Forum sponsored by Allendale July 23rd
Stub Mandrel in Aluminium
WIll it work
Iain Downs11/07/2019 18:26:00
478 forum posts
361 photos
I want to turn the back side of my flywheel (1 inch deep, 6 inch across) mounting it on a stub mandrel.
It has a 22mm bore.
I have no steel around that size, but I do have a piece of 25mm aluminium bar which could be pressed to service.
Is that a good idea? Or is it to soft?
Just to add a note, I then need to turn it round and finish off the first side so it needs to go on twice.
Iain
Michael Gilligan11/07/2019 18:40:15
13544 forum posts
586 photos
Posted by Iain Downs on 11/07/2019 18:26:00:
It has a 22mm bore.
Iain
If you really mean Aluminium, Iain ... then yes it's probably too soft
But if [as I suspect] it's an extruded hard alloy then it could well be O.K.
... First test would be to see how cleanly it turns.
JasonB11/07/2019 18:45:12
15737 forum posts
1646 photos
1 articles
Have you thought of holding it by the inside of the rim, you will get less vibration/chatter than is likely on a mandrel
Iain Downs11/07/2019 20:02:43
478 forum posts
361 photos
It's not pure aluminium - I had some of that a while back and it was HORRID to work.
It turns very very nicely. Much better finish that steel or cast with more or less any tool.
I hadn't thought of holding it by the inside of the rim. I'm not convinced that the chucks I've got extend that far.
However, it's worth giving it a go. Chatter is a problem with my machine pretty much all the time, so no need to make it worse!
Iain
JasonB11/07/2019 20:12:15
15737 forum posts
1646 photos
1 articles
You should be able to do it with the jaws reversed and still have plenty of jaw in the chuck body
Iain Downs15/07/2019 21:08:16
478 forum posts
361 photos
I did as suggested and just about the other side sorted out. The wheel was about 0.1 mm off centre held in the 3 jaw on the inside.
After taking off the bulk of the metal this way, I reverted to the aluminium stub mandrel to finish back to more accuracy and it worked a treat.
More details on my build log...
Iain
TRANSWAVE Converters
Advertise With Us
Meridienne Sept 2019
Ausee.com.au
