Myford Change Gear trouble
Mark Gould 116/07/2019 16:39:13
194 forum posts
117 photos
Gents,
We are trying to cut an M10 thread on our S7 lathe. We have a metric conversion set and have installed the slotted quadrant as per Myford booklet. The quadrant has been fitted with the required change wheels.
The problem we are having is with the Tumbler Stud. As per the booklet, it must have 30 teeth. The tumble stack is quite thick as the tumbler gear itself has a flange of sorts. This makes the outer wheel on the tumbler stack stick out too far as it comes into contact with the outer wheel beneath it. It is only supposed to drive the inner of the 2 wheels beneath it. I took some photos to illustrate the problem. It may look ok in the photo but the outer wheel on the tumbler stud is actually touching the outer wheel of the stack below it as it's only supposed to drive the inner wheel of the stack beneath it.
Any help is greatly appreciated,
Mark
Edited By Mark Gould 1 on 16/07/2019 16:40:35
ega16/07/2019 16:45:26
1618 forum posts
136 photos
Is it just a matter of packing out the new quadrant?
Edited By ega on 16/07/2019 16:47:46
KWIL16/07/2019 17:07:18
3215 forum posts
63 photos
Yes
Martin Kyte16/07/2019 17:09:06
1788 forum posts
33 photos
It looks like you need to fit a spacer between the two change wheels on the quadrent. Myford supply such an item which is used on most wheel set up's on non gearbox series 7 lathes to provide clearence and stop the change wheels rubbing. It looks like a penny washer with a cut out for the key so you can slide it onto the stud. If you have a set of change wheels you should have one.
regards Martin
Nick Hulme16/07/2019 17:16:14
743 forum posts
37 photos
Yes, add spacers, or skim the quadrant to align correctly.
Mark Gould 116/07/2019 17:24:18
194 forum posts
117 photos
Yes, that is the logical step. I took a short cut and put a washer on the whole stack which moved the whole stack outwards but a spaced between the 2 wheels is the way to go. I'll order the parts from Myford.
Thanks gents!
I told my Dad we'd have the answer inside 15 minutes, you gents are fantastic, many thanks from Dad and myself
ega16/07/2019 17:53:31
1618 forum posts
136 photos
Glad to help and to know who the "we" are!
Although I have a shop-made equivalent of the Myford conversion set, I mostly just "play tunes" on the stud gear in the way that has been frequently mentioned here. Brian Wood's book is recommended on this topic.
KWIL16/07/2019 23:03:40
3215 forum posts
63 photos
Before you leap to any further conclusions.
Consider if the Anchor Pin, part no A3015 Dwg Ref 203 is correctly assembled into the base of the gearbox. Its depth is set by a single Socket Setscrew (from below). If correctly set this is what hold the quadrant in the correct position to ensure the gears do in fact properly align, without adding any spacers to the gear train.
Mark Gould 117/07/2019 23:28:54
194 forum posts
117 photos
Good point, KWIL, many thanks I will certainly do that next time I am at the lathe. I didn’t even know there was a pin down there.
Mark Gould 117/07/2019 23:32:43
194 forum posts
117 photos
Ah I now know which pin you mean. I wasn’t aware that pin was only held in by a set screw. I just had a look at a pdf I have here on my tablet and see it how that could cause this issue.
thanks again, excellent.
Mark Gould 117/07/2019 23:32:44
194 forum posts
117 photos
Edited By Mark Gould 1 on 17/07/2019 23:35:21
Mark Gould 123/07/2019 12:10:25
194 forum posts
117 photos
KWIL,
Just getting back to what you said, it's actually in the manual that I have. Makes it all the more embarrassing that I missed it, duh!
Mark
