Toyo MD-1 mini drill - drive belts needed
Manfred Baer22/07/2019 18:36:16
15 forum posts
Many years ago I bought a new Toyo MD-1 drilling machine in Devon. The 2 drive belts (which look like commercial grade o-rings) have become brittle over the years. Who can help with a source for a set of spare drive belts or with information about the dimensions of the original belts?
Thanks,
Manfred
Rik Shaw22/07/2019 18:53:04
1365 forum posts
373 photos
Hello Manfred - I have a Record ML-210 mini lathe (Toyo look-a-like) which uses those o-ring type drive belts. I managed to obtain some spares local to me from here:
Rik
Manfred Baer22/07/2019 19:20:55
15 forum posts
Hi Rik,
Thanks for your reply. How did you find out what size O-rings were needed in your machine?
Manfred
Brian G22/07/2019 19:44:57
715 forum posts
28 photos
Could you go the same route as for a Unimat SL and use round polyurethane belting? Easy to join with a hot knife, even easier with a plastic cutting tip on a soldering gun. Start with the belt a little too long and shorten until it doesn't slip.
Rik Shaw22/07/2019 20:13:06
1365 forum posts
373 photos
Manfred - I took the little lathe to the firm in the link and they matched the o-rings to it. By the way, I tried polyurethane / hot knife belting route but it did not work - I recommend the o-ring option as the way to go. Good luck.
Rik
Manfred Baer22/07/2019 21:06:18
15 forum posts
Brian, Rik,
Thanks for your support. Since having some experience with PU belting on spinning wheels (wife) my first choice would be a seamless o-ring. I found that it is quite a task to achieve a (more or less) true running PU joint even for a low rev application like a spinning wheel.
Manfred
Nick Hulme29/07/2019 16:58:55
743 forum posts
37 photos
Posted by Manfred Baer on 22/07/2019 21:06:18:
Brian, Rik,
Manfred
Use V blocks and a straight edge, works perfectly every time for round PU belting and also for bonding O rings from cord.
Manfred Baer29/07/2019 21:06:42
15 forum posts
Nick, thats a nice idea how to align the ends of the belting stuff for a good joint. I'll give it a try.
Thanks for posting, Manfred
EngineDIY
