18
97 forum posts
5 photos
Casterama is French equivalent of B & Q
