chinese hit and miss engine
Philip Burley25/07/2019 18:48:42
194 forum posts
A friend brought round a little hit and miss engine , he has had it running once , but it doesn't want to run now. There seems to be no compression , has anyone got one of these? Should there be any compression ?
Former Member25/07/2019 19:10:55
1329 forum posts
JasonB25/07/2019 19:18:03
18632 forum posts
2048 photos
Have a look on Smokstak forum, there is a long thread there, Gil Garceru has one that runs very well. Not sure if you need to join to see the images posted as attachments.
Gil has several videos of his on his youtube channel as Reddrryder
Former Member25/07/2019 19:24:02
1329 forum posts
Jeff Dayman25/07/2019 21:52:35
1853 forum posts
45 photos
I've seen a few Bang good hit and miss engines, the blue ones, from acquaintances. They ran really well for about 10 or 12 runs, then will not run.
On the ones I have seen the aluminum bores, not lined with steel and not chromed, wear out completely. I fitted a steel liner in one but it was prone to overheat afterward, and there was very little clearance around the head screws to fit it.
No idea whether they have changed the design along the way to add a steel or iron liner, but the early ones I saw were not designed with longevity in mind. Still makes a nice shelf model, running or not.
not done it yet26/07/2019 06:04:58
4877 forum posts
18 photos
Posted by Jeff Dayman on 25/07/2019 21:52:35:
If they were any good they would likely not be for sale from that supplier. I reckon they only sell lines that are bought in cheap because the items are not first quality or are ‘surplus to requirements’ from manufacturing runs.
Blue Heeler26/07/2019 07:23:37
204 forum posts
Posted by not done it yet on 26/07/2019 06:04:58:
That's a totally incorrect statement.
Philip Burley26/07/2019 07:41:37
194 forum posts
thanks for the help . I will ask on that site if they should have some compression
Former Member26/07/2019 07:47:42
1329 forum posts
Former Member26/07/2019 08:36:55
1329 forum posts
Engine Builder26/07/2019 08:57:26
228 forum posts
I had one of these. It does need compression of course. Make sure the valve push rod is fitted the right way around.
One end is flat and the other rounded. Round end to valve. If it's the wrong way the exhaust valve will not close and there will be no compression.
The only other thing that will give no compression is valves not seating properly or damaged piston O ring.
Compression will usualy improve on a model engine after a bit of running as the valves bed in.
I found the ignition cut out after a short run but this was solved by reducing the battery voltage to 3v, there must be some cut out in the electronic ignition circuit that did not like 4.5v. Engine now runs for as long as there is fuel in the tank.
These models are very well made, I would not like to make one for the price they sell for.
Hope this helps.
Model link
Edited By Engine Builder on 26/07/2019 09:12:54
jimmy b26/07/2019 20:48:45
659 forum posts
38 photos
Just because you bought something once that was no good, don't assume everything they sell is the same............................
Jim
not done it yet26/07/2019 22:46:11
4877 forum posts
18 photos
As I have repeatedly stated, I recommend that people don’t buy anything from them that the buyer cannot afford to throw away. There customer service reeks - if it exists at all.
Jeff Dayman27/07/2019 00:47:31
1853 forum posts
45 photos
Just food for thought -
The hit and miss engine models and other engines from China are neat toys which can provide some fun for a finite time. Maybe the newer ones can be repaired easier when required than the older ones. They cost over $230 USD each now. This is a very fair price for what you get - as others said I would not want to try and beat this price to make them (unless I had a CNC shop with dozens of government sponsored brand new machine tools in the far east, and was paying a very low rate per hr to the labour force to run them)
You can buy some raw stock and a good bit of top notch tooling for a lathe or mill for same money and enjoy it for years and build PILES of models of all sorts with it.
You can buy a low cost but really capable 3D printer like the Ender-3 or Ender CR-10 for same money and print PILES of parts and model bits and casting patterns etc (see youtube - search for Myfordboy, as an example of how much diversity you can get out of a small 3D printer)
Mentioning it for consideration only - completely up to the individual how to spend the available coins. I am not compensated in any way by any firm for things said above.
Edited By Jeff Dayman on 27/07/2019 00:54:38
Philip Burley27/07/2019 08:00:29
194 forum posts
sorry I opened a can of worms , seems like this one needs a new Viton piston ring
regards
Ian S C27/07/2019 12:31:42
7468 forum posts
230 photos
Looks like a worth while little motor. If after a while the bore becomes worn, I don't think it would be too hadt to lightly bore the cylinder and fit a cast iron sleeve, you would then need to make a new cast iron piston, the bore would probably be reduced a few thou from new, but it should then run for ever, shouldn't even need a ring with a good fitting piston.
Ian S C
Rockingdodge27/07/2019 15:43:23
224 forum posts
36 photos
Posted by not done it yet on 26/07/2019 22:46:11:
Totally disagree with you, there are some items that are not up to standard but in the main all I have bought from there over the past 6 years have been fine and even great. There have been instances where goods have not arrived, not all there or broke in a short time but every time I contact them I have had a good proactive response and replacement even with extras to say sorry.
Must be your attitude when you contact them not done it yet wink, oh and I always have photos/videos at the ready.
Roger
Edited By Rockingdodge on 27/07/2019 15:45:12
JasonB27/07/2019 16:42:29
18632 forum posts
2048 photos
Let's concentrate on the engine not where it came from.
Ian S C28/07/2019 12:39:03
7468 forum posts
230 photos
Agreed JasonB, what ever it's like, it looks a good basis for a good little engine even if it needs a few mods to make it a bit more durable. At the price it's not too much as a static ornament.
Ian S C
Philip Burley05/08/2019 12:19:24
194 forum posts
an up date on my friend's engine
. I put a new o ring in it to no improvement , so I made a blank cylinder head , lo ! compression restored So it must be the valves leaking . Been trying to grind them in with some metal polish but they are so tiny !!!!!
regards
EngineDIY
