Forum sponsored by Allendale Dec 6th
Cable Gland?
Vic13/07/2019 15:02:38
2373 forum posts
12 photos
I want to install a temperature probe into a water inlet pipe. The probe is 4mm diameter but the wire itself is a figure 8 cable about 1.5mm x .75mm. Are there any cable glands that can deal with this? Water pressure is low and the gland can go into an alloy manifold. 1/4” or 3/8” BSP would be good for the gland body.
Speedy Builder513/07/2019 15:09:02
1863 forum posts
130 photos
Does the probe need to be in the water, or could it be in a pocket that is in the water ? Alternatively, can the gland grip the 4mm diameter probe instead of the cable ?
BobH
Frances IoM13/07/2019 16:57:33
669 forum posts
24 photos
why not make a top hat out of copper (or ali) that can be fitted into a standard T junction and reach down into the water with the temp sensor tightly fitted into drilled holes into top of the T possibly packed with thermal paste if sloppy fitting - the top hat is so will seal when fitted into the T junction
Edited By Frances IoM on 13/07/2019 16:58:26
Vic13/07/2019 17:38:00
2373 forum posts
12 photos
The probe could just be inserted into the tank but I thought things would look neater If the probe was hidden in the pipe. They sell 12mm x 1.5mm cable glands but the minimum cable size is 3.5mm. I do have some silicon cord though some I’m wondering if I can make a suitable packing piece? Being able to remove the probe periodically for cleaning purposes is also a requirement.
Bazyle13/07/2019 18:53:13
4844 forum posts
191 photos
Work out where on the wire you need the gland to be then fit a small piece of tube there using a suitable eg silicone sealant filler. if you think the flexing wire might break the seal make the tube longer, seal one end to the wire, fill up with a non setting or softer glue, then seal the other end.
V8Eng13/07/2019 19:08:32
1329 forum posts
28 photos
If I read this correctly it appears that you are proposing to immerse the whole assembly with just the cable exiting via the gland (sorry if I misread that).
If that is correct: have you checked that probe to cable interface is suitably sealed for that purpose, also do you know if the cable itself is suitable for continuous immersion?
Edited By V8Eng on 13/07/2019 19:08:49
Boiler Bri13/07/2019 20:35:06
813 forum posts
287 photos
Hi. Atex rated glands will do the job. They have o rings on the gland threads and seal to be safe on the cable. You have to machine cut the holes in whatever your fitting them into so its a tolleranced fit
I have loads. Pm me if you want a few sending. I would need to know what size cable you are using ?
Bri
not done it yet14/07/2019 07:54:06
3736 forum posts
15 photos
If it is the common ‘K type’ transducer get another that can be sealed, is my suggestion.
Edited By not done it yet on 14/07/2019 07:54:38
Tee London LMES 6th Dec
