Forum sponsored by Allendale Dec 6th
Rusty tooling restoration
Jon Cameron15/07/2019 20:08:15
231 forum posts
87 photos
Hello, I recently bought a job lot of rusty tools, the reason for buýing them was this lovely bunch of tools that were hidden amongst the pictures.
There is also a marking out gauge which I was wondering if this was featured as a build in ME or if someone could identify the maker.
The fixed and travelling steady are up for sale if anyone is interested. As they are for an ML10 I believe so won't fit my ML4.
How do I go about cleaning the rust off the surface of the tooling?
Lastly what is the other faceplate with a spigot on it, anyone used or have one of those as I've not seen anything like it before.
Bazyle15/07/2019 20:25:13
4851 forum posts
194 photos
There are quite a lot of threads already on here about rust. If you go to the website front page, not the forum front page and use the search box there it will come up with some. Quite a lot of options but for this light rusting ignore the brick/patio cleaner options.
I think the spigot o the faceplate is not part of the original and just fitted for quick mounting in a 3 jaw. The faceplate itself looks like a Picador one or one from a drill powered wood lathe.
3404615/07/2019 20:32:43
883 forum posts
6 photos
There are also several in depth videos using chemical and non chemical methods on you tube.
Bill
Vic15/07/2019 20:40:39
2374 forum posts
12 photos
Battery charger and washing soda works really well and doesn’t etch the surface like acid will.
Brian H15/07/2019 20:50:19
1333 forum posts
100 photos
I recently tried Evapo-rust from Frosts, removed all rust and left a matt grey finish that doesn't re rust immediately. Very pleased with it, and you can re-use it until it no longer works.
Spurry15/07/2019 21:16:42
167 forum posts
59 photos
Citric acid crystals dissolved in warm water, work very well, and give good results...cheaply.
Pete
Andrew Tinsley15/07/2019 21:19:27
941 forum posts
Hello Jon,
I have sent you a PM.
Andrew.
old mart15/07/2019 22:50:39
962 forum posts
104 photos
A lot of that stuff will respond best to a bit of wire wool and 3 in 1 oil or WD40. Use thick pvc gloves.
 If the faceplates are to be used in a lathe, then a light facing off will kill two birds with one stone.
Edited By old mart on 15/07/2019 22:53:16
ega15/07/2019 22:55:00
1374 forum posts
113 photos
At first sight I thought the faceplate could be from GHT's UPT.
Jon Cameron15/07/2019 23:11:44
231 forum posts
87 photos
Thanks for all the replies, i think ill try the citric acid crystals first on the calipers. From what ive been reading from bazyles suggestion is that electrolysis can leave raised sections of black stuff, so could effect the accuracy of any surfaces, and strong acids can eat into the surface of the metal. Evapourust seems to be a good one without any harmful chemicals but is still costly to buy in any quantity. So for me it's the crystals and then maybe the evapourust.
Cheers again
Jon
Jon Cameron15/07/2019 23:16:34
231 forum posts
87 photos
Posted by ega on 15/07/2019 22:55:00:
That's what I was wondering......I remember seeing pics of it before.
Spurry16/07/2019 09:34:39
167 forum posts
59 photos
Posted by Jon Cameron on 15/07/2019 23:11:44:
Cheers again
Jon
From my experience with the citric acid, keep your eye on it when you have dunked the bits and pieces. The rust disappears, the metal takes on a nice silvery sheen, but if left too long the metal can get discoloured. It is quite a long temperature-dependent process though.
Pete
Tee London LMES 6th Dec
