ARC NCIH Part Off Blade
Blue Heeler23/07/2019 04:01:27
274 forum posts
Does anyone use one of these?
Thor 🇳🇴23/07/2019 05:15:44
1483 forum posts
41 photos
Hi Jim,
I have one for 2mm inserts and one for 3mm, they work well.
Thor
Blue Heeler23/07/2019 05:21:19
274 forum posts
Cheers Thor.
Ketan Swali23/07/2019 06:38:25
1402 forum posts
126 photos
Hi Jim,
This product and similar have been discussed on here and more recently on MEM. I cant find the links at present.
As a summery, it is a bit like marmite. You either like it, get on with it and are happy, or the exact opposite. I personally happen to prefer the HSS Co8 type...which is also thinner than the carbide offering, at 1.5mm or 2mm. My reasons are down to fear.
In the 'likeit' camp are people like Smithy from MEM, our Neil Wyatt, the late Sir John and many others.
The main issues are - not so good for beginners, and as you have to run the machine relatively fast, the fear is there during parting, combined with rigidity issue around the machine components, combined with constant positive feed required for parting. The carbide blade/holder is not forgiving, and can break more easily if confidence levels are low. Great and easy to use for non-ferrous, but a lot of caution, skill and confidence required when using it on steel or cast iron.
For every five buyers, three get on with the NCIH type, one plays with it with some fear, and one breaks it. Most beginners WILL most likely break it.
Ketan at ARC
edited to correct spellings,... not had coffee yet.
Edited By Ketan Swali on 23/07/2019 06:40:02
JasonB23/07/2019 07:23:58
22017 forum posts
2540 photos
I suppose the reason why some sellers of these holders supply two " blades" confirms what Ketan says about them breaking. Can't say I've damaged my similar type holder yet and am still on the first end of my holder with the "spare" still unused.
It's my reach to parting tool for anything over 12mm, below that Like Ketan I use a HSS Co one particularly on brass/bronze and also have a 1mm wide insert tool that gets used quite a bit on smaller stiff.
Slice of 70mm Cast Iron 1.5mm thick, and another smaller piece 0.5mm thick
Blue Heeler23/07/2019 08:11:55
274 forum posts
Thanks Ketan & Jason for your replies.
For the last 7 years I've been using Iscar GFN 3J IC354 inserts in an Iscar holder -
Iscar GFN 3J IC354
Everything is great about them, except for the price (even though they do last for a long time, to buy a whole pack of 10 is $$$). They are around $18+ an insert and I was wanting to move away to something cheaper like the NCIH Part Off Blade.
Many thanks again for the replies, I will do some searching for those MEM articles.
Kind regards,
Jim
Daniel23/07/2019 08:25:47
338 forum posts
48 photos
Hello All,
I have only ever possessed the NCIH type parting tool (Type 26 x 3mm).
To date it does everything I need it to. It is true, probably, that it takes a bit of getting used to.
Tips do eventually wear out and/or break. But, to me, I still feel that the rapport usage/price is well within reason. As Jason has said, they can be used right up to capacity (80mm mild steel), with some care.
A quantum leap, for myself, was when I switched to parting off under powered cross feed. Tip life increased tenfold !! yes
ATB
Daniel
David Standing 123/07/2019 08:32:37
1297 forum posts
50 photos
Posted by Ketan Swali on 23/07/2019 06:38:25:
Ketan at ARC
First time I used mine......I broke it laugh
But I was doing something dumb with it that was, in hindsight, almost guaranteed to break it blush
Just had my first mug of freshly ground coffee.....life is good wink
SillyOldDuffer23/07/2019 09:46:25
7921 forum posts
1725 photos
Posted by David Standing 1 on 23/07/2019 08:32:37:
Ketan at ARC
Me too! Still my preferred parting-off tool. Impressive when working well but not indestructible. Parting-off demands a lot of the lathe and the tool. Much easier to part-off on a heavy stiff machine than a bendy lightweight.
Two main problems I get.
  1. Swarf tends to jamb in the slot and the tool stops cutting, rubs and increases the unwanted forces on the machine that can displace the tool-tip. Aluminium causes most trouble because it's sticky and tends to weld, blunting the tool.
  2. The tool and maybe the whole saddle tend to bend slightly dropping the tool-tip and causing dig-ins. Anything that reduces rigidity is bad,, It can happen too fast for the operator to react and some are severe enough to damage the tool.
I've found all parting-off tools perform best with a steady feed when cutting correctly, which means getting the tool height, rpm and feed-rate right. Not too fast, not too slow, and definitely not jerky. Swarf clearance is vital. Proper lubrication helps, and the tool tip should be in good condition. Add it all together and it's not surprising parting-off goes wrong!
Parting off is a balancing act. I found a lot more skill was needed to do it successfully on a Mini-lathe than my WM280, and I imagine anything heavier would be easier again, mainly because big heavy lathes are less likely to flex enough to allow the tool-tip to dip into a dig-in.
