not tightening
"split" return crank will not tighten on shaft
David Bothwell 127/07/2019 16:25:53
152 forum posts
Came across this problem while re-fitting new return crank, I used a cap head screw (2.5 m.m.) and steel nut, but it will not tighten, just wondering if anyone has a suggestion? Possibly incompatible nut (7ba.) I have copied the original part( and consulted the drawings) but the original builder decided to make a split and fit a nut and bolt to grip it to the shaft. I did have the engine running with this method, but the return crank "moved" (engine would not go!) any suggestion gratefully received. Also is there a "fool-proof" way of setting the return crank in the right position in respect to other parts of the motion? Thanks in anticipation!
roy entwistle27/07/2019 16:36:54
1172 forum posts
Use the same thread on nut and screw
Speedy Builder527/07/2019 19:03:01
2006 forum posts
140 photos
Is one of them left handed.
Jim Nic27/07/2019 20:04:41
244 forum posts
149 photos
What is it that won't tighten - is it that the nut won't run down the thread?
If the engine was running and then the shaft turned in the split crank it suggests to me that the split is closing fully before the crank grips the shaft. In which case make the split wider.
Jim
David Bothwell 127/07/2019 21:00:19
152 forum posts
Thanks for the replies, I will try the solution in the morning! The nut goes down he thread but there is no tightening up I am fairly sure this is because the bolt is a metric thread and the nut is B.A.. at least I think this is the problem
Mike Poole27/07/2019 21:10:41
2575 forum posts
60 photos
Just to be pedantic BA is a metric threaddevil but your nut and bolt will need to be a match.
David Bothwell 128/07/2019 07:56:14
152 forum posts
Of course you are correct Mike, I have looked at the conversion chart and there is a difference between 7b.a. and the "metric" equivalent. thanks for the replies most useful.
