Forum sponsored by Allendale Dec 6th
Aldi bargain laser level
Ian Johnson 117/07/2019 00:32:58
211 forum posts
63 photos
Michael Gilligan17/07/2019 06:43:50
14586 forum posts
633 photos
Posted by Ian Johnson 1 on 17/07/2019 00:32:58:
But did you actually follow-up on my recommendation, Ian ?
... made yesterday morning at 06:54:33
MichselG.
Ian Johnson 117/07/2019 09:30:18
211 forum posts
63 photos
Posted by Michael Gilligan on 16/07/2019
Given that you have "checked it again" and and found another unlikely size; I think it advisable to try measuring once more ...
There is, of course, no obligation upon Aldi to use any standard thread; but if they have tried to follow convention, the most likely choice would be 5/8" x 11tpi.
Thanks Michael but there is no need to, it is a very sloppy M16 x 2 (which I haven't got any taps or dies for) so I'll re-cut the thread to something I have got. Something like 1/2"UNC / Whit, then make an adaptor to suit. It needs a chunky thread because it's cheap plastic rubbish and if I make mess of it, it goes in the bin! It only cost £3.49 after all. Bit of a bargain I think.
Ian
Michael Gilligan17/07/2019 09:35:08
14586 forum posts
633 photos
Thanks for the confirmation, Ian yes
P.S. Bargain status 'seconded'
Edited By Michael Gilligan on 17/07/2019 09:38:54
Neil Wyatt17/07/2019 19:28:47
16935 forum posts
690 photos
76 articles
Posted by RMA on 15/07/2019 23:27:58:
Neil makes a comment about my username,,,,why? It's not a posting.
Just humorously pointing out the irony ..
But the forum seems to have had something of a humour bypass. There seems to be something in the air these days.
Frank Gorse17/07/2019 20:09:17
28 forum posts
What this thread is short of is a bit of pedantry so may I point out that it’s only an acronym if the letters form a word,such as UNESCO,RADAR etc. Otherwise it’s just a TFLA (three or four letter abbreviation) You’re welcome.
Daniel17/07/2019 20:47:09
254 forum posts
39 photos
Posted by Neil Wyatt on 17/07/2019 19:28:47:
Perhaps a bit too much sun,
Posters have become very grumpy, recently
Ian Johnson 117/07/2019 23:25:59
211 forum posts
63 photos
My 'Threadlocker' photo didn't work very well did it! laugh
David Standing 118/07/2019 08:27:34
1281 forum posts
46 photos
Isn't that a fact Neil! sad
Read, and move along if you don't like it, is my mantra.
mark costello 118/07/2019 16:11:53
554 forum posts
12 photos
271 thread locker is supposed to be the permanent one.
Ian Johnson 118/07/2019 22:10:34
211 forum posts
63 photos
Not permanent enough it seems! This thread just refuses to die!  laugh (edit: I forgot the emoji)
Edited By Ian Johnson 1 on 18/07/2019 22:12:52
Michael Gilligan18/07/2019 22:27:05
14586 forum posts
633 photos
Posted by Ian Johnson 1 on 17/07/2019 09:30:18:
... it is a very sloppy M16 x 2 (which I haven't got any taps or dies for)
Ahah !
That's probably why the thread won't die devil
Mark Rand18/07/2019 23:16:51
828 forum posts
Just a little niggle from a little way back:- Why would one assume that camera and telescope mounting threads are UNC? They were in use a long time before Unified threads were decided upon.
Please use the correct (Whitworth) thread form for your tripods!
Oh, and 5/8" x 13tpi is probably a DD Holtzapfel thread. cheeky
Michael Gilligan18/07/2019 23:28:04
14586 forum posts
633 photos
Posted by Mark Rand on 18/07/2019 23:16:51:
Tripod threads were Whitworth ... They are now UNC [and have been for some years], specified to a sufficiently loose fit that they are 'compatible' with Whitworth.
It's all there in the standard.
https://www.iso.org/standard/55918.html
Edited By Michael Gilligan on 18/07/2019 23:35:35
Mark Rand18/07/2019 23:53:32
828 forum posts
Bah! Humbug! Revisionist history!
Edit to add smiley. laugh
Edited By Mark Rand on 18/07/2019 23:54:30
Michael Gilligan18/07/2019 23:54:58
14586 forum posts
633 photos
Posted by Mark Rand on 18/07/2019 23:53:32:
laugh Goodnight.
andrew lyner19/07/2019 00:01:35
149 forum posts
2 photos
Trouble is that camera equipment has been used for years and there's no reason (as far as photographers are concerned) for changing that thread standard. I would think that most photographers are not DIY people and they just buy stuff. So the standard continues. I use both sizes of thread because the small thread is not strong enough for very heavy lenses (= modest sized refractor telescopes).
The available adapters are at least as expensive as that now famous cheapo laser level.
Ian Johnson 119/07/2019 00:22:44
211 forum posts
63 photos
Posted by Michael Gilligan on 18/07/2019 22:27:05:
Ahah !
Has anybody got any spare sloppy taps and dies? Preferably sloppy UNC though!
Ed Duffner19/07/2019 00:40:29
741 forum posts
61 photos
I bought one of these laser levels from B&Q many years ago for about £30. I think I've used it twice so far. For finding levels in the garden to add a railway sleeper, low retaining wall and to check and level the ceiling timbers in my living room when I knocked the hall through. I was surprised to find the timbers had a difference of as much as 7/8" or ~22mm lowest to highest point. !!!
I find levelling the base of the tool to be a bit tedious.
Ed.
andrew lyner19/07/2019 00:42:22
149 forum posts
2 photos
Wassamadda you lathe owners? You don’t need taps and dies - just a bit of time and some gears.
Ausee.com.au