What's really annoying is some lucky chaps don't have trouble parting-off. I suspect they have a steady hand, quick reactions and a natural feel for when tools are cutting correctly. The rest of us have to practice and experiment. I no longer expect disaster every time I part-off, but I'm not surprised that it goes wrong every so often.
The design of NCIH holders may be deliberately weak:
I suspect in commercial use where feed-rates are carefully calculated and automated, a dig-in means something really bad is wrong, and the tool is intended to break before the expensive CNC machine does.
Still the best option for parting-off I've tried. Ketan's image shows the maximum parting-off diameter to be rather small: I invariably use the tool to take much deeper cuts than that!
JasonB23/07/2019 13:14:49
22017 forum posts
2540 photos
Posted by SillyOldDuffer on 23/07/2019 09:46:25:
Dave, even with a silly old hand you should not have problems flicking the feed lever down on your 280, don't faff about hand feeding. That then gives you a free hand to drip a bit of paraffin onto aluminium so it does not stick
old mart23/07/2019 13:59:11
3524 forum posts
217 photos
I have parting blades in 26mm and 32mm size, from 1.6 to 5mm wide. I wouldn't use the wide ones for parting, only grooving as the lathe isn't really stiff enough for parting, especially with steel.
I ruined one end of my Kennametal 26mm by 1.6mm blade when the work moved in a three jaw chuck. A four jaw independent chuck is much more secure.
Remember to check your jibs for tightness, and always lock the saddle when parting.
I made a dedicated rear cut off block to hold 26 and 32 blades which bolts directly to the cross slide, with the blades inverted. I also added a rear saddle lock as the cutting forces are upwards. This is much stiffer than using a normal toolpost.
I would never part off dry, soluble oil from a squirty bottle for steel, and WD40 or similar for aluminium.
A great advantage of using the GTN inserts is that they are available from several sources, the best I know of is Korloy. I have some in 1.5, 2 and 3mm wide.
Edited By old mart on 23/07/2019 14:01:45
Edited By old mart on 23/07/2019 14:09:56
mark costello 123/07/2019 16:20:24
685 forum posts
12 photos
I have the best of both worlds. I mounted My insert cut off tool holder upside down, chips fall out. Every little bit helps.
SillyOldDuffer23/07/2019 16:44:37
7921 forum posts
1725 photos
Posted by JasonB on 23/07/2019 13:14:49:
Well I do have a genuine problem. It's cowardice! I can't quite bring myself to try power feeding during parting-off. Now I've admitted the real reason I'll have to try it next time.
Most disasters in the Duffer Workshop can safely be blamed on the operator...
blush
Howard Lewis23/07/2019 17:16:21
5751 forum posts
13 photos
It is only recently that I have had the courage to use power fine feed for parting off with a rear toolpost. As already said, the swarf falls away rather than accumulating, and so far, tempting fate, no dig ins!
Forget to reverse the feed, from time to time, but soon rectified.
Neil Wyatt23/07/2019 17:22:05
18899 forum posts
734 photos
80 articles
Just to confirm I like these. When I want to make little grooves I use HSS.
In my experience confidence is the best aid to parting, (s)he who hesitates is lost!
Brian G23/07/2019 17:43:23
806 forum posts
35 photos
Powered cross feed is a great alternative to confidence (maybe not that much confidence, my freed-up hand sometimes hovers over the e-stop button). Truth be told It isn't thick material that REALLY bothers me, I have never successfully parted small stainless bar by hand as I start too slowly and work harden the surface, but under power it is a doddle.
So far I have only parted with carbide tips in a grooving holder as I was nervous of the extra 15+ mm overhang on the QCTP that seems inevitable with the blade type holders, so for thicker material I have stuck to HSS, but this thread seems encouraging.
Hollowpoint23/07/2019 18:21:39
446 forum posts
56 photos
Posted by Blue Heeler on 23/07/2019 08:11:55:
Iscar GFN 3J IC354
Kind regards,
Jim
Why not just swap the tips? The ones in the link look an awful lot like gtn3 tips. These are readily available and if you are prepared to wait they can be had for as little as 60p a tip from China.
Rik Shaw23/07/2019 18:32:53
1470 forum posts
398 photos
I use one of those generic insert holders that takes 3mm wide tips. I use an assortment of grades which I nab on ebay when they slip through in my price range. blush Sometimes with flood coolant but more often than not without. I don't have a rear mounted toolpost. Due to an enhanced sense of self preservation for both me and my kit I always feed in by hand. Using this tool holder I don't bother with HSS.
Lathe is Warco BH600G
Rik
Edited By Rik Shaw on 23/07/2019 18:34:22
old mart23/07/2019 20:52:07
3524 forum posts
217 photos
Those of us lucky enough to have the use of a mill can make their own custom made rear toolposts, and dedicated conventional types.
One of the reasons that I have never gone the QCTP route (apart from the cost), is the slight loss of rigidity as mentioned by Brian G.
Emgee23/07/2019 22:22:43
2315 forum posts
277 photos
Does anyone have a picture of the GTN insert removing tool, or a short description. ?
Emgee
JD Metals
MIDLNDS GARDEN RAIL Jan 2022
rapid Direct
